how does this intercsect with my problem..?
Your device — one of the CRS326 models based on the header of your RSC file — isn't a CRS1xx or 2xx, so you can't have multiple bridges per switch chip. I'm going to guess it's one of the 24G models based on details of your bridge setup. From that, we can then go to
the product page and dig up
the block diagram, which shows only one switch chip.
Therefore, your result is entirely expected. One switch chip = one hardware-accelerated bridge for this class of device. All I'm pointing out with my additional detail up-thread is that this isn't true of every device in MikroTik's lineup. Most, yes, but not all.
how can i solve my problem in current situation..?
The general pattern is to create a single hardware bridge for everything, then use other technologies to divide things up.
VLANs are one popular method.
Port isolation is another. You might even find use for certain
VPN technologies.
What precisely are you trying to accomplish?
