eldoncito2019
IP HOTSPOT HOST
Thu Sep 01, 2022 7:59 pm
Friend, if I put this:
:put  [/ip hotspot host print as value]
I only want to print the "MAC ADDRESS", how do I do it?
EL DONCITO.
rextended
Re: IP HOTSPOT HOST
Thu Sep 01, 2022 10:49 pm
Do you want to make an effort to write in more detail?
As usually, is not understandable.
Provide EXAMPLE and a BETTER DESCRIPTION
rextended
Re: IP HOTSPOT HOST
Thu Sep 01, 2022 10:52 pm
/ip hotspot host; :foreach item in=[find] do={:put [get $item mac-address]}
eldoncito2019
Re: IP HOTSPOT HOST
Fri Sep 02, 2022 12:02 am
Thanks friend REX; How do I copy the mac address in IP BINDING?
EL DONCITO.
rextended
Re: IP HOTSPOT HOST  [SOLVED]
Fri Sep 02, 2022 12:08 pm
First EXPLAIN what you want to achieve in the end, without doing it one piece at a time.
/ip hotspot
:foreach item in=[host find] do={
    :local mac [host get $item mac-address]
    :local svr [host get $item server]
    ip-binding
    :if ([:len [find where mac-address=$mac and server=$svr]] = 0) do={
        add mac-address=$mac server=$svr type=blocked disabled=yes
Users browsing this forum: GoogleOther [Bot] and 43 guests
