Here's a poor diagram of my setup:
Connection 1: 10G SFP+ to CRS326 SFP+2
Connection 2: 1g CAT6 to CRS326 ether10
Connection 1 --> CRS326 --> CRS309 --> speedtest.net:
Code: Select all
Speedtest by Ookla
Server: Spectrum - Austin, TX (id = 16965)
ISP: Spectrum
Latency: 14.73 ms (4.29 ms jitter)
Download: 1174.86 Mbps (data used: 1.6 GB )
Upload: 40.59 Mbps (data used: 19.8 MB )
Packet Loss: 0.0%
Code: Select all
Connecting to host 172.16.10.1, port 5201
[ 5] local 172.16.10.192 port 38474 connected to 172.16.10.1 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 658 MBytes 5.52 Gbits/sec 35 1.02 MBytes
[ 5] 1.00-2.00 sec 551 MBytes 4.62 Gbits/sec 299 1.41 MBytes
[ 5] 2.00-3.00 sec 672 MBytes 5.64 Gbits/sec 3 1.36 MBytes
[ 5] 3.00-4.00 sec 672 MBytes 5.64 Gbits/sec 137 1.10 MBytes
[ 5] 4.00-5.00 sec 676 MBytes 5.67 Gbits/sec 127 757 KBytes
[ 5] 5.00-6.00 sec 674 MBytes 5.65 Gbits/sec 0 1.23 MBytes
[ 5] 6.00-7.00 sec 671 MBytes 5.63 Gbits/sec 10 1.18 MBytes
[ 5] 7.00-8.00 sec 677 MBytes 5.68 Gbits/sec 136 848 KBytes
[ 5] 8.00-9.00 sec 674 MBytes 5.65 Gbits/sec 0 1.29 MBytes
[ 5] 9.00-10.00 sec 675 MBytes 5.66 Gbits/sec 86 1.25 MBytes
[ 5] 0.00-10.00 sec 6.45 GBytes 5.54 Gbits/sec 833 sender
[ 5] 0.00-10.00 sec 6.44 GBytes 5.53 Gbits/sec receiver
iperf Done.
Code: Select all
Speedtest by Ookla
ISP: Spectrum
Latency: 14.82 ms (2.25 ms jitter)
Download: 266.18 Mbps (data used: 332.2 MB )
Upload: 40.49 Mbps (data used: 19.4 MB )
Packet Loss: 0.0%
Code: Select all
[ 5] local 172.16.10.108 port 44780 connected to 172.16.10.1 port 5201
[ 5] 0.00-1.00 sec 114 MBytes 956 Mbits/sec 0 491 KBytes
[ 5] 1.00-2.00 sec 112 MBytes 942 Mbits/sec 0 491 KBytes
[ 5] 2.00-3.00 sec 112 MBytes 942 Mbits/sec 0 491 KBytes
[ 5] 3.00-4.00 sec 111 MBytes 934 Mbits/sec 0 491 KBytes
[ 5] 4.00-5.00 sec 112 MBytes 942 Mbits/sec 0 491 KBytes
[ 5] 5.00-6.00 sec 111 MBytes 934 Mbits/sec 0 491 KBytes
[ 5] 6.00-7.00 sec 112 MBytes 942 Mbits/sec 0 491 KBytes
[ 5] 7.00-8.00 sec 111 MBytes 934 Mbits/sec 0 491 KBytes
[ 5] 8.00-9.00 sec 112 MBytes 942 Mbits/sec 0 491 KBytes
[ 5] 9.00-10.00 sec 112 MBytes 942 Mbits/sec 0 491 KBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 941 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec receiver
iperf Done.
In case it's relevant, here's the relevant sections of my CRS326 config:
Code: Select all
add admin-mac=18:FD:74:47:E9:57 auto-mac=no comment=defconf ingress-filtering=\
no name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
/interface ethernet switch
set 0 l3-hw-offloading=yes
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10 pvid=\
10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus1
/interface bridge vlan
add bridge=bridge comment=LAN tagged=\
bridge,sfp-sfpplus1,ether23,ether7,ether9,sfp-sfpplus2 vlan-ids=10
