aboshhab
anyone explain advantages of rest api over old api?
Wed Aug 31, 2022 4:40 am
hello everyone
may i ask what the advantages of new rest api?
i use standard api with php
is rest api better ? and what difference bt them?
vecernik87
Forum Veteran
Forum Veteran
Re: anyone explain advantages of rest api over old api?
Wed Aug 31, 2022 6:05 am
The new REST API is easier to implement than the old one - if follows common RESTful approach instead of reinventing wheel with proprietary, binary based communication. If you already have implementation already done, you won't gain much if you decide to use the new one.
Larsa
Re: anyone explain advantages of rest api over old api?  [SOLVED]
Wed Aug 31, 2022 8:24 am
Just be aware that https (ssl) might be quite slow on many devices.
aboshhab
Wed Aug 31, 2022 10:29 am
in general do you advise me to use rest-api instead of old one?
rextended
Wed Aug 31, 2022 1:47 pm
If you start from 0, yes...
If you already have implemented something, you can continue.
aboshhab
Wed Aug 31, 2022 11:50 pm
ok
but what advantages of rest api over old api ?
