knowledgemonster
EdgeMAX vpn to Mikrotik lan device cannot ping
Fri Sep 02, 2022 6:19 pm
I have an EdgeRouter X v2.0.6 and it is the L2TP+IPSec server.
I have Mikrotik RB951Ui-2HnD with v7.5 on it as the client.
VPN connection is established between the 2 routers
From the mikrotik i can ping the lan device on the EdgeRouter.
From the lan on the mikrotik side i cannot ping the lan device on the EdgeRouter.
Mikrotik lan is 192.168.88.0/24
Edge lan is 192.168.0.0/24
VPN ip assigned to client is 192.168.100.230
Where do i start looking?
Here is the script for mt:
# sep/02/2022 11:31:22 by RouterOS 7.5
# software id = E7I4-E2AN
# model = 951Ui-2HnD
# serial number = 5582050204DB
add admin-mac=E4:8D:8C:83:3A:4B auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-833A4F wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add address-pool=default-dhcp interface=bridge name=defconf
/interface l2tp-client
add connect-to=10.0.0.34 name=l2tp-wt profile=default use-ipsec=yes \
    user=someuser
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add disabled=no dst-address=192.168.0.1/24 gateway=l2tp-wt routing-table=\
    main suppress-hw-offload=no
/system clock
set time-zone-name=America/Toronto
/tool mac-server
/tool mac-server mac-winbox
If i setup the vpn on the windows 10 computer then i can access lan device edgerouter no problem.
knowledgemonster
Re: EdgeMAX vpn to Mikrotik lan device cannot ping
Wed Sep 07, 2022 2:39 pm
Maybe someone can throw me a bone here:
Mikrotik side lan device can ping edge side lan device with this masquerade in the mikrotik:
masquerade
chain=srcnat action=masquerade src-address=192.168.88.0/24 log=no
log-prefix="" ipsec-policy=out,none
But it does not work with the default masquerade:
masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no
Users browsing this forum: andreo, Bing [Bot], jhbarrantes, sebus46 and 76 guests
