nichky
pppoe->vrf->vpn.l2tp
Sat Sep 17, 2022 1:48 pm
one of my client has pppoe (public ip-add) in to vrf, (it's too late to do proper route leaking) and because of that the l2tp is not able to establish.
I do believe that mangle is able to do something, but i have no clue how to do.
The router can ping out only if i do with the vrf table, from the main table cannot ping out, and i that cost the issue
the config is very simple :
/ip route vrf
add interfaces=pppoe-out1,vlan10,vlan11,vlan12,vlan13,vlan14 routing-mark=vrf1
and also im allowing 1701,4500,500 , and 50 (ipsec-esp) on the filter (even though in this case i dont need ipsec)
sindy
Re: pppoe->vrf->vpn.l2tp
Sat Sep 17, 2022 2:24 pm
It is not recommended to do that, but indeed a mangle rule
chain=output protocol=udp src-port=1701 action=mark-routing new-routing-mark=vrf1
should make the L2TP run.
nichky
Sat Sep 17, 2022 2:27 pm
why it's not recommended , will that break anything?
sindy
Sat Sep 17, 2022 2:28 pm
That's a good question but I haven't found any explanation in the manual. It just says "don't do it". But I admit I only do that when handling the own traffic of the router, not a forwarded one.
nichky
Sat Sep 17, 2022 2:39 pm
sill no, this is what i can see on log
sindy
Re: pppoe->vrf->vpn.l2tp  [SOLVED]
Sat Sep 17, 2022 3:12 pm
Is this router an L2TP client or an L2TP server? Is it running ROS 6 or ROS 7?
Also, maybe remove the mangle rule and use a routing rule instead:
/ip route rule add src-address=ip.of.the.pppoe action=lookup-only-in-table table=vrf1
nichky
Sat Sep 17, 2022 3:17 pm
server, v6
to mi daj!!!! radi
nichky
Mon Sep 19, 2022 8:20 am
just for our records , that route rule, doesn't work on v7,i hope that MT will fix it up
Users browsing this forum: Ahrefs [Bot], dazzaling69, Google [Bot], grayfoxbsd, Question and 147 guests
