Znuff
[webproxy-test bug] <base href="http://url/" /> gets trimmed
Tue Oct 02, 2007 8:16 pm
Hello.
I'm using webproxy-test under 2.9.45 and I have a small issue with a website and probably with others.
Try visiting http://www.upc.ro when the webproxy-test is enabled and set as transparent proxy. Nothing loads up. Not the images, not the javascript, not the css and links don't work. Upon disabling the srcnat rule in the firewall (thus having direct access to the web) the website works fine.
Later edit: it seems to have an issue with the <base href=""> tag...
When the proxy is enabled I get <base href="http:///" />, while the correct tag in the page is <base href="http://www.upc.ro/" />.
Znuff
Re: [webproxy-test bug] <base href="http://url/" /> gets trimmed
Wed Oct 03, 2007 2:47 pm
So where do I post a bug, seeming that here nobody notices the bug posts?
Znuff
Tue Oct 16, 2007 1:36 am
Is this thing actually getting noticed?
normis
Tue Oct 16, 2007 10:32 am
can you try ROS v3 RC6?
sergejs
Wed Oct 17, 2007 4:29 pm
Contact support (support@mikrotik.com), in case you think that you have found bug at RouterOS.
Znuff
Thu Oct 18, 2007 8:01 pm
Can't try to use RC6 on that particular box. It's our main gateway and I don't want to risk breaking internet access for all our customer. I'll try and see on another box.
Znuff
Sun Oct 21, 2007 7:19 am
This is confirmed under version 3.00 RC7 too.
Users browsing this forum: No registered users and 101 guests
