acssol
Use mANT LTE 5o with LtAP?
Fri Sep 09, 2022 8:54 am
Is it possible to use mANT LTE 5o with LtAP? I can't see any SMA connectors on the LtAP (https://mikrotik.com/product/ltap#fndtn-gallery) - yet the description page of the mANT LTE 5o says "It is an excellent companion to our LTE devices, such as the wAP LTE and LtAP series."
Am I overseeing something?
mkx
Re: Use mANT LTE 5o with LtAP?  [SOLVED]
Fri Sep 09, 2022 8:59 am
It's kind of DIY. LTE antenna connectors are on LTE modem card you need to install in one if PCIe slots. Connect pigtail cables with SMA female connectors, mount those to circular cutouts on the case (remove the tabs as needed).
acssol
Mon Sep 12, 2022 8:27 am
Thanks mkx!
Users browsing this forum: Amazon [Bot] and 38 guests
