imperia
Random wifi client disconnects
Mon Sep 05, 2022 8:48 pm
I am having problem for a long time.
My wifi clients randomly disconnect with following message in log:
18:36:37 wireless,debug wlan1: xx:xx:xx:81:88:DF attempts to associate
18:36:37 wireless,debug wlan1: xx:xx:xx:81:88:DF not in local ACL, by default accept
18:36:37 wireless,info xx:xx:xx:81:88:DF@wlan1: connected, signal strength -83
18:37:24 wireless,info xx:xx:xx:81:88:DF@wlan1: disconnected, extensive data loss, signal strength -83
18:37:43 wireless,debug wlan1: xx:xx:xx:81:88:DF attempts to associate
18:37:43 wireless,debug wlan1: xx:xx:xx:81:88:DF not in local ACL, by default accept
18:37:43 wireless,info xx:xx:xx:81:88:DF@wlan1: connected, signal strength -86
The apartment is very small. There is maximum one wall, but the problem occurs even when I am 2 meters away from the router without walls between us.
Its happening on both bands 2.4ghz and 5ghz.
My device is hap ac with latest firmware 7.5.
I am posting my wifi configuration. If needed I will post more.
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=no \
    eap-methods="" group-ciphers=aes-ccm group-key-update=5m interim-update=\
    0s management-protection=disabled mode=dynamic-keys mschapv2-username="" \
    name=default radius-called-format=mac:ssid radius-eap-accounting=no \
    radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=\
    disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-sta-private-algo=none static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=\
    no-certificates unicast-ciphers=aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
    no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
    3 area="" arp=enabled arp-timeout=auto band=2ghz-g/n basic-rates-a/g=\
    6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz \
    compression=no country=no_country_set default-ap-tx-limit=0 \
    default-authentication=yes default-client-tx-limit=0 default-forwarding=\
    yes disable-running-check=no disabled=no disconnect-timeout=3s distance=\
    indoors frame-lifetime=0 frequency=2412 frequency-mode=superchannel \
    frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
    s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
    cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
    3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 installation=any \
    interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 \
    mac-address=xx:xx:xx:51:4C:CC max-station-count=2007 mode=ap-bridge mtu=\
    1500 multicast-buffering=enabled multicast-helper=default name=wlan1 \
    noise-floor-threshold=default nv2-cell-radius=30 nv2-downlink-ratio=50 \
    nv2-mode=dynamic-downlink nv2-noise-floor-offset=default nv2-qos=default \
    nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" \
    on-fail-retry-time=100ms preamble-mode=both radio-name=xxxxxx514CCC \
    rate-selection=advanced rate-set=default rx-chains=0,1,2 scan-list=\
    default secondary-frequency="" security-profile=default \
    skip-dfs-channels=all ssid=iMPERiA station-bridge-clone-mac=\
    00:00:00:00:00:00 station-roaming=enabled supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1,2 \
    tx-power-mode=default update-stats-interval=disabled vlan-id=1 vlan-mode=\
    no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
    wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 \
    wmm-support=disabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=\
    3 area="" arp=enabled arp-timeout=auto band=5ghz-a/n/ac basic-rates-a/g=\
    6Mbps bridge-mode=enabled channel-width=20/40/80mhz-XXXX compression=no \
    country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes disable-running-check=no \
    disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0 \
    frequency=5200 frequency-mode=superchannel frequency-offset=0 \
    mac-address=xx:xx:xx:51:4C:CB max-station-count=2007 mode=ap-bridge mtu=\
    1500 multicast-buffering=enabled multicast-helper=default name=wlan2 \
    nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink \
    nv2-qos=default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret=\
    "" on-fail-retry-time=100ms preamble-mode=both radio-name=xxxxxx514CCB \
    skip-dfs-channels=all ssid=iMPERiA-5GHz station-bridge-clone-mac=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2 \
    tx-chains=0,1,2 tx-power-mode=default update-stats-interval=disabled \
    vht-basic-mcs=mcs0-7 vht-supported-mcs=mcs0-9,mcs0-9,mcs0-9 vlan-id=1 \
    vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none \
    wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
    wireless-protocol=802.11 wmm-support=disabled wps-mode=disabled
mkx
Re: Random wifi client disconnects
Mon Sep 05, 2022 9:30 pm
Signal strength indicated at disconnect (-83dBm and -86dBm) is quite low, no wonder device disconnects.
The problem when debugging signal strength problems is that one only sees one part of story on any single device. In this case AP sees received signal strength of client, but doesn't know how client receives AP's signal. Level of signal is largely affected by transmit power and client devices are often weaker than AP. The other thing largely affecting both level of transmited signal and received signal is antenna and connections. If antenna is somehow damaged or if connection between antenna and Tx/Rx circuitry is bad, signal in both ways will suffer.
If your wireless clients work fine when connected to other APs, this indicates problem with your AP. It's hard to guess what kind of problem that might be. hAP ac features triple-chain radios for both 2.4GHz and 5GHz bands with separate antennae dedicated to each frequency band. This kind of setup is not likely to develop antenna and connection problems on both bands at the same time. Since both radios are separate (2.4GHz radio is part of SiC, 5GHz radio is separate chip connected to SoC using PCIe line), it's unlikely that silicon failure would cause both radios behave subpar at the same time.
Users browsing this forum: GoogleOther [Bot], TeWe and 80 guests
