Reeman
router hanging for 20s
Wed Sep 14, 2022 12:24 pm
my custemer has a WISP with 1200 user and has ccr1072-1g-8s+ connected to multiple towers, each tower is connected to the router as PPPOE . the problem accures when the elecricity is cut off on a certain area and all users in that area are dissconnected at the same time the router is hanging for a certain time.
when he went to the router location and unplug a random cable of one of the towers, the router hang for approxmetly 20 seconds , all the leds are off then after 20s its works normally.
he had a 1036 router and he think the problem was because it is overloaded then he replace it with 1072 and the problem is still.
whats the problem with the routers?
thank u for your time
Buckeye
Forum Veteran
Forum Veteran
Re: router hanging for 20s
Thu Sep 15, 2022 12:22 am
That's an interesting troubleshooting technique.
probably nothing.
I'm not sure why, but this post reminded me of this joke. Engine Failure
Paternot
Forum Veteran
Forum Veteran
Thu Sep 15, 2022 5:49 am
I remember something along these lines on the forum - do a search and You will find it.
If I'm not mistaken, the solution is to run two different CCRs: one doing PPPoE - and with connection tracking disabled - and the other doing NAT, firewall and the rest. The problem happens when one customer disconnects: then one core has to parse everything on the connection tracking table, and gets overloaded. This creates a rolling problem, with one connection going down after another.
Without connection tracking the problem disappear, since there is nothing to parse. But run a search on the forum and do a test on lab first - I read it a long time ago, and may be wrong.
Znevna
Thu Sep 15, 2022 7:52 am
Your custemer should hire someone qualified to get the job done.
Reeman
Thu Sep 15, 2022 12:38 pm
thank you , its very helpful :)
Users browsing this forum: massinia, Semrush [Bot] and 85 guests
