odroid
Configuration Wifi - Hap Ac Lite
Sat Sep 17, 2022 12:55 pm
Hello everyone, this is my first Mikrotik router and I must be lost getting the 2.4Ghz and 5Ghz wifi to work.
I have a Hap AC LITE (RouterOS 7.5) connected to my internet provider router, there are 2 computers connected in RJ45, All the parameters are by default and it works as it should, I never added anything that is.
I wanted to use my Mac M1 laptop in Wifi but I can't manage to configure the wifi of the Hap AC LITE router.
In interface there is Wlan1 and Walan2 but impossible to activate ( managed by CAPsMAN ) Couldn't change Interface <wlan1> - interface managed by CAPsMAN (6)
In the Quick Set / Home Hap Dual / Local network parameters, I have to fill in request an ip address and whatever I enter when I apply the changes, I cannot access the router and the wifi connection does not arrive at retrieve an ip address and there is no internet connection.
I have to reset everything every time because it is impossible to reconnect to the router.
Can you help me please.
rextended
Re: Configuration Wifi - Hap Ac Lite
Sat Sep 17, 2022 1:05 pm
Never use QuickSet after first configuration (or better, at all)
Go to WebFig / CAPsMAN section and manage the device...
odroid
Sat Sep 17, 2022 1:28 pm
thank you for your reply
In the CaPsMan configurations there is nothing, what should I do to make the wifi work?
rextended
Sat Sep 17, 2022 3:55 pm
Go on (the same screen) wireless menu on the left, click "CAP" button and disable CAP.
holvoetn
Sat Sep 17, 2022 5:58 pm
Manager button and disable.
odroid
Sat Sep 17, 2022 8:52 pm
Thank you all for your help, working fine. ( Resolved )
Merci à tous ^^
Users browsing this forum: No registered users and 60 guests
