jlopez
[OSPF] MikroTik and Huawei neighbor establishment issues
Wed Aug 31, 2022 5:30 pm
Dear MikroTik community.
I have a MikrotTik CCR and Huawei router trying to deploy an ospf scenario:
This is MikroTik ospf configuration:
/interface vlan
add interface=combo1 name=OSPF_HUAWEI vlan-id=30
add address=192.168.30.2/30 interface=OSPF_HUAWEI network=192.168.30.0
/routing ospf instance
set [ find default=yes ] name=OSPF redistribute-connected=as-type-1 router-id=192.168.30.2
/routing ospf interface
add instance-id=1 interface=OSPF_HUAWEI
/routing ospf network
add area=backbone network=192.168.30.0/30
This is Huawei configuration (ospf between two Huawei routers is successful):
ospf 1 router-id 192.168.30.1
import-route direct
opaque-capability enable
area 0.0.0.0
network 192.168.30.0 0.0.0.3
interface GigabitEthernet0/2/5.30
vlan-type dot1q 30
description OSPF_MIKROTIK
ip address 192.168.30.1 255.255.255.252
ospf cost 100
ospf enable 1 area 0.0.0.0
Both equipments have direct connectivity and ping is successful.
Thanks for your attention andl help.
Best regards.
StubArea51
Trainer
Trainer
Re: [OSPF] MikroTik and Huawei neighbor establishment issues
Wed Sep 07, 2022 4:43 pm
Verify MTU, timers and network type all match
I would also disable opaque LSA capability on the Huawei router until you have the neighbor working.
jlopez
Tue Sep 20, 2022 1:32 am
Thanks for your answer.
All parameters are the same in both routers, but issue remains.
Best regards.
Users browsing this forum: No registered users and 10 guests
