yeapYou have installed container package, first?
[admin@CHR] > /container/add remote-image=pihole/pihole:latest interface=veth1 root-dir=pihole mounts=dnsmasq_pihole,etc_pi
hole envlist=pihole_envs
failure: not allowed by device-mode
[admin@CHR] > system/device-mode/print
mode: enterprise
+1pls tell me how to enable CHR\x86 in system/device-mode/container?
/system/device-mode/updatecontainer=yes asks for a manual poweroff or reset - turn off vps via isp manager there is not working
nopeWhen you do any option, are you see "router was rebooted without proper shutdown" error at first line at log when routeros come back?
I just tested with latest VirtualBox and it works fine using the "reset" in vitualbox with the CHR 7.5 imagesSame thing to me when i tried it on VirtualBox, can not update the device-mode.
I also thought that from the management console, only a warm restart. I created a ticket with the provider and they answered me in technical support, "stop button in the console executes the virsh shutdown command"You aren't doing anything wrong. Probably when you hit stop or restart isp manager notify routeros and do it graceful reboot/shutdown.
No matter what i did, container permission given only when i force vm to stop like power off and on like hardware. That's why i ask if you see that error/information at first place.
Maybe mikrotik dev's give an exception for CHR instances at later versions since we don't have button and not everybody can hard stop vm because of permissions or incompatibility of software. =/
Anyway if i find easy way to do it, let this thread aware.
virsh destroy
/system/device-mode/update container=yes
Unfortunately it doesn't work for my vps provider...I asked the technical support of my vps provider to doCode: Select allvirsh destroy
/system/device-mode/print
mode: enterprise
container: yes
I just love the idea. AWS first sends the ACPI shutdown, and in few minutes, if the instance is still up will cold-stop it. And idea presumably is to make the machine "swallow" ACPI command sending that immediately after start.On AWS, after install container:
aws ec2 start-instances --instance-ids i-???
aws ec2 stop-instances --force --instance-ids i-???
I can not find any information about that only push button works, but not power cycle.
I am struggling with the same issue here. AWS support have advised that a "dirty shutdown" is not possible. Even using the force option listed in here.I just love the idea. AWS first sends the ACPI shutdown, and in few minutes, if the instance is still up will cold-stop it. And idea presumably is to make the machine "swallow" ACPI command sending that immediately after start.On AWS, after install container:
Unfortunately, I couldn't replicate this on my setup. And I'm doing that just a month later so I doubt AWS changed something.
I was testing on t2.micro. Used the AWS CloudShell to minimize the lag. I also tried to add arbitrary sleeps between start and stop, tried with and without "--force" -- it just shows "Stopping" for 5-10 seconds and stops, without giving me a chance to input anything to terminal.
edv4ld0, could you share more detail how you did that?
