Hi all,
I have several trunk type point-to-point links between two switches made with RB91x bridges (bridge-station bridge) and ROS 7.5
I am using a qos configuration identical to the script of mducharme's FastTrack-Friendly Queues post;
Everything works fine except fasttrack, I can see that some tcp or udp connections are well fasttracked in the "Connections" tab, but the counter for the "dummy" rule remains at 0.
It's the same in IP/Settings, fastrack is active but the counters are at 0.
A priori the material is fasttrack compatible according to the ROS documentation
I've tested everything after having scoured the forum a lot looking for similar cases, tested several version of ROS 7, I can't find anything conclusive.
Has anyone with RB9xx type cards ever managed to get fasttrack to work?
thanks in advance for your help
