mhaluska
Switch: block STP on one port in RouterOS v7
Wed Sep 07, 2022 8:31 pm
Due to ISP special setup, I need to block STP on one switch port, otherwise clients behind this switch will not get IP thru DHCP. I'm limited to 3 dynamic public IPs, but also STP proto is somehow blocking rest of clients and is counted as a client.
This bridge filter was working fine untill I upgraded from latest v6 to v7.5:
/interface bridge filter
add action=drop chain=output out-interface=ether23 src-mac-address=<MAC addr of ether23>/FF:FF:FF:FF:FF:FF
Filter is now not matching and I can see those packets in "testing" HexS connected to ISP modem in bridge mode:
313077	1569.938077	<Switch MAC>	Spanning-tree-(for-bridges)_00	STP	107	RST. Root = 16384/0/<HIDDEN>  Cost = 10  Port = 0x0015
Some idea?
sindy
Re: Switch: block STP on one port in RouterOS v7
Wed Sep 07, 2022 9:18 pm
Try matching on the destination mac-address 01:80:C2:00:00:00/FF:FF:FF:FF:FF:FF, which is specific for STP, instead.
mhaluska
Wed Sep 07, 2022 9:28 pm
None is matching (before setting edge=yes -> see below)...
add action=drop chain=output dst-mac-address=01:80:C2:00:00:00/FF:FF:FF:FF:FF:FF out-interface=ether23
add action=drop chain=output out-interface=ether23 src-mac-address=08:55:31:95:85:C3/FF:FF:FF:FF:FF:FF
I managed to disable STP with this, I don't see more STP packets and got 2nd IP successfully:
/interface/bridge/port/set edge=yes interface=ether23
But still there is probably some ethernet comm and "occupying" last available IP. Before this was probably solved with mentioned filter rule.
mhaluska
Wed Sep 07, 2022 9:39 pm
It looks like bridge filter is not working or all rules are totally ignored, ether5 is my Raspberry Pi where I tried to generate traffic after adding those rules:
> /interface/bridge/filter/export
add action=accept chain=forward in-interface=ether5
add action=accept chain=forward out-interface=ether5
add action=accept chain=input in-interface=ether5
add action=accept chain=output out-interface=ether5
> /interface/bridge/filter/print stats
Columns: CHAIN, ACTION, BYTES, PACKETS
# CHAIN    ACTION  BYTES  PACKETS
0 forward  accept      0        0
1 forward  accept      0        0
2 input    accept      0        0
3 output   accept      0        0
Splash
Tue Nov 15, 2022 12:35 pm
You could try a switching rule...
The manual seems to state you need to depend on the switch model you are using.
https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
"Dropping received BPDUs on a certain port can be done on some switch chips using ACL rules, but the Bridge Filter Input rules cannot do it if bridge has STP/RSTP/MSTP enabled because then received BPDUs have special processing in the bridge."
Example:
/interface ethernet switch rule
add dst-mac-address=01:80:C2:00:00:00/FF:FF:FF:FF:FF:FF ports=sfp-sfpplus13 switch=switch1
Also set the port to Edge = yes
add bridge=bridge1 edge=yes frame-types=admit-only-vlan-tagged interface=sfp-sfpplus13
Users browsing this forum: ChadRT, jmszuch1, LdB and 124 guests
