barara
Routeros 7 Interface random Mac address
Sun Sep 11, 2022 11:13 am
Hello
I'm not familiar with mikrotik scripts. Please understand even the low level questions.
In the picture below, I want to randomly select the hexadecimal characters of number 1 and combine them with the randomly generated hexadecimal string of number 2 and finally make it like number 5.
Is there a way?
Thank you.
Jotne
Re: Routeros 7 Interface random Mac address
Sun Sep 11, 2022 12:15 pm
Why?
Where is part 1 (6 first hex of mac) coming from?
Part 2 are the 6 last hex of you random mac
barara
Sun Sep 11, 2022 1:29 pm
Why?
Thanks for reply.
The dhcp server connected to the wan port did not assign an IP address for a specific MAC address.
So, I used the method of combining the specified values.
It seems that IP is assigned based on the oui value.
part 1 hex values are pre-specified plain text.
Jotne
Sun Sep 11, 2022 5:38 pm
Here you go
:local array { "c8:ea:f8"; "70:9f:2d"; "38:3b:26"; "5c:fa:fb"; "9c:7b:ef" }
:local part1 ($array->[:rndnum from=0 to=([:len $array]-1)])
:local hex1 [:rndstr length=6 from="0123456789abcdef"]
:local part2 ([:pick $hex1 0 2].":".[:pick $hex1 2 4].":".[:pick $hex1 4 6])
:local Mac ($part1.":".$part2)
:put $Mac
Just add more mac to the array to your need.
rextended
Re: Routeros 7 Interface random Mac address  [SOLVED]
Mon Sep 12, 2022 1:11 am
":" are not needed, and uppercase and lowercase are ignored (but must be a valic MAC: the 2nd digit of 1st HEX must be 0, 4, 8 or C)
:put "$[:rndstr length=1 from="0123456789ABCDEF"]$[:rndstr length=1 from="048C"]$[:rndstr length=10 from="0123456789ABCDEF"]"
barara
Mon Sep 12, 2022 7:38 am
Thanks to both of you for the replies.
the script works very well.
juanfrancisco2023
Mon Apr 24, 2023 11:45 pm
rndstr como se utiliza en la v6.48? no existe ese comando
rextended
Tue Apr 25, 2023 11:12 am
Generate 12 times a random number
viewtopic.php?f=9&t=175453&p=858629#p858629
each time you do % 16 you can have random results from 0 to 15, pick from one arraythe corresponding digit.
Make sure that the 1st bit (bit 0) on 2nd digit is always 0, or the network do not work as expected....
and if is generated MAC must have 2nd bit (bit 1) on 2nd digit always 1.
:global randomnum do={
    /system resource irq
    :local tmpsum 0
    :foreach i in=[find] do={:set tmpsum ($tmpsum + [get $i count])}
    :set   tmpsum [:tostr $tmpsum]
    :local lentmp [:len   $tmpsum]
    :return [:tonum [:pick $tmpsum ($lentmp - 2) $lentmp]]
:local arrhex [:toarray "0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F"]
:local rndmac ; :local tmp
:for x from=1 to=12 step=1 do={
   :set tmp ([$randomnum] % 16)
   # this makes it always a valid MAC
   :if ($x =  2) do={:set tmp (($tmp | 0x2) & 0xE)}
   :set rndmac "$rndmac$($arrhex->$tmp)"
   :if ([:tostr [:len $rndmac]] ~ "(2|5|8|11|14)") do={:set rndmac "$rndmac:"}
:put $rndmac
Users browsing this forum: No registered users and 33 guests
