vetal12311
Container launching issues using hap ac3 with ros 7.5
Sat Sep 10, 2022 6:11 pm
Greetings, collegues.
Since the reintroduction of containers support in v7.5, I got curious what could I do with it beyond Pihole, which is Mikrotik's entry point in a tutorial guide.
Tried downloading multiple images from the repository as described in aforementioned guide, but failing to launch even though I have thought out all env variables.
Maybe entrypoint and mounts were incorrect?
holvoetn
Re: Container launching issues using hap ac3 with ros 7.5
Sat Sep 10, 2022 10:09 pm
Upgrade to latest beta 7.6.
Then start from scratch.
Quite some container issues haven been solved after 7.5.
Andrew162
Sun Sep 11, 2022 1:14 am
Check my error and at the same solution
viewtopic.php?t=189091
The most issue of my situation was.. copy paste...
terminal of mikrotik dont like "paste"
do it manualy
and also check subnets etc
on My post i write solution for my errors
Working on 7.6beta6 ( did not test on previous)
Users browsing this forum: arm920t, lurker888, phascogale and 50 guests
