dll2003
Antenna for Metal 2
Thu Sep 08, 2022 4:11 pm
Good afternoon everyone!
A friend gave me Metal 2 (RBMetal2SHPn).
But without antenna :(
What can I replace it?
rextended
Re: Antenna for Metal 2
Thu Sep 08, 2022 4:15 pm
Any 2,4GHz antenna with "N" connector...
dll2003
Mon Sep 12, 2022 12:03 pm
Thanks for the help.
I was embarrassed that, according to the description for Metal2, a fairly wide range is indicated (2192-2732MHz).
The antennas that I found had a much narrower range.
rextended
Mon Sep 12, 2022 12:21 pm
Standard pc, smartphone, etc. devices can work only on channels 1-14 (variable on countries) range and one narrow antenna is better ;)
Users browsing this forum: Tegarrti and 93 guests
