markos222
IRC vulnerability: CVE-2022-2663
Sat Sep 17, 2022 12:20 pm
Hi
I have seen beta that there is a fix for CVE-2022-2663, how we are afected, is there any mitigation?
How this vuln actuate?
Disabling irc helper is sufficient?
rextended
Re: IRC vulnerability: CVE-2022-2663
Sat Sep 17, 2022 12:59 pm
This is not a "MikroTik" vulnerability, you can not gain any access to RouterBOARD or any other (non-IRC) device if the sevice is active or not,
The attacker can impersonate other endopints only on device where IRC software is executed
and also the device where IRC is present must be NATted.
Just disable IRC helper on /ip firewall service-port
For default I disable useless services on all my RouterBOARD.
Users browsing this forum: djferdinad, Google [Bot], GoogleOther [Bot], jaclaz, Maggiore81, own3r1138, VMX and 87 guests
