MarkScott
OpenVPN help needed
Mon Sep 12, 2022 4:45 pm
My home LAN is based on a HaP AC router running OpenVPN server that I'm able to connect to from the OpenVPN Android client on my phone, but using the same configuration I can't get a connection established from my laptop running Ubuntu LTS (20.04), even when the phone and he laptop are on the same WiFi network. I'm using the openvpn3 package as supplied by Ubuntu (18-beta1+focal).
Something is causing either the client or the server side to disconnect, then it immediately retries, in an endless loop. I can't see what's causing this.
I'd be grateful for any advice on how I might resolve this. I've included what I hope are the relevant logs and configs.
Client invocation from command line produces these messages, which end with the error message when I disconnect the client from another command prompt:
openvpn3 session-start --config temp/OpenVPNetc/PHVPN.ovpn
Using configuration profile from file: temp/OpenVPNetc/PHVPN.ovpn
Session path: /net/openvpn/v3/sessions/73a32ca6s5715s476bs8771s3121992010e6
session-start: ** ERROR ** Failed to start session
The client log messages look like this:
$ openvpn3 log --log-level 6 --config temp/OpenVPNetc/PHVPN.ovpn
Waiting for session to start ... Done
Attaching to session /net/openvpn/v3/sessions/73a32ca6s5715s476bs8771s3121992010e6
2022-09-11 16:30:01 [STATUS] Connection, Configuration OK: config_path=/net/openvpn/v3/configuration/caca0248x641ax4a9axabd7xf9e4f639d7ed
2022-09-11 16:30:01 Client INFO: Starting connection
2022-09-11 16:30:01 [STATUS] Connection, Client connecting
2022-09-11 16:30:01 Client VERB1: Waiting for server response
2022-09-11 16:30:02 Client INFO: Connecting
2022-09-11 16:30:02 [STATUS] Connection, Client connecting
2022-09-11 16:30:05 Client VERB1: Waiting for server response
2022-09-11 16:30:05 Client INFO: Connecting
2022-09-11 16:30:05 [STATUS] Connection, Client connecting
2022-09-11 16:30:09 Client VERB1: Waiting for server response
2022-09-11 16:30:09 Client INFO: Connecting
2022-09-11 16:30:09 [STATUS] Connection, Client connecting
2022-09-11 16:30:13 Client VERB1: Waiting for server response
2022-09-11 16:30:13 Client INFO: Connecting
2022-09-11 16:30:13 [STATUS] Connection, Client connecting
2022-09-11 16:30:17 Client VERB1: Waiting for server response
2022-09-11 16:30:17 Client INFO: Connecting
2022-09-11 16:30:17 [STATUS] Connection, Client connecting
2022-09-11 16:30:18 Client INFO: Stopping connection
2022-09-11 16:30:18 [STATUS] Connection, Client disconnecting
2022-09-11 16:30:18 [STATUS] Connection, Client disconnected
2022-09-11 16:30:18 Client INFO: Disconnected
2022-09-11 16:30:18 [STATUS] Connection, Client process exited
Session closed
Here is the OpenVPN client configuration (identical to one that works on the Android client):
dev tun
proto tcp-client
remote **.**.**.**
port 1194
nobind
persist-key
persist-tun
tls-client
remote-cert-tls server
ca CA.crt
cert PHClient.crt
key PHClient.key
verb 6
mute 10
cipher AES-256-CBC
auth SHA1
auth-user-pass secret
auth-nocache
Extract from router log:
16:29:06 ovpn,info TCP connection established from <source ip>
16:29:06 firewall,info OpenVPN input: in:pppoe-out1 out:(unknown 0), proto TCP (SYN), <source ip>:35426-><router ip>:1194, len 60
16:29:06 ovpn,info : using encoding - AES-256-CBC/SHA1
16:29:06 ovpn,info,account mark logged in, 172.28.16.202 from <source ip>
16:29:06 ovpn,info <ovpn-mark>: connected
16:29:08 ovpn,info <ovpn-mark>: terminating... - peer disconnected
16:29:08 ovpn,info,account mark logged out, 2 0 0 0 0 from <source ip>
16:29:08 ovpn,info <ovpn-mark>: disconnected
16:29:10 ovpn,info TCP connection established from <source ip>
16:29:10 firewall,info OpenVPN input: in:pppoe-out1 out:(unknown 0), proto TCP (SYN), <source ip>:35428-><router ip>:1194, len 60
16:29:10 ovpn,info : using encoding - AES-256-CBC/SHA1
16:29:10 ovpn,info,account mark logged in, 172.28.16.202 from <source ip>
16:29:11 ovpn,info <ovpn-mark>: connected
16:29:12 ovpn,info <ovpn-mark>: terminating... - peer disconnected
16:29:12 ovpn,info,account mark logged out, 1 0 0 0 0 from <source ip>
16:29:12 ovpn,info <ovpn-mark>: disconnected
16:29:14 ovpn,info TCP connection established from <source ip>
16:29:14 firewall,info OpenVPN input: in:pppoe-out1 out:(unknown 0), proto TCP (SYN), <source ip>:35430-><router ip>:1194, len 60
16:29:14 ovpn,info : using encoding - AES-256-CBC/SHA1
16:29:14 ovpn,info,account mark logged in, 172.28.16.202 from <source ip>
16:29:14 ovpn,info <ovpn-mark>: connected
16:29:16 ovpn,info <ovpn-mark>: terminating... - peer disconnected
16:29:16 ovpn,info,account mark logged out, 1 0 0 0 0 from <source ip>
16:29:16 ovpn,info <ovpn-mark>: disconnected
16:29:18 ovpn,info TCP connection established from <source ip>
16:29:18 firewall,info OpenVPN input: in:pppoe-out1 out:(unknown 0), proto TCP (SYN), <source ip>:35432->           :1194, len 60
16:29:18 ovpn,info : using encoding - AES-256-CBC/SHA1
16:29:18 ovpn,info,account mark logged in, 172.28.16.202 from <source ip>
16:29:18 ovpn,info <ovpn-mark>: connected
16:29:19 ovpn,info <ovpn-mark>: terminating... - peer disconnected
16:29:19 ovpn,info,account mark logged out, 1 0 0 0 0 from <source ip>
16:29:19 ovpn,info <ovpn-mark>: disconnected
16:29:21 ovpn,info TCP connection established from <source ip>
16:29:21 firewall,info OpenVPN input: in:pppoe-out1 out:(unknown 0), proto TCP (SYN), <source ip>:35434-><router ip>:1194, len 60
16:29:21 ovpn,info : using encoding - AES-256-CBC/SHA1
16:29:21 ovpn,info,account mark logged in, 172.28.16.202 from <source ip>
16:29:22 ovpn,info <ovpn-mark>: connected
16:29:23 ovpn,info <ovpn-mark>: terminating... - peer disconnected
16:29:23 ovpn,info,account mark logged out, 1 0 0 0 0 from <source ip>
16:29:23 ovpn,info <ovpn-mark>: disconnected
Router confiiguration:
# sep/12/2022 14:11:57 by RouterOS 6.48.3
# software id = GIY1-UQIH
# model = RB962UiGS-5HacT2HnT
# serial number = BEC60BFB9663
add admin-mac=C4:AD:34:09:62:32 arp=proxy-arp auto-mac=no comment=defconf \
    name=bridge
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="united kingdom" disabled=no distance=indoors frequency=auto \
    mode=ap-bridge ssid=PoplarHouse station-roaming=enabled \
    wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country="united kingdom" disabled=no distance=indoors \
    frequency=auto mode=ap-bridge ssid=PoplarHouse station-roaming=enabled \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=dhcp ranges=172.28.16.64-172.28.16.199
add comment="for use by openvpn" name=vpnpool ranges=\
    172.28.16.200-172.28.16.210
add address-pool=dhcp disabled=no interface=bridge lease-time=1h name=defconf
/ppp profile
set *0 idle-timeout=20m
add dns-server=1.1.1.1,172.28.16.24 local-address=172.28.16.1 name=ovpn \
    remote-address=vpnpool use-encryption=yes
set *FFFFFFFE idle-timeout=20m
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
/interface ovpn-server server
set auth=sha1 certificate=PHServer cipher=aes256 default-profile=ovpn \
    enabled=yes require-client-certificate=yes
/interface pptp-server server
set enabled=yes
add address=172.28.16.1/24 comment=defconf interface=ether2 network=\
    172.28.16.0
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
add address=172.28.16.0/24 comment=defconf dns-server=172.28.16.24 domain=\
    POPLARHOUSE gateway=172.28.16.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=172.28.16.1 name=router.lan
/ip firewall address-list
add address=172.28.16.2-172.28.16.254 list=allowed-local
    established,related,untracked
add action=accept chain=input comment="Source IP is on local LAN" log-prefix=\
    LocalIP src-address-list=allowed-local
add action=accept chain=input comment="Allow OpenVPN" dst-port=1194 log=yes \
    log-prefix=OpenVPN protocol=tcp
    invalid log-prefix=Invalid-dropped
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=openvpn \
    passthrough=yes protocol=tcp src-port=1194
add action=dst-nat chain=dstnat comment="remote access to birdbox" disabled=\
    yes dst-port=7175 log=yes protocol=tcp to-addresses=172.28.16.22 \
    to-ports=8082
add action=masquerade chain=srcnat connection-mark=openvpn
/ppp secret
add name=anna profile=ovpn service=ovpn
add name=mark profile=ovpn
add name=msx1 profile=ovpn
/system clock
set time-zone-name=Europe/London
/system identity
set name=PoplarAP1
/system leds
set 2 disabled=yes
/tool graphing interface
add
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: GoogleOther [Bot], Majestic-12 [Bot], sebi099 and 203 guests
