HasanAlawlaki
7.5 no session time left & limit bytes total?
Fri Sep 16, 2022 2:01 am
7.5 no user manager session time left & limit bytes total?
Not showing on winbox or status page ..!
usmank
Re: 7.5 no session time left & limit bytes total?
Sat Oct 08, 2022 4:12 am
Yes... I have the same problem with this, is there any solution? :idea:
rumahnetmks
Tue Oct 11, 2022 4:48 pm
Yes, for the status it happens since I switch to ROS 7 (v7.1 that time). No status left time and limit byte total.
I just have test at ROS 7.5 hotspot system, UserManager>Limitation>Session Time, work. I test a 10-minutes user, the user exactly disconnected after 10minutes.
But for volume limitation it wont work (this happen since v7.1). For this one I still use Mikrotik Attributes, Mikrotik-Total-Limit...
As I ever post here viewtopic.php?p=900484#p900484 there I mention at Note...
Note :
Work since 7.6, tested. If dont work try netinstall.
Alxpv
Thu Nov 17, 2022 6:28 pm
Hello, well, if I set at User Group - Attributes - Mikrotil-Total-Limit for example as 250000000 when user reaches this value, it will be logged off. But 2nd attempt to login will allow this user to restore initial 250Mb limit and he could use it again several times more :)
Any ideas to fix this?
Reason: removed excessive quotting of preceding post; be wise, quote smart.
HasanAlawlaki
Mon Mar 13, 2023 12:24 am
Until version 7.8, the problem is still that user data does not appear in the hotspot, such as the remaining time or the remaining bytes. Does anyone have a solution?
rumahnetmks
Wed Mar 29, 2023 2:10 pm
/user-manager use-profile=yes have been set up?
Users browsing this forum: No registered users and 13 guests
