emils
Forum Veteran
Forum Veteran
v7.5 [stable] is released!
Wed Aug 31, 2022 1:54 pm
RouterOS version 7.5 is released in the "v7 stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during the upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.5 (2022-Aug-30 12:25):
*) bgp - fixed remote refuse capability options, max prefix limit errors and administrative stop;
*) bgp - improved stability when "default-originate" is configured;
*) bridge - fixed "new-priority" value validation for NAT rules;
*) capsman - added randomized range option for "reselect-interval" parameter (CLI only);
*) certificate - fixed handling of empty AKID by SCEP client;
*) console - fixed automatic command completion with keypress;
*) container - added support for running Docker (TM) containers on ARM, ARM64 and x86 (containers created before v7.4 must be recreated);
*) defconf - fixed loading of default configuration on RB4011 with WifiWave2 package enabled;
*) dhcpv4-server - fixed removal of dynamic leases when server is removed;
*) dhcpv6-client - moved invalid lifetime logging message from "debug" to "error" topic;
*) dhcpv6-client - use /128 prefix for IA_NA addresses;
*) dhcpv6-relay - fixed relay forwarding (introduced in v7.1.5);
*) dhcpv6-server - improved stability when acquiring binding;
*) dns - added "address-list" parameter for static DNS entries (CLI only);
*) dns - added "match-subdomain" option for static entries (CLI only);
*) firewall - added support for RTSP helper;
*) health - fixed "temperature" and "power-consumption" readings on RB1100x4;
*) health - improved voltage reading on CRS112-8P-4S;
*) health - renamed "cpu-temperature" to "switch-temperature" on CRS312-4C+8XG, CRS326-24S+2Q+, CRS354-48P-4S+2Q+, CRS354-48G-4S+2Q+, CRS504-4XQ-IN, CRS518-16XS-2XQ;
*) hostpot - fixed Walled Garden functionality for HTTPS sites;
*) hotspot - automatically reject all HTTPS requests passing through HotSpot server for unauthorized users;
*) hotspot - improved stability when receiving bogus packets;
*) hotspot - limit maximum allowed connections based on free RAM resources;
*) hotspot - removed "https-redirect" option;
*) ike2 - allow sending certificate chain as initiator;
*) interface - fixed default interface naming on RB1100x2;
*) l3hw - fixed HW offloaded NAT;
*) leds - fixed default LED configuration for RBwsAP-5Hac2nD;
*) leds - fixed wireless LED functionality on LHGG;
*) lora - do not ignore negative sign for spoofed GPS coordinates;
*) lte - added at-chat and NMEA port support for Simcom modems, USB composition (device id - 0x9003);
*) lte - added at-chat support for Simcom modems, USB composition (device id - 0x9005);
*) lte - added "SIM not inserted" and "SIM failure" messages to "status" and "monitor" commands for AT modems;
*) lte - changed cell ID info display to short format for 3G connections;
*) lte - disallow empty APN name only for default entry;
*) lte - fixed AT channel for Sierra Wireless modems with device ID 0x9091;
*) lte - fixed LTE interface presence for Telit LN940;
*) lte - fixed UDP performance on MMIPS devices;
*) lte - improved antenna scan for Chateau devices with switchable antennas;
*) lte - improved configuration export when multiple LTE interfaces are present;
*) lte - modem dialer, do not reset dialing sequence if modem reply with error to user set init-string;
*) netinstall - fixed Netinstall procedure for ARM devices;
*) netwatch - automatically start migrated probes from previous RouterOS versions;
*) netwatch - changed ICMP default packet loss fail threshold to 85%;
*) ntp - fixed NTP server when "use-local-clock" is used;
*) ospf - fixed handling of external forwarding address;
*) ospf - improved stability when interface is being disabled during database exchange;
*) ovpn - fixed encryption key renewal process which caused periodic session disconnects;
*) ovpn - improved system stability when hardware acceleration is used on ARM64 devices;
*) ovpn - moved disconnected user logging message from "debug" to "info" topic;
*) ping - improved service stability;
*) port - added support for D-Link DWM-222 in serial/PPP mode (device id - 0xac01/0x7e3d);
*) port - added support for Huawei/ZTE K5006z in serial/PPP mode (device id - 0x1017/0x1018);
*) ppp - improved service stability under high load;
*) ppp - use /32 as default netmask if not specified for "routes" parameter;
*) ptp - improved system stability on CRS devices;
*) quickset - removed PPTP and SSTP server addition for "VPN" checkbox;
*) rb5009 - fixed ether1 status reporting after system reboot;
*) route-filter - fixed "delete bgp-communities" command;
*) routerboard - added "reset-button" script feature for TILE devices;
*) sfp - fixed "eeprom" reading on single SFP port ARM devices;
*) sfp - fixed QSFP+ and QSFP28 interface disable when using breakout cable;
*) sfp - fixed unresponsive "sfp1" interface after disabling "ether1" on NetMetal devices;
*) sfp - improved combo SFP ports initialization handling on CRS312-4C+8XG, CRS328-4C-20S-4S+;
*) sfp - improved stability when using 2.5G optical modules in CCR2116, CCR2216 and CRS518;
*) snmp - fixed usage of VRF after system startup;
*) socks - fixed "dst-port" usage when checking access list;
*) ssh - added AES support for PEM decryption;
*) ssh - fixed importing of public keys;
*) ssh - fixed minor typo issue when importing public key;
*) sstp - fixed client stuck in "nonce matching" state;
*) switch - fixed ACL rules for 98DXxxxx switches with more than 28 ports (introduced in v7.3);
*) switch - removed limit for number of hardware-offloaded bonding interfaces;
*) swos - enabled SwitchOS support for CRS310-1G-5S-4S+;
*) swos - fixed SwOS upgrade procedure on CRS305-1G-4S+;
*) traceroute - added "do-not-fragment" parameter support (CLI only);
*) traceroute - increased packet size limit to 65535;
*) vrrp - added "sync-connection-tracking" compatibility with preemption-mode;
*) vrrp - fixed high CPU usage when "sync-connection-tracking=yes" and the backup router goes offline;
*) vrrp - fixed HW offloaded bridge MAC address learning when changing from VRRP master to backup;
*) vrrp - fixed initial connection tracking synchronization, a backup router now always receives all existing connections;
*) vrrp - improved connection tracking synchronization protocol (CTSYNC), the new protocol is incompatible with previous RouterOS versions with "sync-connection-tracking=yes";
*) webfig - allow to specify NTP server as domain name;
*) webfig - fixed displaying of grahs in status pages;
*) webfig - fixed floating point field's negative value in -0.*** format;
*) wifiwave2 - added "sae-pwe" parameter with hash-to-element mechanism for SAE PWE derivation;
*) wifiwave2 - added support for 802.11k;
*) wifiwave2 - disable wireless interface after wireless configuration reset;
*) wifiwave2 - fixed displaying of AKM in scan results;
*) wifiwave2 - fixed duplicated AKM in RSN message;
*) wifiwave2 - fixed group key update for client devices which connect via fast BSS transition;
*) wifiwave2 - fixed incorrect AKM usage for FT-WPA3-EAP-192;
*) wifiwave2 - fixed reassociation response sending for fast transition over DS;
*) wifiwave2 - fixed setting of "ft-nas-identifier" parameter;
*) wifiwave2 - fixed usage of Canada country setting on US locked devices;
*) wifiwave2 - improved default channel width selection for interfaces in station mode;
*) winbox - do not show previously attached LTE interfaces while establishing LTE connection;
*) winbox - enabled all filters by default under "Tools/Torch" menu;
*) winbox - fixed "Enable", "Disable" and "Comment" functions for L2TP-ether type interfaces;
*) winbox - fixed "Next Run" parameter displaying under "System/Scheduler" menu;
*) winbox - fixed "Type" and "Value" field displaying under "System/Health" sub-menu's;
*) winbox - show warning messages for BGP connection entries;
*) wireless - fixed interface initialization on x86 devices;
*) x86 - allow downgrading to RouterOS v6 only if it was previously installed;
*) x86 - fixed advertising of 2500M and 5000M link speeds on ixgbe driver;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while the router is not working as suspected or after some problem has appeared on the device
Rox169
Re: v7.5 [stable] is released!
Wed Aug 31, 2022 1:58 pm
first :) Please let me know on what devices did you try this STABLE version...especially HAP AC3, HAP AC2, any 60 Ghz device....
templeos
Wed Aug 31, 2022 2:12 pm
Progress, but you still have work to do. Memory usage and Disk usage gives: ERROR: NO ACCESS!
CPU usage is fine and interfaces.
While you are at it fix mikrotik_logo.png on WebFig. Please make background transparent and not white.
EDIT: the hardware is hAP ac² and is added image where only CPU is present
Reason: added hw used and image
giulianoz
Wed Aug 31, 2022 2:36 pm
Can you explain this, please?
rextended
Wed Aug 31, 2022 2:44 pm
Containers are removed on 7.4 and reintroduced again on 7.5
On changelog of the stable are considerered only the change between previous stable and this version.
rextended
Wed Aug 31, 2022 2:50 pm
Hardware used: hAP ac²
After trying several times to install 6.44.6, activate the graphs, have them recorded, then update to 7.5,
and repeat the process with 6.46.8 and 6.48.6, I was unable to duplicate the problem.
All the times the graphs worked perfectly.
Probably is a problem on your filesystem, and since you don't give a damn about contacting technical support(*) , I'ts your problem.
(*) On removed useless posts, the user do not want provide supout.rif to technical support at support@mikrotik.com
rextended
Wed Aug 31, 2022 3:04 pm
What is the problem???
eworm
Wed Aug 31, 2022 3:08 pm
It looks ugly to have a white rectangle on a grey gradient...
th0massin0
Wed Aug 31, 2022 3:33 pm
SUP-67642 (SSTP long connecting).
winap
Wed Aug 31, 2022 3:38 pm
So tell me, is there any difference between RC2 and final?
rextended
Wed Aug 31, 2022 3:45 pm
The differences reported are between 7.4.1 and 7.5, it should not be changed between 7.5rc2 and 7.5
@eworm
I try to use my monitor at home, thanks.
mmc
Wed Aug 31, 2022 4:14 pm
was this a bug regarding ospf redistribution - does somebody have more info about it?
Ullinator
Wed Aug 31, 2022 4:16 pm
Update successfully done without problems (ROS and FW) from 7.4.1 to 7.5 on the following devices:
DL7JP
Wed Aug 31, 2022 4:47 pm
CRS125-24G, hAP ac, hAP ac^2, CCR2004-16G: Upgraded, no problems noticed.
jvanhambelgium
Wed Aug 31, 2022 4:54 pm
Updated RB3011 from 7.5RC2 to 7.5 "Stable" , no imminent issues ;-) for now.
BrateloSlava
Wed Aug 31, 2022 5:06 pm
Example, please.
didis81
Wed Aug 31, 2022 5:17 pm
Updated a small network about 50 device to 7.5 Stable no issues for now.
All good
rextended
Wed Aug 31, 2022 5:44 pm
Example, please.
This example is for obtain a random FIXED time everytime the script is called, or when creating new interface,
but after first creation, or after set, the time between intervals still the same.
/caps-man/interface set <CAPSMAN INTERFACE NAME> channel.reselect-interval=[:rndnum 86400 172800]
On next @Guntis post, you have the example to set a range between two values for channel.reselect-interval,
with that values when the channel.reselect-interval expire, the memorized values are used for choose everytime a different time interval between two channel-reselection.
Guntis
Wed Aug 31, 2022 6:28 pm
Example: caps-man/configuration/add channel.reselect-interval=10m..20m
It will run channel reselection at a random interval that is within the defined range.
mseidler
Wed Aug 31, 2022 6:38 pm
Upgraded an RB3011, RB4011, CRS326-24G-2S+, CRS1128-8P-4S and CRS309-1G-8S+, 2x wAP G-5HacT2HnD without issues.
TIS
Wed Aug 31, 2022 7:25 pm
Upgraded from 7.4.1 to 7.5 CHR Amazon + HEX 750G r3 flight normal :)
juniorespow
Wed Aug 31, 2022 7:37 pm
Issue showing uptime and Remote ID of BGP SESSIONS after upgrading to 7.5
holvoetn
Wed Aug 31, 2022 8:20 pm
2x hap AC3 upgraded (home network, wifiwave2 and VLANs, nothing fancy), no noticeable issues.
tarikin
Wed Aug 31, 2022 8:39 pm
After reboot lost my home hap ac2 7.4.1 -> 7.5 with:
- vrrp master
- capsman
- dual pppoe wan ipv4, ipv6
- some other functions
Got boot loop.
Another hap ac2 with similar configuration upgraded without issues
- configured but disabled vrrp slave interface
nexusds
Wed Aug 31, 2022 8:54 pm
WAP60G station-bridge (WAP60G-AP are ok as bridge-ap) causing high bandwidth (20-30Gbps) only on wlan60-1 interface and 1xcore CPU spike upon management login. 7.4.1 works fine - only a problem on 7.5
Panbambaryla
Wed Aug 31, 2022 9:51 pm
Why does it take so long to run SFP+ Mikrotik transceiver on RB4011iGS+5HacQ2HnD? It started to behave this way a few 7 releases back and since that moment I always have to wait much longer for communication with my LAN.
Last edited by Panbambaryla on Thu Sep 01, 2022 10:00 am, edited 2 times in total.
revilo
Wed Aug 31, 2022 9:59 pm
RB5009UG+S+ Moved from 7.4 to 7.5 - ppp client not connecting after upgrade (connected once during multiple reboots)
Moved to 7.5rc2 now and it's connecting normally again.
LonDat
Wed Aug 31, 2022 10:38 pm
Does it mean, I should do Netinstall again when I did Netinstall on AC3 and Audience (both ARM) with OS 7.3.1 and 7.4.1?
draid
Wed Aug 31, 2022 10:41 pm
The SFP module information is still missing and this is getting really frustrating. I understand if it was some kind of 3rd party SFP module, but one would expect a MT branded module to work out of the box with a MT device as intended. HexS and S-85DLC05D. I'm tired of rolling back to 6.49 every time. At least give some information on this problem...
Rox169
Wed Aug 31, 2022 10:57 pm
anyone else has this issue? Have you log SUP to Mikrotik?
nexusds
Wed Aug 31, 2022 11:28 pm
Yes Support as an auto generated supout since it crashed the CPU with the load.
Guscht
Thu Sep 01, 2022 12:52 am
Without incident my homenetwork:
lelmus
Thu Sep 01, 2022 3:07 am
Updated to 7.5 stable and have issue with sfp+. Every time I software reboot RB4011iGS+5HacQ2HnD, I keep getting "sfpplus1 fcs error on link" on sfpplus1 of CCR1016-12S-1S+. Winbox is connected to CCR1016-12S-1S+ as its the main router that everything connects to. The way to fix RB4011iGS+5HacQ2HnD is by hard rebooting with complete power loss for 10+ seconds. Doing a software reboot RB4011iGS+5HacQ2HnD locks me up again. All sfp+ ports are on default settings.
aglabs
Thu Sep 01, 2022 3:50 am
Interesting, on my CCR2116 l3hw nat was working fine for me before 7.5. Post 7.5 traffic that is natted has high % drop rate so high not even a TLS session can establish. Disabling l3hw removes the packet loss behavior.
nichky
Thu Sep 01, 2022 4:19 am
@Guntis
so that one will have effect only if the channel is auto , if i specify it, then there is no point using that , am i correct?
hoeser
Thu Sep 01, 2022 5:02 am
VRRP issues between a setup with an x86 & CCR2004 master/slave preemptive setup on 7.5 (both devices) - both nodes showing master, packet sniffing confirms all traffic including broadcast is seen by both nodes.
I wanted to start debugging this outside production on pair lab HEXs - both on 7.5, both fresh barebones configs - ended up with a completely different VRRP problem - vrrp IP and vrrp interfaces stay in invalid state on both routers despite valid shared /32 address in the same address space as the parent interface.. was using ether3 on both lab hex routers connected directly.
So, VRRP seems a little janky on 7.5
sirbryan
Thu Sep 01, 2022 5:25 am
I confirmed this on my 2115 as well. L3HW switching was enabled on the switch and NAT worked prior to 7.5. After upgrade NAT was broken until I disabled L3HW switching on the switch.
nexusds
Thu Sep 01, 2022 7:13 am
Similar issue on RB4011 - SFP+ 10G Copper.. had to disable/enable/change auto to hard code and back again a few times then it would work fine. (did try cold reboot as you did)
Rox169
Thu Sep 01, 2022 8:03 am
Is the netinstall necessary or it is enough only when I flash this firmware?
nichky
Thu Sep 01, 2022 9:21 am
how to get to :
rextended
Thu Sep 01, 2022 10:02 am
@Guntis
I'm not @Guntis, but if is only one channel in list, is useless, but if you set two or more channels on list, the choice is made on the better on that list.
rextended
Thu Sep 01, 2022 10:07 am
@LonDat, @Rox169
Is a fix inside the Netinstall program, that do not work correctly with some arm device.
Is not needed to netinstall the RouterBOARD or upgrade RouterOS for this program bug.
infabo
Thu Sep 01, 2022 11:04 am
Chateau LTE12, hap lite and map lite -> updated without issues.
raimondsp
Thu Sep 01, 2022 11:44 am
Before 7.5, FastTrack NAT connections could be reported as hw-offloaded despite still getting processed by the CPU. In 7.5 those are actually hw-offloaded. Maybe the problem is that the hardware cannot handle some types of connections (e.g. a tunneled connection), so those shouldn't be offloaded in the first place. Please create a support ticket, so we can investigate the problem.
raimondsp
Thu Sep 01, 2022 11:52 am
Are you using sync-connection-tracking=yes? We have identified the issue where sync-connection-tracking didn't work on HEX (and on any MIPS device); the fix will be released in the next beta.
Regarding the VRRP setup between x86 and CCR2004, please post your "/interface export" and "/ip export" configurations from both devices. I suggest creating a separate forum thread here.
Ullinator
Thu Sep 01, 2022 12:40 pm
Sorry, but I can´t agree. My RB4011iGS+5HacQ2HnD is connected via SFP+ with my CRS326-24S+2Q+ with an MikroTik DAC-Cable and regardless if I soft- or hardreboot my device the SFP+ connection came up without any issues.
So maybe it´s a device specific problem with your CCR or with your SFP+ GBIC.
honzam
Thu Sep 01, 2022 1:01 pm
Hello. CubeG-5ac60ay with 7.5 as client = kernel failure every minute.
After downgrade to 7.4.1 = everything OK
ticket: SUP-91404
hecatae
Hap AC Lite upgraded without issues.
Anyone upgraded a RB2011 or RB3011 yet?
jvanhambelgium
Thu Sep 01, 2022 1:42 pm
Yep, RB3011 went OK.
Only 1 PPPoE to ISP , no complex setup, no routing-protocols etc. Typical home-usage.
osc86
Thu Sep 01, 2022 2:01 pm
2x CubeG-5ac60ad constantly rebooting every 1-3 Minutes, both upgraded from 7.4.1 to 7.5.
EDIT: The issue seems to be related to the W60G interface, once disabled, the reboots stop.
Downgraded to 7.4.1 and devices are stable again with W60G interface enabled.
vecernik87
Forum Veteran
Forum Veteran
Thu Sep 01, 2022 2:04 pm
I just had similar (although not same) experience. CRS328-24P-4S+ upgraded from 7.4 to 7.5. After reboot, SFP+ (FS SFP-10GSR-85) said Link OK and showed both RX and TX traffic. However, on the other end there was no RX traffic!
I tried to enable/disable the port on both ends, change autonegotiation to manual and back, reboot the switch few times and then downgrade back to 7.4 , but there was no change - still broken. So I physically removed the SFP module, plugged it into next SFP+ port and it started working. Plugged it back, it still works. Second time upgraded and it did not break.
Since RouterOS was claiming there are TX data but the other side didn't see any RX, I am assuming there was an issue with the SFP+ module itself. Possibly some random fail during initialization after the upgrade? Definitely worth looking into because it shouldn't report "link ok" if the link isn't in fact ok.
Anyway, I would not recommend other people to upgrade remote devices which rely on SFP ports. If you think that another link with RSTP failover will save you - you are wrong. In my case, the affected switch was further from root switch, so the broken SFP was the root uplink. Affected switch thought it works fine (because it saw RX and TX packets) so it disabled alternate uplinks and essentially cut itself from the the rest of the network.
hecatae
Thu Sep 01, 2022 2:07 pm
ticket: SUP-91404
I take it this was both RouterOS and Routerboard updated to 7.5?
Rox169
Thu Sep 01, 2022 2:08 pm
It is sad to see, that MK is not testing new "STABLE" version again after recently bricked soo many devices....
hoeser
Thu Sep 01, 2022 3:59 pm
Neither setup was using connection tracking.
pe1chl
Thu Sep 01, 2022 4:07 pm
This problem was introduced in the 7.5beta and reported, but it has been ignored so now it ends up in the "stable" release...
iliyah
Thu Sep 01, 2022 5:44 pm
powerpc - after the upgrade from v7.4.1, the router drops all incoming vpn connection every 5 minutes or so.
sterod
Thu Sep 01, 2022 8:07 pm
All devices with ARM cpu's are coming up at the wrong frequency after the 7.4.1 to 7.5 upgrade. You see this in the System / RouterBOARD menu. A warning appears that the cpu is not running at the default frequency. Clicking on the "Settings" button, you see it is incorrectly set to 716MHz and needs to be manually changed back to auto.
kalamaja
Thu Sep 01, 2022 8:13 pm
I have opposite situation with hEX S at 7.5: HDD and Memory available, but CPU missing from Resource Graphs and webfig gives "no access" to CPU.
lelmus
Thu Sep 01, 2022 8:32 pm
Good point, maybe its the SFP+ module brand I'm using as they are not a Mikrotik brand and probably don't get tested at Mikrotik. The SFP+ I'm using at both ends the Maxxwave MW-SX+MM-US. But it worked perfect all these years till the moment of the latest 7.5 [stable] update, so it only makes sense its a bug since 7.5beta11 worked perfectly.
Maxxwave site claims MIkrotik compatibility on this SFP+ module: https://www.maxxwave.com/portfolio/mult ... er-module/
holvoetn
Thu Sep 01, 2022 8:42 pm
I'm not seeing that on hap ac3 coming from 7.4.1, nor on ac3 coming from 7.5rc2 (which also was on 7.4.1 some versions before).
Maybe you never set it to auto before when this was introduced ?
honzam
Thu Sep 01, 2022 9:03 pm
ticket: SUP-91404
YES. Problem is only if CubePRO is in station bridge mode. AP mode works.
@mikrotik.com It is so hard to test before you release it to the world?
Please add warning to changelog and download page.
Remote downgrade is not possible. You need to connect via ETH. Turn off the w60g interface and then downgrade
templeos
Thu Sep 01, 2022 9:32 pm
Yes. I saw another topic that is pretty much the same like yours, but that was on a RB750Gr3 on RouterOS v7.1.3. -> viewtopic.php?p=954791
So it must be related. After an upgrade it breaks graphs.
pe1chl
Thu Sep 01, 2022 9:38 pm
The graphs work fine here. For such cases of strange behavior that other people do not see, I advise jumping through the export-netinstall-import hoop.
rb9999
Thu Sep 01, 2022 11:45 pm
Upgraded about 5 hapac2 from 7.1.5 and 7.4.1 to 7.5 - they all seem up and running, will test out rtsp helper tomorrow, can't wait!
yo3gjc
Fri Sep 02, 2022 2:51 am
Upgraded for v741 to v75 and Mikrotik IKEv2 stop working after few minutes. Active peer up but no traffic
nichky
Fri Sep 02, 2022 5:29 am
since we got new feature with vrrp "sync-connection-tracking=yes"
what/where do we need to see that to confirm that sync-connection-tracking=yes it works.
honeyfairy
Fri Sep 02, 2022 9:37 am
BGP Session uptime bug in this version!
buset1974
Fri Sep 02, 2022 9:48 am
For my mpls + bgp network, for safety ikeep stay on 6.49.x
My CCR2004 only test bench, so unused
To much hoping
chiem
Fri Sep 02, 2022 10:01 am
how to get to :
match-subdomain was demonstrated here: viewtopic.php?t=187950#p948005
It's the same functionality as using a regex, but I suppose it's a little cleaner.
I still haven't seen "address-list" demonstrated.
It would be nice if there was official documentation on these features.
abdurrazaqa
Fri Sep 02, 2022 10:51 am
Please check on the all the Ros7 on RB1100AH*2 showing duplicates of ethernet 13 on interface real name
rextended
Fri Sep 02, 2022 10:54 am
@Maggiore81 / @eworm
Don't pollute this topic. Open a separate topic for installation package assistance, or better use search, and you'll find dozens of similar cases.
But what @Znevna suggest is right: do not upgrade remotely from v6 to v7...
revellion
Fri Sep 02, 2022 11:24 am
I have a similar issue with a pair of wireless wire that started to get flaky after upgrading from 7.4.1 to 7.5. gonna test a downgrade with netinstall today and see
Edit: downgraded to 7.4.1 with netinstall and the link is stable again.
bajodel
Long time Member
Long time Member
Fri Sep 02, 2022 11:39 am
Mikrotik devs, please .. bring back the useful [ /ip route check x.x.x.x ] command (or tell us how to do the same in v7).
EDIT:
feature request ticket opened
SUP-91496
Reason: SUP-91496
DL7JP
Fri Sep 02, 2022 2:10 pm
My hAP ac^2 (arm) came back with "auto".
roe1974
Fri Sep 02, 2022 2:55 pm
Hi !
Anyone tested allready if ovpn ist stable now with this version ?
thx, Richard
swa69er
Fri Sep 02, 2022 2:56 pm
RB5009UGS v7.4.1 to v7.5 so far so good. no issue at the moment
mkx
Fri Sep 02, 2022 5:16 pm
This is really getting stale .... after upgrading Audience with wifiwave2 package from 7.4.1 to 7.5:
  MikroTik RouterOS 7.5 (c) 1999-2022       https://www.mikrotik.com/
Press F1 for help
sep/02/2022 16:13:17 system,error,critical error while running customized default configuration script: bad command name wireless (line 985 column 25)
Is this really so hard to fix?
mozerd
Forum Veteran
Forum Veteran
Fri Sep 02, 2022 5:18 pm
CCR1009 ... upgrade from 7.4.1 to 7.5 stable
Under Winbox v3.37
Disks do not show the installed number of Disks .... attached image shows that under Files does show the proper number of disks but under Disks only 2 disks are visible
Disk2 is USB and named Disk2 but as shown in screen shot as directory
holvoetn
Fri Sep 02, 2022 5:23 pm
There is an option to retrieve the script being used at startup, I believe ?
You should be able to see specifically what the error is about since the exact location has been mentioned ?
mkx
Fri Sep 02, 2022 5:30 pm
No need to dig into it, error message says it loud and clear:
If wifiwave2 package is installed, then /interface/wireless disapears and /interface/wifiwave2 appears. So it's only necessary to wrap the legacy wireless setup with check whether legacy wireless exists or not.
My question was rather rhetorical one.
CTassisF
Fri Sep 02, 2022 5:31 pm
It is probably the router trying to load the default configuration for /interface wireless which can't be done when WifiWave2 (/interface wifiwave2) is installed.
This issue was fixed some time ago in 7.5beta4 so I guess it won't happen from now on.
It's just a warning anyway. Annoying, yes, but nothing dangerous.
mkx
Fri Sep 02, 2022 5:35 pm
So when can I expect the fix to kick in? I did a couple of reboots after installing 7.5 (if not for other things to bring routerboot version up) and the message is shown every time ... my feelingnis that this fix is one of those that need to be included in several ROS releases before they're done correctly.
holvoetn
Fri Sep 02, 2022 5:36 pm
I know it's already a long standing one waiting for an answer :lol:
CTassisF
Fri Sep 02, 2022 5:47 pm
I don't know, I don't have an Audience device. But this same issue used to happen to me on my hAP ac3 every so often when upgrading from one v7 to another and I haven't seen it happening again for quite some time now.
I guess doing netinstall can help in these cases (to wipe old, hidden on export configurations). Maybe an /export show-sensitive file=export + /system/reset-configuration run-after-reset=export.rsc can help too.
mkx
Fri Sep 02, 2022 6:02 pm
Perhaps. I did netinstall when first installing v7 on this device (I think it was 7.1rc2 or something) so no v6 config lingering in backgroud.
Not sure if it would work in this case though ... message clearly says it's "customized default script" doing it and AFAIK that's script which is "burned in" with netinstall. But I never installed anything like that hence it must be MT's script. Could be that issue would not arise if wifiwave2 package was installed as a part of netinstall process (it is possible to upload multiple packages) but I kind of doubt it.
Znevna
Fri Sep 02, 2022 6:10 pm
Under Winbox v3.37
How is Disk2 and Disk3 connected?
You only seem to have one usb device connected with one partition.
mozerd
Forum Veteran
Forum Veteran
Fri Sep 02, 2022 7:05 pm
Good catch Znevna …. In fact disk3 is microSD card and disk2 is microUSB …..
rextended
Fri Sep 02, 2022 8:09 pm
@mkx
Please attach the txt files obtained on this way:
/system default-configuration print file=defaultconfigscripts
thanks.
pe1chl
Fri Sep 02, 2022 8:20 pm
When I last tried that on v7.5 (and now also on v7.6 beta) it said:
error - contact MikroTik support and send a supout file (10)
rextended
Fri Sep 02, 2022 8:26 pm
??? ah...
I tested on 7.2.1 and it works (no wifiwave2 package, is one RB5009 on production)
mkx
Fri Sep 02, 2022 9:29 pm
Currently I'm on my phone so it's not easy to attach output of command above. But guess what? Command produces only 203 lines whereas error message mentions line 985 ...
theosoft
Fri Sep 02, 2022 10:01 pm
RB5009 running 7.5. I prepared installation for 7.6 Beta. I copied the running partion to backup.
I saw strange percentages in progress bar. finaly at 760% copy progress finished :-)
holvoetn
Fri Sep 02, 2022 10:33 pm
@mkx
I sense it is time to netinstall again...
elgrandiegote
Sat Sep 03, 2022 1:09 am
Hi !
thx, Richard
ovpn udp, the client disconnects and the server (mikrotik) never drops the connection, even for hours...
guipoletto
Sat Sep 03, 2022 2:46 am
<< i'm having trouble testing this one
on a RB1100AHX2 running 7.4, the total used disk space is 43.5MB, leaving 20.5Mb free, when 20.6 are required for the update
/export yields a 12K file, and the backup file is 340K (not that big...) and /files is clean (deleted all old backups and export files)
any suggestions? (except Netinstall)
rextended
Sat Sep 03, 2022 3:25 am
@mkx
When the "get-custom-defconf" is interrupted for some reason, the "flag" get-custom-defconf runned successfully is not set, and everytime at reboot it try to run the script,
is why everytime, for every reboot, you get that error.
(The error is on the file "get-custom-defconf" on system package, not on wifiwave2 package)
MikroTik Staff, please, deliver to who manage the get-custom-defconf script this message:
   # wait wlan3 it takes 7sec slower to load than wlan1/2 on Audience
    $addCL ("  :local count 0;")
    $addCL ("  :while ([/interface wireless find default-name=\"wlan3\"] = \"\") do={ ")
    $addCL ("    :if (\$count = 15) do={")
    $addCL ("      :log warning \"DefConf: Unable to find wlan3 interface\";")
    $addCL ("      /quit")
    $addCL ("    }")
    $addCL ("    :delay 1s; :set count (\$count +1);")
    $addCL ("  };")
    # TODO: set band and ext, probably use setWlan function
    $addCL ("  /interface wireless {")
    $addCL ("    :local wl3 [find default-name=\"wlan3\"]")
    $addCL ("    :local wlanMac  [get \$wl3 mac-address];")
    $addCL ("    :set ssid \"SYNC-\$[:pick \$wlanMac 9 11]\$[:pick \$wlanMac 12 14]\$[:pick \$wlanMac 15 17]\"")
    $addCL ("    set \$wl3 disabled=no mode=ap-bridge band=5ghz-a/n/ac ssid=\$ssid security-profile=wpsSync wps-mode=push-button")
    # set channnel width 20/40/80mhz-XXXX (russia 20/40mhz-XX)
<<< LINE 983 >>>    # wait wlan3 it takes 7sec slower to load than wlan1/2 on Audience
    :local count 0;
<<< @mkx LINE 985 >>>    :while ([/interface wireless find default-name="wlan3"] = "") do={
      :if ($count = 30) do={
        :log warning "DefConf: Unable to find wlan3 interface";
        /quit
      :delay 1s; :set count ($count +1);
<<< LINE 993 >>>    :local hwInfo [/interface wireless info hw-info [.. find where default-name="wlan3"] as-value];
      $addDL ("#|     channel-width: 20/40mhz-XX;")
<<< LINE 995 >>>      $addCL ("    set \$wl3 channel-width=20/40mhz-XX")
    $addCL ("  };")
Accidentally the already converted block was not deleted, old code and unused chunks were left from line 983 to line 995.
[Also on line 993 is present a useless local variable (never used anywhere) that give error, becase call directly /int wireless for set his value]
Simply deleting the lines from 983 to 995 solve the Audience problem.
Thanks.
roe1974
Sat Sep 03, 2022 8:32 am
Hi !
thx, Richard
.... means the connection stays open at the mikrotik router (ovpn server) even if the client disconnect ?
mobyfab
Sat Sep 03, 2022 1:37 pm
I'm having the same issue. Those connections were definitely offloaded (no cpu activity at high rates) before and worked fine.
elgrandiegote
Sat Sep 03, 2022 7:29 pm
yes, even with the option explicit-exit-notify 1
the server does not drop the connection and the client when reconnecting gives an error that it is already in use
pe1chl
Sat Sep 03, 2022 7:59 pm
I would not recommend mixing the use of OpenVPN with MikroTik OVPN. It is not the same thing. And it is not tracking the releases of the real thing.
It seems better to run a small container with the real OpenVPN software.
rumahnetmks
Sun Sep 04, 2022 2:39 pm
hapAC3 upgrade works fine, no noticeable error so far.
Time to test Container ^_^
Rox169
Sun Sep 04, 2022 4:03 pm
no need to quote preceding post - use "Post Reply"
im just wondering which container app will you try? Hap AC3 has limited cpu power..
gaid78
Mon Sep 05, 2022 9:11 am
marked this one device
ssbaksa
Mon Sep 05, 2022 11:06 am
I have successfully updated few CRS226-24G-2S+, and RBwAPR-2nD, 2011UiAS-2HnD, CRS326-24G-2S+ but my RB1200 doesn't "like" this update. It shows it as available but that's it. Update process can't find it on-line. I can do it manually but ...
[admin@ko4-mt-internet-1] /system package update> check-for-updates
channel: upgrade
installed-version: 6.49.6
latest-version: 7.5
status: New version is available
[admin@ko4-mt-internet-1] /system package update> install
channel: upgrade
latest-version: 7.5
status: routeros-powerpc-7.5.npk missing, use ignore-missing or disable package(s)
holvoetn
Mon Sep 05, 2022 11:58 am
This has happened in the past because of a change in naming convention and it was specifically on powerpc if my memory serves me well (why on earth they decided to do that eludes me. At least they could have foresee a shortcut-link to the old naming for these cases :rolleyes: ).
Since you move from 6.xx to 7.xx this might very well be the problem here.
Can you update manually ?
Subsequent versions should go fine then.
jbl42
Mon Sep 05, 2022 12:00 pm
Updated two RB4011 and one RB5009 in our testlab and one RB5009 at my home network 7.4.1 -> 7.5 without issues so far.
Used features: intra VLAN routing (no BGP/OSPF) with srcNAT towards WAN, bridging 5-7 VLANs with HW filtering, 30-50 FW rules, some simple queues, NTP server/client, DHCP server/client, IPsec, Wireguard
Nevon
Mon Sep 05, 2022 12:07 pm
Upgraded a CRS354-48P-4S+2Q+RM MLAG paired stack. After this weekend customer reported extreme slow network speed.
Made a return to 7.2.3 and now everything works again.
I made a ticket with Mikrotik support last week when we ran into a problem on SW02 in the MLAG stack where port 1-12 stopped working for some users. I was recommended to upgrade to 7.5. I did this this weekend and today I got the from the customer that network was slow. I tried to pinpoint the problem. Made 2-3 speedtest from servers and had full speed. But traffic internal like SQL, SMB and RDP where very slow. At some time my winbox timed out towards both switches. When I connected to the switches with mgmt on bridge it was also slow and hard to download and upload files.
Connected with cable to MGMT port and MAC adress then it was OK. Didn't have time for more so I downgraded to 7.2.3 that we had been running for some months before without problems.
Dude2048
Mon Sep 05, 2022 12:11 pm
Can you elaborate on that problem?
Rox169
Mon Sep 05, 2022 12:44 pm
Still no fix for 60 GHz devices? No info in firmware log to warn users with those devices?
Nevon
Mon Sep 05, 2022 12:58 pm
Updated my ticket.
ruwi000
Mon Sep 05, 2022 5:50 pm
how to get to :
Could address-list be related to views in DNS? Different clients getting different answers?
benlg
Mon Sep 05, 2022 5:58 pm
What about 7.4.1 ?
armandfumal
Mon Sep 05, 2022 11:25 pm
same issue CCR2216....crazy to have bug like this,..Is it me or BGP is not an important protocol to be first running correctly on V7 ?
spippan
Tue Sep 06, 2022 1:26 am
hope this gets sorted soon
have some tiks and ~4-6 bgp sessions to manage and still no correct "prefix counter"
Sob
Tue Sep 06, 2022 2:55 am
No, it adds resolved addresses to address list. AFAIK there's still no official documentation, so check this: viewtopic.php?p=952360#p952360
rumahnetmks
Tue Sep 06, 2022 8:47 am
Hi there. I will try hAP-AC3 with pihole or AdGuard. This router is just for a small home network (really small network :D).
Since from mikrotik manual help page mention about its better to have different storage for the container, hAP-AC3 i think better with its USB port (will use USB to Sata3 SSD).
Moreover I'm just a noob that try to learn :D
Ah. Later I check adguard need min 256MB RAM while pihole 512MB. Sadly hAPAC3 only 256MB RAM...
Too much if have to switch to RB5009, while AX2 dont have USB.
Will wait for AX3 (pls have USB3 :D)
ssbaksa
Tue Sep 06, 2022 9:14 am
With manual package upload and reboot it works just fine. There was no problem with version change but since this is spare/test router I didn't expect problems.
I couldn't say the same for updating main one because I am reluctant to try it for now. That one is essential and I must get permission for update/reboot.
Well, name change! Huh! Why would you do that? There should be a symlink or something like that to ease transition.
Tnx for pointing me to right direction.
ttrs
Tue Sep 06, 2022 1:13 pm
Openvpn mikrotik-to-mirkotik is still not tested before stable releases and is not working, since 7.4 viewtopic.php?t=187760#p946943
EDIT: must be verified: viewtopic.php?p=955836#p955836
PUDIS
Tue Sep 06, 2022 5:44 pm
After upgrade CCR1016 from V6.49.6 to V7.5 - IPsec NAT not working anymore!
Downgrade back to 6.49.6 ... and working again
rextended
Tue Sep 06, 2022 5:46 pm
This is too general, it may depend on how you have configured the device.
There have been many changes from 6.x to 7.x, especially in BGP and Routing,
which probably make the configuration incompatible with what you expect.
mmc
Tue Sep 06, 2022 6:11 pm
ros 7.5 stable breaks pppoe / l2tp with ip pool.
the used ip pool adresses never get released when a ppp session ends. after a while (two days) the whole pppoe server crashed with the log message 'cannot create service connection'. a downgrade to 7.4.1 fixed the problem...
kenyloveg
Tue Sep 06, 2022 6:35 pm
According the help page
https://help.mikrotik.com/docs/display/ROS/Container
/container/set 0 start-on-boot=yes
while i get bad command
johnson73
Tue Sep 06, 2022 6:49 pm
after upgrade from v6.49.6 to v7.5 on CCR1009 without problems.
I wonder why the new Ros v7 consumes so much more memory? For example, on the CCR1009 router with v.6.49.6, the ram consumption was around 740MiB at medium load
With version v7.5 ram already shows 670 MiB. What if I put this version on hAP lite which has only 32Mib total memory? Will he be able to work with this?
pe1chl
Tue Sep 06, 2022 6:51 pm
It is not advisable to install RouterOS v7 on a hAP lite or hAP mini.
marlab
Tue Sep 06, 2022 11:10 pm
Is anyone else having problems with Capsman? With 7.5 I had to give up using Capsman, as the speed with hap ac2 access points went down to 30 Mbps... :/ The same devices without Capsman are easily reaching over 250 Mps... Capsman is installed on the main router, RB4011, I use vlans, so I do not see a reason for such a drastic drop in wireless speed.
holvoetn
Wed Sep 07, 2022 1:46 am
Too many other variables which might be responsible for that speed drop instead of blaming capsman.
Best to start a separate thread and post your config so it can be inspected.
nclmrc
Wed Sep 07, 2022 9:27 am
i had a similar problem; streaming and file trasnfer in LAN stopped suddenly, i resolved downgrade to 7.4.1 all CHR, Hex POE, HAP AC, then i reinstalled 7.5 starting from CHR (no problem) then Hex POE (no problem) then HAP AC (no problem)
marlab
Wed Sep 07, 2022 10:19 am
Too many variables? Capsman ON = low speed. Capsman off and individual access points activated on hap a2 = full speed. The location of Capsman (server) does not seem to be relevant (I've tried 2 routers). When Capsman is on, the traffic seems to go via CPU on hAP (load goes up to ca. 50%). When it is off, traffic goes via vlans and CPU remains below 10%. There are no firewall/NAT/mange rules activated, no other tunnels on hAP ac2 devices.
LSan83
Wed Sep 07, 2022 10:40 am
With local forwarding activated or disabled? If you want speed you need to use local forwarding in Capsman.
rextended
Wed Sep 07, 2022 11:08 am
@marlab
@holvoetn wrote
Best to start a separate thread and post your config(s) so it can be inspected.
@LSan83: se rispondi al post sopra, per favore non quotare.
ssbaksa
Wed Sep 07, 2022 11:32 am
I have tested it and it works for me. At home (server) 2011UiAS-2HnD with 7.5 installed. At work, as a separate router (only for this test , all other traffic is routed trough other routers) RB952Ui-5ac2nD - hAP ac lite with ROS 7.5 as a client. It all works well. No disconnects observed.
Normally I use OpenVPN client on Windows 10 or in Linux Mint to connect to home office and other sites. No problems observed. And I am using this setup for at least 5 years.
own3r1138
Forum Veteran
Forum Veteran
Wed Sep 07, 2022 11:51 am
No disconnects were observed.
Key encryption renewal process which caused periodic session disconnects. as the change log clearly said. Although still, one problem exists, rarely does a client get disconnected for whatever reason But, the server shows the connection active.
marlab
Wed Sep 07, 2022 12:22 pm
Enabled of course. That's why I mentioned this problem in 7.5 thread, I've been using Capsman for a while..
holvoetn
Wed Sep 07, 2022 12:53 pm
Wifi settings the same with and without capsman ?
Same channels ?
Same width ?
Same security ?
rextended
Wed Sep 07, 2022 4:14 pm
@Znevna is right
What's new in 7.6beta6 (2022-Sep-07 12:06):
*) container - added "start-on-boot" parameter for automatic container startup;
pe1chl
Wed Sep 07, 2022 5:36 pm
It sucks that the help.mikrotik.com site does not mention version numbers or has different "views" depending on version numbers.
How is a user of stable version 7.5 supposed to know that a feature described in the online manual is not available in that version, but only in the next beta?
So either each newly added feature/command should have some standard note like "available from version 7.6" or there should be a selection at the top where you can set "see the manual as it is for 7.5" where all new entries added for later versions are not visible...
szeffancs
Thu Sep 08, 2022 9:52 am
Hy everyone!
I have a problem with Router OS 7.5 on my LTAP mini (RB912r-2ND-ltn).
My Ipsec connection dose not work while I upgrade on 7.4.1 to 7.5 OS.
The firmware type is qca9531L, current firmware is 7.5.
Anybody knows what a problem is?
I see my log where I find that massage
ipsec,error unable to get local issuer certificate(20) at depth:0 cert:(this is my remote certificate name)
thanks
own3r1138
Forum Veteran
Forum Veteran
Thu Sep 08, 2022 10:43 am
A simple google search will do more than enough.
mikrotik ipsec,error unable to get local issuer certificate(20) at depth:0 cert site=https://forum.mikrotik.com
viewtopic.php?t=162145
viewtopic.php?t=145608
Larsa
Thu Sep 08, 2022 12:11 pm
It sucks that the help.mikrotik.com site does not mention version numbers or has different "views" depending on version numbers...
Concur indeed. And since the help site is using Confluence/JIRA it should be no problem to version control the help pages if they ever should choose to do so.
szeffancs
Thu Sep 08, 2022 12:30 pm
Thanks for the nothing because there's no answer these websites to my problems! My certificates just work fine...
rextended
Thu Sep 08, 2022 12:37 pm
nice s–t answer...
own3r1138
Forum Veteran
Forum Veteran
Thu Sep 08, 2022 1:12 pm
You're welcome anyway. :)
mmc
Thu Sep 08, 2022 6:11 pm
for me ospf v3 with ipv6 multiple instances doesn't work with ros7.5 'stable'.
only the first ipv6 interface sends ospf packets, all others stay in passive by themself and just do nothing. happens only when you have multiple instances & areas.
anybody got this working?
anrich
Fri Sep 09, 2022 10:31 am
Hy everyone!
thanks
I had a feeling this might be related to ROS7.5, I'm experiencing the same issue: viewtopic.php?p=955390
Have you found a solution yet? I haven't made any progress unfortunately.
own3r1138
Forum Veteran
Forum Veteran
Fri Sep 09, 2022 10:51 am
Timti
Fri Sep 09, 2022 11:11 am
My wAP 60Gx3 AP does not work with v7.5!
When I ping my wAP 60Gx3 AP, it keeps disconnecting on Ethernet.
In the terminal I found:
mikrotik system,error,critical kernel failure in previous boot
I downgraded to 7.4 and now everything works as usual.
anrich
Fri Sep 09, 2022 11:12 am
Interesting. Are you using NordVPN? Did you load any certificates other than the Root CA certificate?
aurelmarius
Sun Sep 11, 2022 11:49 am
CCR1009 running routeros 7.5 stable, when i try to set up pimsm, router reboots with kernel panic.
Chiara
Mon Sep 12, 2022 6:11 pm
Dear Sirs,
I've noticed "secrets" have disappeared from exported .rsc configuration files, is there a way to take these back in the file?
Thanks, BR
eworm
Mon Sep 12, 2022 6:12 pm
Jotne
Mon Sep 12, 2022 7:06 pm
I can confirm that in 7.5 user password is not sown even with show-sensitive (do not remember if I have seen them)
/user> export show-sensitive
/user
add address=192.168.10.0/24 comment="system default user" disabled=yes group=full name=admin
add group=full name=demo
add address=192.168.10.50/32 comment="Use to get remote SSH information." group=full name=admin-ssh
But it does show password for ipsec key when using show-sensitive
/ip/ipsec/identity> export  show-sensitive
/ip ipsec identity
add generate-policy=port-override peer=peer1 remote-id=ignore secret=Complicated_Password
/ip ipsec identity
moskovskiy82
Mon Sep 12, 2022 8:23 pm
Is there any FAQ what to expect when switching from stable 6.49?
Dalo
Tue Sep 13, 2022 9:33 am
What about 7.4.1 ?
I had the same behavior with 7.4.1, extreme low speed over the LAN, in RB3011, and hEX POE, causing to roll back to the previous version. For the moment the most stable version for my environment is 7.3.1.
soulreaver1
Tue Sep 13, 2022 5:53 pm
Recently I've updated the following RBs. I have had only issues with updating RB1100x2 and RB1200 - needed to manually update them becouse the RouterOS was unable to download the update.
  • CCR1009-7G-1C-1S+ (3 pieces)
  • 1100x2 (3 pieces)
  • 1100Dx4 Dude Edition
  • 1200
  • 2011UiAS
  • 951G-2HnD (2 pieces)
  • 750Gr3
holvoetn
Tue Sep 13, 2022 5:57 pm
@soulreaver1:
RB1100/1200:
Coming from which version ?
There was a "hickup" for powerPC where the naming convention of the update files was changed on server-side so it could not retrieve the updates automagically anymore.
Probably that was your problem.
(I still call it neglect that no symlink was foreseen for the old naming to circumvent such issues...)
soulreaver1
Wed Sep 14, 2022 9:49 am
@holvoetn All devices were at 6.49.6 before updating to 7.5.
Chiara
Wed Sep 14, 2022 4:37 pm
RB912R-2nD upgraded from 6.49.6 to 7.5, is it standard behavior that lte1 iterface goes down every 4 hours?
lte1 link down
lte1: not registred, state: 0
lte1: registered home
lte1 link up
this haappen exactly every 4 hours: i.e.
14:34:29
10:34:29
06:34:29 and so on
Is there some scheduler that can be removed to avoid this?
nmt1900
Wed Sep 14, 2022 7:53 pm
That is interesting - has the default changed with introduction of v7, because at least as far as i remember all ipq4000 devices were defaulted to this same 716 MHz before and same is mentioned in the hardware specifications as well (yes I know that "auto" setting was there in v6 for quite some time...)?
I finally jumped on v7 bandwagon and this was the first surprise I got - and yes warning disappeared when frequency was set to "auto" and it was immediately obvious that frequency change behaviour is different than it was on v6 with "auto" setting - at least ipq4000 now jumps all over the place from 448 up to 800+ MHz. It was way more "conservative" on v6.
pothi
Thu Sep 15, 2022 4:57 am
@Chiara There is no new scheduler in RouterOS 7.5, as far as I know. Kindly create a support ticket. Support staff may guide you with troubleshooting this specific issue.
Paternot
Thu Sep 15, 2022 5:41 am
Before the CPU was running at a fixed frequency: 716MHz. This is why it's set to 716MHz after upgrade. Problem is: RoS now wants to run with "auto", and shows this complain when set to 716MHz.
rextended
Thu Sep 15, 2022 10:58 am
@pothi
@Chiara ...
Can be simply the LTE operator that do not want one user to stay linked forever...
LSan83
Thu Sep 15, 2022 11:15 am
@Chiara
With which operator you have the reset of connection?
Wind3 in Italy? They reset every connection after 4 hours, you can't avoid this.
pe1chl
Thu Sep 15, 2022 11:48 am
He wrote that he upgraded from 6.49.6 to 7.5. But he did not tell if before it was the same thing. Hopefully he watched the logging before he upgraded.
Here with T-Mobile it is normal that the connection is interrupted every 24 hours. But sometimes I see interruption every 8 hours for a while.
Probably the providers are playing with such a parameter to try to solve problems in their network, e.g. overloading of particular cells.
mkx
Thu Sep 15, 2022 2:21 pm
Mobility is taken very seriously in standardization phase of every generation of mobile technology ... so no, disconnecting clients is not necessary to move users between cells. And it doesn't work for "smart" clients who use cell lock on their devices anyway. There are a few other problems MNOs might try to solve by disconnecting clients, one is clearing up PDP/EPS contexts in their core network nodes (in the same manner as rebooting computer to "fix" memory leak), another one is making sure clients (at least most of them) don't run service off their mobile subscription plan (with its dumping price).
pe1chl
Thu Sep 15, 2022 7:34 pm
Normally the clients are behind CGNAT so running services on them does not make much sense anyway.
We use 4G backup of fixed line connection to branch routers, I have L2TP/IPsec from the branch to the central office and every day they disconnect and reconnect.
Fortunately the disconnects are done at exact 24h intervals (normally) and as I have a secheduled job to apply updates during the night, the disconnects also happen during the night.
rushlife
Sun Sep 18, 2022 9:31 am
yesterday first problem with 7.5stable.
On RBLHGG-60ad units, boot error, kernel panic.
Reverting back to 7.4.1 solved that problem.
Be careful with upgrade on these units guys.
HasanAlawlaki
Mon Sep 19, 2022 12:11 pm
No session time left
No limit bytes total
How to fix that
Rox169
Mon Sep 19, 2022 1:03 pm
Be carefull on 7.4.1 I had problem on ROS 7.4 few days ago....I upgraded especially because this fix *) w60g - improved interface initialization after being inactive for a while;
But on WAP60Ghz happend exactly what should this fix fixed.
ArShuRaZ
Mon Sep 19, 2022 4:35 pm
Is this version (7.5) already fixed ping issue (Cannot ping to everywhere after run for a while)?
eworm
Mon Sep 19, 2022 4:36 pm
Yes.
ArShuRaZ
Mon Sep 19, 2022 4:45 pm
thank you :)
prawira
Tue Sep 20, 2022 8:16 am
the recursive work, but no recursive via words on /ip route menu
the display of routing table sometime does not represent the current situation after the interface changed.
the table routing have to close and open again to see the correct situation
pe1chl
Tue Sep 20, 2022 11:10 am
You may need to enable an extra column in the display to see that.
rb9999
Tue Sep 20, 2022 10:21 pm
Issues upgrading RB951-2n frmo 7.1.5 to 7.5.0... nothing fancy, some vlans, some bridged ports, it seems its reverts to 7.1.5 and gets unresponsive.
prawira
Wed Sep 21, 2022 5:00 am
dear pe1chl,
normally we can see recursive via both on gui and cli. i can not see it on v7.x; check on target-scope>30
also, no-more unreachable (U) and or prohibit (P) options for routing, thus no (B) flag shown on blackhole entries.
add check-gateway=ping disabled=no distance=1 dst-address=10.1.2.0/30 gateway=10.1.1.2
add check-gateway=ping disabled=no distance=1 dst-address=10.1.3.0/30 gateway=10.1.2.2 target-scope=31
add check-gateway=ping disabled=no distance=1 dst-address=192.168.2.0/29 gateway=10.1.1.2
add check-gateway=ping disabled=no distance=1 dst-address=192.168.3.0/29 gateway=10.1.2.2 target-scope=31
add check-gateway=ping disabled=no distance=1 dst-address=192.168.4.0/29 gateway=10.1.3.2 target-scope=32
add disabled=no distance=2 dst-address=10.1.2.0/30 gateway=10.1.4.1
add disabled=no distance=2 dst-address=10.1.3.0/30 gateway=10.1.4.1
add disabled=no distance=2 dst-address=192.168.2.0/29 gateway=10.1.4.1
add disabled=no distance=2 dst-address=192.168.3.0/29 gateway=10.1.4.1
add disabled=no distance=2 dst-address=192.168.4.0/29 gateway=10.1.4.1
[admin@R1] /ip/route> print detail
Flags: D - dynamic; X - disabled, I - inactive, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, y - copy; H - hw-offloaded; + - ecmp
   DAd   dst-address=0.0.0.0/0 routing-table=main pref-src="" gateway=10.31.31.1 immediate-gw=10.31.31.1%ether1 distance=1 scope=30 target-scope=10 vrf-interface=ether1 suppress-hw-offload=no
   DAc   dst-address=10.1.1.0/30 routing-table=main gateway=ether3 immediate-gw=ether3 distance=0 scope=10 suppress-hw-offload=no local-address=10.1.1.1%ether3
 0   s   dst-address=10.1.2.0/30 routing-table=main pref-src="" gateway=10.1.4.1 immediate-gw=10.1.4.1%ether4 distance=2 scope=30 target-scope=10 suppress-hw-offload=no
 1  As   dst-address=10.1.2.0/30 routing-table=main pref-src="" gateway=10.1.1.2 immediate-gw=10.1.1.2%ether3 check-gateway=ping distance=1 scope=30 target-scope=10 suppress-hw-offload=no
 2   s   dst-address=10.1.3.0/30 routing-table=main pref-src="" gateway=10.1.4.1 immediate-gw=10.1.4.1%ether4 distance=2 scope=30 target-scope=10 suppress-hw-offload=no
 3  As   dst-address=10.1.3.0/30 routing-table=main pref-src="" gateway=10.1.2.2 immediate-gw=10.1.1.2%ether3 check-gateway=ping distance=1 scope=30 target-scope=31 suppress-hw-offload=no
   DAc   dst-address=10.1.4.0/30 routing-table=main gateway=ether4 immediate-gw=ether4 distance=0 scope=10 suppress-hw-offload=no local-address=10.1.4.2%ether4
   DAc   dst-address=10.31.31.0/24 routing-table=main gateway=ether1 immediate-gw=ether1 distance=0 scope=10 suppress-hw-offload=no local-address=10.31.31.230%ether1
   DAc   dst-address=192.168.1.0/29 routing-table=main gateway=ether2 immediate-gw=ether2 distance=0 scope=10 suppress-hw-offload=no local-address=192.168.1.1%ether2
 4   s   dst-address=192.168.2.0/29 routing-table=main pref-src="" gateway=10.1.4.1 immediate-gw=10.1.4.1%ether4 distance=2 scope=30 target-scope=10 suppress-hw-offload=no
 5  As   dst-address=192.168.2.0/29 routing-table=main pref-src="" gateway=10.1.1.2 immediate-gw=10.1.1.2%ether3 check-gateway=ping distance=1 scope=30 target-scope=10 suppress-hw-offload=no
 6   s   dst-address=192.168.3.0/29 routing-table=main pref-src="" gateway=10.1.4.1 immediate-gw=10.1.4.1%ether4 distance=2 scope=30 target-scope=10 suppress-hw-offload=no
 7  As   dst-address=192.168.3.0/29 routing-table=main pref-src="" gateway=10.1.2.2 immediate-gw=10.1.1.2%ether3 check-gateway=ping distance=1 scope=30 target-scope=31 suppress-hw-offload=no
 8   s   dst-address=192.168.4.0/29 routing-table=main pref-src="" gateway=10.1.4.1 immediate-gw=10.1.4.1%ether4 distance=2 scope=30 target-scope=10 suppress-hw-offload=no
 9  As   dst-address=192.168.4.0/29 routing-table=main pref-src="" gateway=10.1.3.2 immediate-gw=10.1.1.2%ether3 check-gateway=ping distance=1 scope=30 target-scope=32 suppress-hw-offload=no
Znevna
Wed Sep 21, 2022 7:10 am
Dear @prawira (trainer), I suggest to read the documentation provided that brings some answers to some of the things you've mentioned.
Moving from ROSv6 to v7 with examples
v7 introduces a new menu /routing route, which shows all address family routes as well as all filtered routes with all possible route attributes. /ip route and /ipv6 route menus are used to add static routes and for simplicity show only basic route attributes.
For more in-depth information on routing see this article (IP Routing).
pe1chl
Wed Sep 21, 2022 12:20 pm
That is all correct. There are no unreachable or prohibited routes anymore, and when you had them they are converted to blackhole.
And blackhole is no longer a flag. There is a separate column "Blackhole" with a yes/no value in it.
As Znevna already wrote, a lot of things have changed in the routing between v6 and v7 and you will have to learn about it. These are not bugs.
anoka
Mon Sep 26, 2022 1:46 am
Hi!
When I use CAPsMAN for local WLAN interface, then it's displayed as disabled port, but running.
rextended
Mon Sep 26, 2022 1:50 am
@anoka
Do you talk to others by images?
Did you see that there are two red writing above the wireless interface?
Maybe try reading them.
For help open another topic and do not continue here.
holvoetn
Tue Sep 27, 2022 12:34 pm
Upgraded cAP AC XL from 6.49.6 using Winbox.
After reboot, device became unresponsive.
Netinstall 7.5 doesn't seem to work (linux). It requests the package, it starts and then it starts all over again after some time.
Same with 6.49.6 and latest 7.6beta.
Sweet ... I've got a couple of other XLs, I guess I keep them on 6.49.6 for now.
SUP-93559 created.
EDIT: got a first reply, this is going to be fun if the response I get is to use netinstall ...
holvoetn
Tue Sep 27, 2022 2:02 pm
Success !
Powered everything down incl laptop with Linux.
Went for lunch
Powered everything up again and used netinstall.
Instead of nothing after the recognition of the device, I immediatelly saw a line "formatting". And then I knew it was going to work !
cAP XL is running 7.6beta8 now.
But something ODD: it remembered the user passwd (I did change it before the upgrade, one of the first things I do on a new device next to activating ROMON).
Also on wireless I changed (before upgrade) the settings for country and installation. Those were remembered as well.
Ergo: netinstall did not format that device completely...
mkx
Tue Sep 27, 2022 4:16 pm
User manual, the linux section, describing command line options for netinstall executable, mentions
-r resets the configuration upon reinstallation procedure, optional
So by default, linux netinstall keeps configuration.
Znevna
Tue Sep 27, 2022 4:19 pm
Don't use netinstall on an empty stomach.
mkx
Tue Sep 27, 2022 4:24 pm
Before using netinstall, have a light meal and read some literature ;-)
holvoetn
Tue Sep 27, 2022 4:26 pm
@mkx: hmmm ... missed that. Good to know !
But then it is inconsistent with the Windows version since there you explicitely need to tick the option to keep user config.
Confusing ...
@Znevna: seems to be a solution for quite a lot of things.
mkx
Tue Sep 27, 2022 6:11 pm
But then it is inconsistent with the Windows version ...
The inconsistence continues beyond that ... UI is completely different.
I'm not trying to argue about what you're saying, what I'm trying to say is that both versions (linux and windows), although having same name and basically doing same job, are completely different beasts. Additionally, CLI doesn't offer any clues about available toggles and switches, so reading manual is pretty smart thing to do (which I usually try to avoid myself as well, making me sound a smart ass right now).
gotsprings
Sun Oct 02, 2022 2:56 am
Took a factory Fresh RB3011 and Updated it to 7.5.
Opening terminal would cause the CPU to shoot up and terminal not to work.
Downgraded to 7.4.1 and saw a warning that stated there had been a reboot for kernel failure.
Will check the router in a few days and see if its stable. It was a had to replace a unit that ate some voltage during a storm.
/log print
 18:50:00 system,error,critical router was rebooted without proper shutdown, pro
bably kernel failure
 18:50:01 system,error,critical kernel failure in previous boot
Znevna
Sun Oct 02, 2022 11:14 am
I'd stay with v6 on that one.
gotsprings
Sun Oct 02, 2022 11:17 am
Can't.
System requires Wireguard.
Should be using Zerotier... Which also requires 7.x + extra packages.
holvoetn
Sun Oct 02, 2022 12:04 pm
Regular update or netinstall ?
I'd try netinstall...
gotsprings
Sun Oct 02, 2022 3:20 pm
moderator note: why do you quote whole preceding post? Use "Post Reply" instead.
/System package update install
Now hold on a second... I can take a "default the unit after update"... But there had better be a clear warning that is gonna be needed BEFORE I CAN EVEN DOWNLOAD THE UPDATE.
If we need to start doing netinstalls before sending them out in the field... I wanna see a big f--king warning on the top of EVERYTHING from the Mikrotik domain.
holvoetn
Sun Oct 02, 2022 3:52 pm
There will/might come a point when moving from ROS6 to ROS7 you may see erratic and inexplicable behavior.
At that moment it is advised to perform a pristine clean install to clear any inconsistencies (from ROS7 point of view) left-over from previous version.
A.k.a. Netinstall.
mozerd
Forum Veteran
Forum Veteran
Sun Oct 02, 2022 4:52 pm
@gotsprings ....
My speculation is that over the last 2 years many personnel changes have take place in the Tik developer domain so the expertise needed to get 7.x to where it should be will take much more time ....
With Tailscale [WireGuard management system] you can have your Cake and Eat it and performance is wonderful. Mastering Tailscale is no big deal exploiting Tailscale Subnet routers and traffic relay nodes provides a great deal of power in your hands.
Znevna
Sun Oct 02, 2022 5:27 pm
Talk about Tailscale has no place in this topic.
socs
Tue Oct 04, 2022 6:20 pm
I'm unable to pull containers when using custom registry-url that is not "registry-1.docker.io". Here's the log,
14:53:18 container,info,debug importing remote image: routeros-container/routeros-container, tag: latest
14:53:18 system,info item added by admin
14:53:18 container,info,debug failed to parse www-auth
14:53:18 container,info,debug was unable to import, container 4558db4a-cc1f-4f92-825c-c1c1f94fbb86
This is from a self-hosted registry but the result are the same for other official registries, eg gcr.io.
edit: fixed in 7.6rc1
SiB
Thu Oct 06, 2022 1:27 am
ros6 show one ping as one row and I see the TX RX in one entry, as send and proper back package in one session.
ros7 show me two entry/row, please fix this in Torch
pe1chl
Thu Oct 06, 2022 10:21 am
This is because your DSCP is different between the two directions, and you selected a matching with DSCP (even when it is "any").
SiB
Thu Oct 06, 2022 4:38 pm
pe1chl write:
Thanks, it's true in this case.
This is default settings in ros7, I not enabled that by myself.
True, after disable this selector the entry is one row, like old ros6. Thanks !.
anav
Thu Oct 06, 2022 4:42 pm
Hi mozerd, can you confirm its easy to implement 2FA with tailscale, vice wireguard which seems to be a bit of a challenge.
mozerd
Forum Veteran
Forum Veteran
Thu Oct 06, 2022 6:11 pm
Greetings anav
When you establish an account with Tailscale you are provided with a number of options including the most popular 2FA identity provider like google, Microsoft
Tailscale relies on existing identity provider to authenticate users. Any authentication settings from your identity provider are automatically used by Tailscale, including MFA
For Example I use google .... many people I know like to use Microsoft etc. So for example once you have a Gmail account and enabled 2FA on it --- that will now be used by Tailscale as the screen following depicts. Its very easy :-)
anav
Re: v7.5 [stable] is released!
Thu Oct 06, 2022 6:15 pm
Now that would a great future update for MT to put on their wireguard module.... a redirect to 2FA after connecting...............
Or I suppose a work around might be to the radius server on the MT where a user has to put in another password?"????
rb9999
Fri Oct 07, 2022 10:13 am
Did anyone notice that arp ping still doesn't work? Guess this is a major downside if gateway doesn't respond to ICMP echo request and you have check-gateway set to arp...
[admin@Mikrotik] > tool/ping arp-ping=yes interface=bridge-lan count=5 192.168.0.1
SEQ HOST SIZE TTL TIME STATUS
0 ping failed
1 ping failed
2 ping failed
3 ping failed
4 ping failed
sent=5 received=0 packet-loss=100%
marcocamza
Fri Oct 07, 2022 10:34 am
Hi all
Not sure if what I'm seeing is correct but I thought Ros7 utilizes all cores more efficiently.
The attached image shows only 1 CPU being used on a 2216 that's only doing BGP and nothing else.
usmank
Sat Oct 08, 2022 4:13 am
How to fix that
Yes... I have the same problem with this, is there any solution?
pe1chl
Sat Oct 08, 2022 12:58 pm
It is not like all activity w.r.t. BGP is now spread over all cores. That would require a multithreaded implementation of the BGP protocol, which is apparently hard to do.
However, the handling has been split in some different processes, e.g. for filtering and route table maintenance, and there is a separate process for each peer.
When you have only a single peer, that probably does not bring you much.
MarcinPLPOZ
Mon Oct 10, 2022 1:13 pm
After updating to 7.5, when I want to add a new entry to QoS (simple), I noticed that it causes an interruption of the internet connection for the given subnet for which I am setting it up. Someone had that too? What is the answer?
I would like to add that the previously added entries work, and the new ones do not.
winap
Mon Oct 10, 2022 11:43 pm
From which version?
pe1chl
Tue Oct 11, 2022 12:30 am
Also, please show a /queue/simple/export made both before and after you have added the new entry.
MarcinPLPOZ
Wed Oct 12, 2022 10:58 am
From which version?
I updated one by one as "stable" appeared, ie from the previous one, ie 7.4.1. I admit, I don't know if the problem has arisen now. Maybe it was already during an earlier upgrade. I am unable to establish this.
MarcinPLPOZ
Wed Oct 12, 2022 12:49 pm
before
/queue simple
add max-limit=50M/50M name=limit-vlan6 target=VLAN_6_LAN
add max-limit=15M/15M name=limit-guest target=VLAN_8_Guest
after
/queue simple
add max-limit=70/70 name=limit-vlan4 target=VLAN_4_VMs_admin
The last entry does not work (VLAN_4_VMs_admin), and even cuts the Internet for hosts in that subnet.
holvoetn
Wed Oct 12, 2022 1:17 pm
70 BYTES is not a lot.
Should be 70M/70M, no ?
mkx
Thu Oct 13, 2022 8:54 am
Up to latest v6 releases the principle was that every release (e.g. 6.x) was kind of a feature freeze. Then the minor releases (e.g. 6.x.y) were more or less bug fixes. This kind of release cycle is not prominent in v7 yet as the whole v7 is still largely work in progress. I expect that with some 7.10 things will slowly converge and we'll see more "bug fix only" releases from that point forward.
And I really don't see need for major version inflation (e.g. v8 after 7.7). We've had v6 around pretty long time (I'm not around long enough to remember v5) while there were quite a few major changes in the v6 series (e.g. brand new wireless driver which is proprietary now, bridge with VLAN functionality, etc.).
MarcinPLPOZ
Thu Oct 13, 2022 10:31 am
OMG, you are right, and I thought I tried it in the 70M / 70M configuration before and it didn't work ... ehhh ... well, it actually works.
Thanks @mkx
MarcinPLPOZ
Thu Oct 13, 2022 10:33 am
Thanks for explanation. Regards :)
pe1chl
Thu Oct 13, 2022 11:42 am
I'm still hoping that someone at MikroTik has a list of features of v6 that are no longer working in v7, and assigns some priority to fixing those or putting up a list of features in the documentation that "are gone and will not come back".
stylsoft
Sun Oct 16, 2022 9:04 pm
Upgrade from 7.3.1 to 7.5. CCR2004-1G12S+XS and RB4011 many reboots after 2-12h. Downgrade back to 7.3.1
lechat75
Mon Oct 17, 2022 12:52 pm
I am using the CHR Version.
Weired things with VLAN and "user service tag" for 802.1ad.
It works fine - I mean mac learning.
UDP and ICMP are working fine too but TCP does not work.
I am not able to :
- telnet between two CHR
- ssh between two CHR
- set up an BGP session
This issue does not exist with 6.48.6
HTH
ahmedelbarbary
Mon Oct 17, 2022 10:47 pm
Hello mikrotik team
I can't use this rule in new terminal on 7.5
ip firewall connection remove [find]
Could you check it?
gotsprings
Mon Oct 17, 2022 11:20 pm
CRS328-24P-4S+
Ports 17-24 don't have a tab for POE in winbox.
But port 22 is powering my WAP right now.
emils
Forum Veteran
Forum Veteran
Tue Oct 18, 2022 11:49 am
New version v7.6 has been released!
viewtopic.php?t=190072
Users browsing this forum: No registered users and 7 guests
