Tharun252
Netmetal Access Point
Thu Sep 08, 2022 1:33 pm
Hi all,
I have configured my Netmetal 5 as a Access point and Connected my PC with the access point using WIFI.
But I cant ping my access point from my laptop which is connected the access point via WIFI.
The access point IP Address is 10.5.200.10.
The laptop's WIFI IP is given as "OBTAIN AUTOMATICALLY".
I cant ping Access point from Laptop.
Am I missing something?
Thanks,
THARUN.
rextended
Re: Netmetal Access Point
Thu Sep 08, 2022 1:39 pm
If someone asked you the same question,
providing them with the same starting data, what would you answer them?
Wouldn't you ask him first to see how the devices are configured, for example?
Tharun252
Thu Sep 08, 2022 3:04 pm
Can I share you the backup file?
Thanks,
rextended
Thu Sep 08, 2022 3:19 pm
NO,
paste this on terminal:
/export file=config
on files you see the config.rsc
save on desktop,
open with notepad or similar,
read carefully all, and remove serial number, username, password and email, if any, (censore the value with ***, do not delete the line)
paste on forum the obtained text between [ code] [/ code] tags (without space in front of code)
Tharun252
Fri Sep 09, 2022 12:36 pm
Thanks for the concern,
I am attaching the file like you asked.
Kindly Guide me.
Thank you,
rextended
Fri Sep 09, 2022 2:29 pm
I do not see any particular problem, except for some 3 device on wireless access list that have forwarding disabled.
You have dhcp client active and one fixed IP???
Paste this on terminal without omit the { and the } :
set bridge comment="" admin-mac=[/int ethernet get ether1 mac-address] auto-mac=no
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-n/ac wds-default-bridge=disabled wds-mode=none
set [ find default=yes ] wpa-pre-shared-key=""
set [find] comment=""
remove [find]
remove [find where name=WAN]
remove [find where name=LAN]
set [find] interface=bridge
/ip dhcp-client
add comment=defconf interface=bridge
remove [find where disabled=yes]
Tharun252
Mon Sep 12, 2022 7:54 am
Good Morning Sir,
The original application is One master and Three remotes.
That's why there are three remote devices and also the remotes should not talk to each other they have to communicate only with the master that's why forwarding is disabled.
I don't have DHCP client active.
Yes I have one fixed IP.
Thank you,
THARUN.
Users browsing this forum: Pilo2710 and 78 guests
