earanaus
Forwarded device lagging
Mon Sep 05, 2022 10:11 am
I have MikroTik RB2011iL-RM and two external IP on ISP.
First external IP is passthought directly via port 2 to next router, here is all ok.
Secondary external IP is set on router. Also I create rule that by secondary IP via 8000 port would be route redirecting to internal IP 192.168.88.XX which have manually set on my cameras device. (Also this device is connected to 5th gygabyte port).
Forwarding is working correct, I can access my cameras device from external via described port, I can monitor my cameras online without problems. BUT if I want playback my videos, then my cameras very often disconnecting and need connect again to playback list. This problem appears just then, when I installed this new mikrotik router, with previous router it worked stable.
Question, is any limitations on router to limit route via forwarding? what reasons could cause such problems?
Users browsing this forum: No registered users and 10 guests
