mbghost
Script don't work
Wed Sep 14, 2022 3:39 pm
Hello, I can't run this script, it worked a week ago, and I didn't change anything connected with him ,if write only
:log info "Starting Backup Script...";
it show in Log, but if I run all script, it's do not show anything in Log
:local sysname [/system identity get name];
:local sysver [/system package get system version];
:log info "Flushing DNS cache...";
/ip dns cache flush;
:delay 2;
:log info "Deleting last Backups...";
:foreach i in=[/file find] do={:if ([:typeof [:find [/file get $i name] \
"$sysname-backup-"]]!="nil") do={/file remove $i}};
:delay 2;
:local smtpserv [:resolve "smtp.gmail.com"];
:local Eaccount mail@mail.com;
:local EaccountTo  mail@mail.com;
:local pass password;
:local backupfile ("$sysname-backup-" . \
[:pick [/system clock get date] 7 11] . [:pick [/system \
clock get date] 0 3] . [:pick [/system clock get date] 4 6] . ".backup");
:log info "Creating new Full Backup file...";
/system backup save name=$backupfile;
:delay 2;
:log info "Sending Full Backup file via E-mail...";
/tool e-mail send from="<$Eaccount>" to=$Eaccount server=$smtpserv \
port=587 user=$Eaccount password=$pass start-tls=yes file=$backupfile \
subject=("$sysname Full Backup (" . [/system clock get date] . ")") \
body=("$sysname full Backup file see in attachment.\nRouterOS version: \
$sysver\nTime and Date stamp: " . [/system clock get time] . " " . \
[/system clock get date]);
:delay 5;
:local exportfile ("$sysname-backup-" . \
clock get date] 0 3] . [:pick [/system clock get date] 4 6] . ".rsc");
:log info "Creating new Setup Script file...";
/export verbose file=$exportfile;
:delay 2;
:log info "Sending Setup Script file via E-mail...";
port=587 user=$Eaccount password=$pass start-tls=yes file=$exportfile \
subject=("$sysname Setup Script Backup (" . [/system clock get date] . \
")") body=("$sysname Setup Script file see in attachment.\nRouterOS \
version: $sysver\nTime and Date stamp: " . [/system clock get time] . " \
" . [/system clock get date]);
:delay 5;
:log info "All System Backups emailed successfully.\nBackuping completed.";
and Email if working correct, I already check it
rextended
Re: Script don't work
Wed Sep 14, 2022 8:43 pm
For example, did you forget that you upgraded from v6 to v7?
mbghost
Thu Sep 15, 2022 7:18 am
It start do not work before upgraded
Jotne
Re: Script don't work  [SOLVED]
Thu Sep 15, 2022 8:43 am
You do not need { in start of script, same not need } at end of script.
You also do not need ; at end of each line. Only while separate various command on same line. (But do not do that, messy)
This script do work.
viewtopic.php?t=183631
mbghost
Thu Sep 15, 2022 9:46 am
Got it, I'll try by the script))
rextended
Thu Sep 15, 2022 11:05 am
It was pretty easy to figure out what you did ...
The script (ignoring syntax horrors) cannot work on any (actual or previous) v7 version...
You probably remember badly, it's since you upgraded to v7 that it doesn't work.
On v6 it's quite unlikely it won't work, but I may have had an oversight.
mbghost
Fri Sep 16, 2022 11:45 am
Thank you so much))
Users browsing this forum: JDF, Kanzler, kormenator and 171 guests
