kelvinmurithi3229
CLI command not working or finding values
Thu Sep 15, 2022 5:06 am
I'm trying to run this command
 /ip route disable [find dst-address=0.0.0.0.0/0 gateway=10.15.30.1]
which I found on an article https://www.linkedin.com/pulse/basic-is ... y-symonds/. The command doesn't disable any of the routes despite them being there.
I also tried to find only and no results are returned.
It works if I use the find gateway only. ie.
 /ip route disable [find gateway=10.15.30.1]
What am I doing wrong here for the first 1 not to work?
mkx
Re: CLI command not working or finding values
Thu Sep 15, 2022 8:17 am
First make sure the [ find ... ] part works by running command
:put [ find ... ]
If find construct works, you should see some value printed (it'll probably be a meaningless value like *30000001). What I found is that sometimes one has to put quotes around CIDR IP address, and I tend to put spaces around square brackets:
:put [ find dst-address="0.0.0.0.0/0" gateway=10.15.30.1 ]
Users browsing this forum: Bing [Bot], foresthus, K0NCTANT1N, pav5, pmcsill and 128 guests
