Z0ltan
WireGuard weird bug on webfig
Sun Sep 11, 2022 7:58 pm
Wanted to add a new device to my WireGuard peers and I think I have found a bug. When you want to add a new peer via web, the endpoint address field is empty but it is available for editing - in that state, connections are established but no data flows through. If the endpoint address textfield is hidden with the little black triangle and the connection is saved, everything works. I can repeat this on my RB4011 running 7.5 stable (open peer, save with empty endpoint address field to break it; then open peer, disable endpoint address and save to fix it. All keys/etc stay the same, I normally don’t have endpoint address set for the peers). My endpoints are iPhone and iPad, running latest app and OS.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 36 guests
