skendric
Configure the QSFP+ ports on the CR328-24S-2Q-RM
Tue Sep 13, 2022 12:49 am
I am trying to configure the (2) QSFP+ ports to support a 40G twinax (aka DAC) cable. By default, they seem to be configured to support a 4 x 10G break-out cable
Where do I find instructions on doing this?
I am consulting the following:
https://help.mikrotik.com/docs/display/ ... tswitching
https://wiki.mikrotik.com/wiki/Manual:S ... p_Features
But I don't see any discussion of an /interface/ethernet xyz command which even mentions the "qsfpplus1" and "qsfpplus2" ports
None of these options seem to allow me to change the port from "split into (4) 10G channels" to "present a single 40G QSFP+ port"
[admin@MikroTik] /interface ethernet>
.. -- go up to interface
blink -- Generate traffic to blink leds
cable-test --
comment -- Set comment for items
disable -- Disable items
edit --
enable -- Enable items
export -- Print or save an export script that can be used to restore configurati
on
find -- Find items by value
get -- Gets value of item's property
monitor -- Monitor interface status
print -- Print values of item properties
reset-counters --
reset-mac-address --
set -- Change item properties
switch --
unset --
[admin@MikroTik] /interface ethernet> >
Suggestions?
--sk
Stuart Kendrick
AidanAus
Re: Configure the QSFP+ ports on the CR328-24S-2Q-RM
Tue Sep 13, 2022 3:57 am
Im not sure personally but have you tried disabling auto negotiation and trying to set the interface 'main' interface speed to 40gb and see if the other 3 slave interfaces disaprear?
https://wiki.mikrotik.com/wiki/MikroTik ... link_rates
skendric
Wed Sep 14, 2022 1:33 am
Hard-coding speed & duplex seems to work
[admin@MikroTik] /interface ethernet> set qsfpplus1-1 auto-negotiation=no speed=40Gbps full-duplex=yes
Though the other subinterfaces still show up ...
[admin@MikroTik] /interface ethernet> print qsfpplus1-1 detail
expected end of command (line 1 column 7)
[admin@MikroTik] /interface ethernet> print detail qsfpplus1-1
expected end of command (line 1 column 14)
Flags: X - disabled, R - running, S - slave
0 RS name="ether1" default-name="ether1" mtu=1500 l2mtu=1598
mac-address=DC:2C:6E:5E:AA:E5 orig-mac-address=DC:2C:6E:5E:AA:E5
arp=enabled arp-timeout=auto loop-protect=default
loop-protect-status=off loop-protect-send-interval=5s
loop-protect-disable-time=5m auto-negotiation=yes
advertise=10M-half,10M-full,100M-half,100M-full full-duplex=yes
tx-flow-control=off rx-flow-control=off speed=100Mbps
bandwidth=unlimited/unlimited switch=switch2
1 S name="qsfpplus1-1" default-name="qsfpplus1-1" mtu=1500 l2mtu=1584
mac-address=DC:2C:6E:5E:AA:DD orig-mac-address=DC:2C:6E:5E:AA:DD
loop-protect-disable-time=5m auto-negotiation=no advertise=""
full-duplex=yes tx-flow-control=off rx-flow-control=off speed=40Gbps
bandwidth=unlimited/unlimited switch=switch1 fec-mode=auto
2 S name="qsfpplus1-2" default-name="qsfpplus1-2" mtu=1500 l2mtu=1584
mac-address=DC:2C:6E:5E:AA:DE orig-mac-address=DC:2C:6E:5E:AA:DE
loop-protect-disable-time=5m auto-negotiation=yes advertise=""
3 S name="qsfpplus1-3" default-name="qsfpplus1-3" mtu=1500 l2mtu=1584
mac-address=DC:2C:6E:5E:AA:DF orig-mac-address=DC:2C:6E:5E:AA:DF
4 S name="qsfpplus1-4" default-name="qsfpplus1-4" mtu=1500 l2mtu=1584
mac-address=DC:2C:6E:5E:AA:E0 orig-mac-address=DC:2C:6E:5E:AA:E0
How do I print just the details for qsfpplus1-1?
And ...
How do I print the make/model of the transceiver which the switch sees inserted into qsfpplus1-1?
mkx
Wed Sep 14, 2022 8:13 am
This way:
/interface ethernet print detail where name=qsfpplus1-1
Users browsing this forum: fxcd, Javokhir, NxtGen [Bot], zalciukaz and 106 guests
