willosof
Evening out the CPU workload on the cores
Thu Sep 01, 2022 8:56 pm
Hi
I have a production system running with loads of inbound L2TP/SSTP/PPTP connections, with not THAT many packets/sec or bytes/sec in total, but one of my cores is between 50-90% utilization at all times. Any dirty tricks I can apply to better utilize the idle cores?
(yes, I know the version is old.)
Screenshot at:
https://www.dropbox.com/s/g6d48sahqpx13 ... 2.png?dl=0
Thanks!
holvoetn
Re: Evening out the CPU workload on the cores
Thu Sep 01, 2022 9:45 pm
I could be wrong but all those VPNs are handled by 1 core.
Can you consider to use Wireguard for some or most of those connections ? Requires ROS7, though ... may not be possible for all clients connecting to use that protocol, I am aware.
So possible options:
- change VPN protocol (all or partly)
- reduce number of connections
- change HW
Others might chime in with better suggestions.
Znevna
Fri Sep 02, 2022 3:52 am
A profile view would've helped to see what that core is busy with.
Users browsing this forum: 5h4k4, Dulcow, Experimentator, ichyre and 60 guests
