sstsac
hAP ac3 wifi not working after hard reset
Sun Sep 04, 2022 11:50 am
I bought an hAP ac3 router a week ago, everything was working fine. (Updated to the newest stable version.)
I made a configuration mistake, so I hardreset the device. After it, I can not see the default wifi networks from my laptop/mobile.
And the wifi led remains dark. I think the led is OK, because at powering on, it flashes for a moment when the others also...
I tried to reset it several times, but no luck.
Only the blue led is on, and can not discover the default wifi networks...
Does anyone have a similar issue?
Is it possible to get into the device setup using LAN cable?
Or make a harder reset or something :)
Or is it a hardware issue?
Thanks in advance!
holvoetn
Re: hAP ac3 wifi not working after hard reset
Sun Sep 04, 2022 1:25 pm
Which version of routeros are you using ?
It should be possible to connect to any ethernet port except 1. Normally the device should appear in Winbox.
If not: maybe best to netinstall to 7.5 (if you need ros7 features like wifiwave2) or 6.49.6.
sstsac
Sun Sep 04, 2022 2:24 pm
Thank you for your fast response.
I cant remember the version.
I updated it in winbox to the newest stable version 1 week ago.
I will try via ethernet connection shortly, then come back with the result...
Ovic
Re: hAP ac3 wifi not working after hard reset  [SOLVED]
Sun Sep 04, 2022 3:58 pm
If the router is reseted to default, the wifi interfaces are disabled. So you must connect via cable to get them enabled again.
sstsac
Sun Sep 04, 2022 11:58 pm
Thanks! That was the key... I could log on via cable, then I had to restore the default configuration, and then the (wifi) light came back. ;) and I could reconfigure the device.
Thank you again!
Users browsing this forum: nickcarr and 24 guests
