This switch is running on top of a server rack for almost one year now. It's used just as a dumb switch, it was bought for the dual power supply. It's configured as it came from the factory, except that a password was set. Everything worked fine since two days ago, when in the middle of the day it just stopped switching. The LEDs blinked just fine, but nothing worked. I've tried switching the uplink port, nothing. Tried pinging the switch, nothing. After a reset (by removing the power) it started working again. A few hours later, in the middle of the night it happened again.
Since it's a production environment, I replaced it with an old D-Link and took it to my office hoping it would get stuck again (this time with logs enabled) but now it just works. I have less computers connected to it than it had servers in the datacenter, but unfortunately I don't have the same quantity of devices.
The switch is running ROS 6.49, I have doubts upgrading it to ROS 7.5 (I'm also having issues with that two, on the routers) until I find out what was causing the issue, to have a confirmation that newer firmware fixes it. Also, I am afraid of putting it back in the datacenter, because the downtime was no fun and took a while.
Any suggestion or help would be appreciated!
Thanks!
