benoitc
LTE: can’t get an IPv6 address
Sat Sep 10, 2022 7:31 pm
My provider support IPV6:
/interface/lte> at-chat lte1 input="AT+CGDCONT=\?"
output: +CGDCONT: (0-15),"IP",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
+CGDCONT: (0-15),"IPV6",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
+CGDCONT: (0-15),"IPV4V6",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
+CGDCONT: (0-15),"PPP",,,(0-3),(0-4),(0,1),(0,1),(0-2),(0,1)
OK
But I don't get any Ipv6 address when setup to auto. I've also tried to force it to ipv6 but without success. Any idea how can I force the modem to use the IPV4V6 mode ? Should I setup something else apart the profile and lte interface?
Current configuration is:
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=orange.fr band=\
1,3,7,20 network-mode=lte
/interface lte apn
add apn=orange.fr authentication=chap ipv6-interface=bridge user=orange
nicodonald
Re: LTE: can’t get an IPv6 address
Thu Apr 06, 2023 9:29 pm
Hello, I have a 5g chateau ont RouterOS 7.9 and I have the same problem.
When I try with an bouygetel SIM I have the same problem (When on my smartphon I have an Ipv6)
Amm0
Thu Apr 06, 2023 10:28 pm
You might want to enable some add'l lte logging to see what's happening during LTE session establishment.
/system/logging/add topics=lte,!packet,!raw
then disable/re-enable the LTE device, and check the logs.
Amm0
Thu Apr 06, 2023 10:30 pm
And it generally helps if you're using the latest RouterOS, matching /system/routerboard firmware, and the LTE firmware is also up-to-date. e.g. You mention the RouterOS version, but might want to update the board and LTE firmware if you haven't already.
nicodonald
Sat Apr 08, 2023 12:25 pm
LTE Firmware and RouterBOARD firmware are up to date :
LTE : RG502QEAAAR13A02M4G
RouterBOARD : 7.9rc1
Here is the log of the lte interface :
11:23:55 lte,debug lte1 mbim: <<< Q service: connect, command: subscriber ready status
11:23:55 system,info device changed by admin
11:23:55 lte,async lte1: rcvd OK
11:23:55 lte,async lte1: sent AT+QNWPREFCFG="nsa_nr5g_band",1:3:5:7:8:20:28:38:40:41:77:78:79
11:23:55 lte,async lte1: sent AT+QNWPREFCFG="lte_band",1:3:5:7:8:18:19:20:26:28:32:34:38:39:40:41:42:43
11:23:55 lte,debug lte1 mbim: >>> D service: connect, command: subscriber ready status
11:23:55 lte,debug lte1 mbim: subscriber ready state: initialized
11:23:55 lte,debug lte1 mbim: state 7=>10
11:23:55 lte,debug lte1 mbim: set lte attach apn: orange.fr
11:23:55 lte,debug lte1 mbim: <<< S service: conn_ext, command: lte attach config
11:23:55 lte,debug lte1 mbim: >>> D service: conn_ext, command: lte attach config
11:23:55 lte,debug lte1 mbim: lte attach ctx  source: 1 roam: 0 ip: 0 apn: orange.fr
11:23:55 lte,debug lte1 mbim: lte attach ctx  source: 1 roam: 1 ip: 0 apn: orange.fr
11:23:55 lte,debug lte1 mbim: lte attach ctx  source: 1 roam: 2 ip: 0 apn: orange.fr
11:23:55 lte,debug lte1 mbim: request register, operator: [auto]
11:23:55 lte,debug lte1 mbim: <<< S service: connect, command: register state
11:23:55 lte,debug lte1 mbim: >>> D service: connect, command: register state
11:23:55 lte,debug lte1 mbim: register state: deregistered
11:23:55 lte,debug lte1 mbim: state 10=>11
11:23:55 lte,debug lte1 mbim: set radio: on
11:23:55 lte,debug lte1 mbim: <<< S service: connect, command: radio state
11:23:55 lte,debug lte1 mbim: >>> N service: sms, command: configuration
11:23:55 lte,debug lte1 mbim: sms service center +33689004000
11:23:55 lte,debug lte1 mbim: >>> N service: connect, command: radio state
11:23:55 lte,debug lte1 mbim: >>> D service: connect, command: radio state
11:23:55 lte,debug lte1 mbim: >>> N service: connect, command: register state
11:23:55 lte,debug lte1 mbim: register state: searching
11:23:55 lte,debug lte1 mbim: state 11=>12
11:23:56 lte,debug lte1 mbim: >>> N service: connect, command: register state
11:23:56 lte,debug lte1 mbim: register state: home, gsm operator: 20801, Orange F, avail data classes: 0x20
11:23:56 lte,debug lte1 mbim: state 12=>14
11:23:56 lte,debug lte1 mbim: waiting for auto attach
11:23:56 lte,debug lte1 mbim: >>> N service: connect, command: packet service
11:23:56 lte,debug lte1 mbim: packet service: attached data class: 0x20 nwe:
11:23:56 lte,debug lte1 mbim: state 14=>17
11:23:56 lte,debug lte1 mbim: >>> N service: conn_ext, command: lte attach status
11:23:56 lte,debug lte1 mbim: lte status: attached apn: orange.fr iptype: 0
11:23:57 lte,debug lte1 mbim: do connect activate #0
11:23:57 lte,debug lte1 mbim: apn: orange.fr iptype: 0 user: orange
11:23:57 lte,debug lte1 mbim: <<< S service: connect, command: connect
11:23:57 lte,debug lte1 mbim: >>> N service: connect, command: connect
11:23:57 lte,debug lte1 mbim: connect: #0 activating, nwe:
11:23:57 lte,debug lte1 mbim: waiting for done
11:23:57 lte,debug lte1 mbim: >>> D service: connect, command: connect
11:23:57 lte,debug lte1 mbim: connect: #0 activated, nwe:
11:23:57 lte,debug lte1 mbim: get ip config #0
11:23:57 lte,debug lte1 mbim: <<< Q service: connect, command: ip configuration
11:23:57 lte,debug lte1 mbim: >>> D service: connect, command: ip configuration
11:23:57 lte,debug lte1 mbim: received ip config #0 15,0
11:23:57 lte,debug lte1 mbim: IPv4: 10.2.193.143, DNS: 192.168.10.110, MTU: 1500
11:23:57 lte,info lte1 IPv4: 10.2.193.143, DNS: 192.168.10.110
11:23:57 lte,debug lte1 mbim: state 17=>18
11:23:57 interface,info lte1 link up
optio
Long time Member
Long time Member
Sat Apr 08, 2023 12:59 pm
Did you try to set ip-type=ipv6 on apn profile? Maybe you cannot have dual stack LTE connection (or is some ROS limitation/bug).
nicodonald
Sat Apr 08, 2023 1:05 pm
If I set type ipv6 in the apn it fails to connect :
12:04:16 lte,debug lte1 mbim: lte status: attached apn: orange.fr iptype: 2
12:04:17 lte,debug lte1 mbim: do connect activate #0
12:04:17 lte,debug lte1 mbim: apn: orange.fr iptype: 2 user: orange
12:04:17 lte,debug lte1 mbim: <<< S service: connect, command: connect
12:04:17 lte,debug lte1 mbim: >>> N service: connect, command: connect
12:04:17 lte,debug lte1 mbim: connect: #0 activating, nwe:
12:04:17 lte,debug lte1 mbim: waiting for done
12:04:17 lte,debug lte1 mbim: >>> E service: connect, command: connect, error: FAILURE
12:04:17 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
nicodonald
Sat Apr 08, 2023 1:17 pm
Ok I figured it out
apn orange.fr and IPv6 > failed to connect
apn orange and IPv6 > ipv4 (rfc1918) AND ipv6 addresses
apn orange and auto > ipv4 (rfc1918) only
That's weird
Users browsing this forum: Syn and 54 guests
