Tomek11
Possible attack
Fri Sep 16, 2022 9:24 am
Hello!
Every day I have a killing ike in the log on my router from the 169.228.69.212 IP address and a research-scan@sysnet.ucsd.edu domain.
Basically It's a school in San Diego.
Has anyone encountered this problem?
Znevna
Re: Possible attack
Fri Sep 16, 2022 12:07 pm
What is the reported problem?
gonzo2022
Re: Possible attack
Sun Oct 02, 2022 8:05 pm
I have the same problem from ip 169.228.66.212. Firewall error: identity not found for peer: RFC822: research-scan@sysnet.ucsd.edu.
It try to connect on port 500. The problem is that I cannot block this IP in the firewall :(
depth0cert
Re: Possible attack
Sat Oct 08, 2022 2:29 pm
05:16:09 ipsec,error identity not found for peer: RFC822: research-scan@sysnet.ucsd.edu
BartoszP
Re: Possible attack
Sat Oct 08, 2022 2:32 pm
If you cannot block that port then block offending IP in Filter RAW without any logging.
gonzo2022
Re: Possible attack
Tue Oct 18, 2022 11:48 am
Blocking through the filter raw works ok.
Thank you for the advice,
BrateloSlava
Re: Possible attack
Sat Nov 12, 2022 9:58 pm
gotsprings
Re: Possible attack
Sun Nov 13, 2022 2:38 am
Why not add that domain or IP to an address list and dump it at the top of the firewall?
mkx
Re: Possible attack
Sun Nov 13, 2022 10:31 am
Performance-wise it should either be done in raw (to skip connection tracking machinery for those packets) or right after "accept established,related" rule(s) to skip evaluation of that rule for each and every packet passing firewall.
Users browsing this forum: holvoetn and 126 guests
