DeLorean
Setting up 2.4g and 5g
Tue Sep 13, 2022 6:16 am
During the pandemic my WiFi was killed with all of my kids being at home with their Chrome Books and other wireless devices all the time. I upgrade to a Wireless AP RBcAPGi-5acD2nD and it was working great with my Edge router lite. Well my router died and I upgraded to a RB4001iGS+ that has been great to handle my 1Gbps Fiber connection.
Everything seemed fine after setting it up and everything was happy... 900+ up and down on speed test WiFi was strong, how ever I kept getting some lag spikes on mine and my wife's W@H machines. IT was blaming my Internet and I was blaming my IT for not knowing what they where doing.
Fast forward a few weeks of going back and forth on the issue I was messing with my CAP working on getting it to play with my router. I got it to work, but only in 2.4g and my lagging problems with our W@H machines went away. Everything was good until I wanted to connect my 5g devices for faster connections. Don't ask me how, but I got 5G to work, but now I don't have 2.4g and I have a few devices that need the 2.4g (Traeger, daughters laptop, Wyze devices).
I am now nearly bald and think that I have lost my mind trying to right my WiFi ship.
Can anyone help or give me any direction I should go?
mkx
Re: Setting up 2.4g and 5g
Tue Sep 13, 2022 9:14 am
Post text export of cAP ac config. Open a terminal window from GUI, execute command /export hide-sensitive file=anynameyouwish, fetch the resulting file (with extension .rsc) from cAP ac Files section to your computer, open it with text editor, obfuscate (don't remove, replace it with some clearly dummy values, e.g. A.B.C.D for IP address or some such) remaining sensitive data (such as serial number, any passwords or user names) and copy-paste the whole lot here between [code] [/code] pair of tags.
DeLorean
Tue Sep 13, 2022 4:55 pm
I don't know if this is correct or not
/caps-man channel
add band=5ghz-a/n/ac name="Mikrotik 5g"
add band=2ghz-b/g/n name="Mikrotik 2g"
add admin-mac=2C:C8:1B:8B:DA:41 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,2500M-full
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,2500M-full
/caps-man datapath
add bridge=bridge name=Default
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 service-name=Xmission use-peer-dns=yes user=usernamehere
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm,tkip name=Terminator
/caps-man configuration
add channel="Mikrotik 5g" channel.band=5ghz-a/n/ac country="united states3" datapath=Default datapath.bridge=bridge mode=ap name="MikroTik 5g" security=Terminator security.authentication-types=wpa-psk,wpa2-psk .encryption=aes-ccm,tkip ssid="MikroTik 5g"
add channel="Mikrotik 2g" channel.band=2ghz-b/g/n country="united states3" datapath=Default datapath.bridge=bridge mode=ap name="Mikrotik 2g" security=Terminator ssid="Mikrotik 2g"
/caps-man interface
add channel="Mikrotik 2g" channel.band=2ghz-g/n configuration="Mikrotik 2g" configuration.mode=ap .ssid="Mikrotik 2g" datapath=Default datapath.bridge=bridge disabled=no l2mtu=1600 mac-address=48:8F:5A:0A:62:A8 master-interface=none name=cap1 radio-mac=48:8F:5A:0A:62:A8 radio-name="" security=Terminator \
add channel="Mikrotik 5g" channel.band=5ghz-a/n/ac configuration="MikroTik 5g" configuration.mode=ap .ssid="MikroTik 5g" datapath=Default disabled=no l2mtu=1600 mac-address=48:8F:5A:0A:62:A9 master-interface=none name=cap2 radio-mac=48:8F:5A:0A:62:A9 radio-name="" security=Terminator \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge name=DHCP
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
set *FFFFFFFE dns-server=192.168.88.1 local-address=192.168.89.1 remote-address=vpn
/caps-man manager
set ca-certificate=auto enabled=yes upgrade-policy=suggest-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
/caps-man provisioning
add action=create-dynamic-enabled master-configuration="MikroTik 5g" radio-mac=48:8F:5A:0A:62:A9
add action=create-dynamic-enabled master-configuration="Mikrotik 2g" radio-mac=48:8F:5A:0A:62:A8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface ovpn-server server
set auth=sha1,md5
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
/interface wireless cap
set caps-man-addresses=::,:: discovery-interfaces=cap1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.88.2/30 interface=ether1 network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add interface=ether1
add interface=cap1
/ip dhcp-server lease
add address=192.168.88.100 client-id=1:a8:a1:59:13:f9:a2 mac-address=A8:A1:59:13:F9:A2 server=DHCP
add address=192.168.88.17 client-id=1:7c:d3:a:7a:84:9a mac-address=7C:D3:0A:7A:84:9A server=DHCP
add address=192.168.88.97 mac-address=84:EA:ED:11:E0:2D server=DHCP
add address=192.168.88.254 client-id=1:b4:2e:99:3a:75:fe mac-address=B4:2E:99:3A:75:FE server=DHCP
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=32400 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.88.100 to-ports=32400
add action=dst-nat chain=dstnat dst-port=921 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.88.100 to-ports=443
add action=dst-nat chain=dstnat dst-port=2456-2458 in-interface=pppoe-out1 protocol=udp to-addresses=192.168.88.100 to-ports=2456-2458
add action=dst-nat chain=dstnat dst-port=2456-2458 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.88.100 to-ports=2456-2458
add action=dst-nat chain=dstnat dst-port=443 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.88.100 to-ports=443
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=192.168.89.0/24
/ip upnp
set enabled=yes
/ppp secret
add name=vpn
/system clock
set time-zone-name=America/Denver
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool mac-server
/tool mac-server mac-winbox
DeLorean
Tue Sep 13, 2022 5:15 pm
delorean1.rsc
mkx
Tue Sep 13, 2022 9:35 pm
Do you intend to use multiple Mikrotik APs in your network? If not, then I suggest you to ditch capsman and go with plain WiFi config under /interface wireless (even though commercial name of device is cAP ac, you don't have to use capsman). When using capsman, settings are dispersed around and it's harder to put all pieces together (at least that's my own experience).
DeLorean
Tue Sep 13, 2022 10:57 pm
Thanks for your reply. This is the 1st time that I have had devices that I could link together as such... I've had Cisco, Edge router-lite, multiple consumer devices before that too... So when I set this up I found a guide that made any sense to me (https://www.nkent.us/wiki/index.php/Wir ... Tik_cAP_ac) the guide appears to no longer be online.
Would there be a guide that I could follow for the "Wireless" option you mentioned?
holvoetn
Wed Sep 14, 2022 12:06 am
Check in usefull user articles, anav has some nice posts to get you started.
viewtopic.php?t=182373
DeLorean
Wed Sep 14, 2022 3:34 am
Okay...So it looks like I need to follow these steps viewtopic.php?t=181718
Is there any easy way to remove what I have done so far with the AP to configure it with these steps instead?
mkx
Wed Sep 14, 2022 8:43 am
Either click through capsman configuration section and remove everything you see (the important part being cap section of wireless configuration subtree) ... or reset to defaults and re-do the DST NAT part you have. Then proceed with configuration of wireless interfaces.
Users browsing this forum: No registered users and 73 guests
