thomassocz
Can connect to SSTP VPN but can't interact with Windows Server
Sat Sep 17, 2022 2:04 pm
Hi all,
we use a single server (Windows Server 2019 Essentials) in our micro-sized business. The server's role are Domain Controller, DNS, DHCP and some others.
We also have a MikroTik router. This is our only router and is connected to the internet directly - it's the main gateway to our network and functions also as a firewall.
I managed to configure a SSTP server on the router and I am able to connect to it from a distant network using a Win 10 client.
I can ping the server's IP address. But I can't do anything else...
  • Can't ping the server hostname
  • Can't access shared files
  • Can't do anything else on the server, basically just ping its IP
Needless to say, this all works when I'm connected directly to the network.
The server handles the DHCP, however when I configured the SSTP on MikroTik, I had to assign some IP Pool to VPN clients. As I am fairly new to MikroTik, I'm not sure if I did everything correctly here. The Windows Server DHCP assigns range 192.168.100.100-192.168.100.254 and I configured the VPN Pool on Mikrotik to 192.168.101.100-192.168.101.254.
I also have several bridges on the router, one of which is my company network. I made sure to assign this bridge to the VPN connection.
I tried to turn off Windows Firewall on the server, but that didn't do anything.
I would appreciate any tips about why this might be happening.
Thanks a lot.
Tomas
tdw
Re: Can connect to SSTP VPN but can't interact with Windows Server
Sun Sep 18, 2022 4:43 am
Without seeing the configuration it is impossible to say what is wrong, post the output of /export hide-sensitive after redacting any other information such as public IP addresses. From the symptoms most likely firewall rules, VPN DNS settings.
Using multiple bridges is generally not optimal as hardware offload is only supported on one bridge on most Mikrotiks. SSTP is an IP VPN so bridges are not relevant to the setup unless attempting to use the PPP BCP functionality.
thomassocz
Mon Sep 19, 2022 11:15 am
Hi, thanks for your reply.
As for now, I'm using the public IP address, not DNS name, so that shouldn't be the issue. I plan on adding the "A" record to our public DNS after I make it work with IP.
Here is the requested information:
# sep/19/2022 10:07:01 by RouterOS 6.49.6
# software id = 6D4F-G8NH
# model = RB3011UiAS
# serial number = HCV085R40Q0
add admin-mac=18:FD:74:5C:40:3D auto-mac=no comment=defconf name=bridge-datel
add name=bridge-home
set [ find default-name=ether2 ] arp=proxy-arp
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
    name=security-datel
add comment=defconf name=WAN
add comment=defconf name=LAN
/caps-man datapath
add bridge=bridge-datel interface-list=LAN name=datapath-datel
/caps-man configuration
add country="czech republic" datapath=datapath-datel hide-ssid=no installation=\
    indoor mode=ap name=CAPs security=security-datel \
    security.authentication-types=wpa2-psk security.encryption=aes-ccm ssid=\
    DatelInternalWifi
add authentication-types=wpa2-psk mode=dynamic-keys name=profile-datel \
    supplicant-identity=""
add name=vpn_pool ranges=192.168.101.100-192.168.101.254
/ppp profile
add bridge=bridge-datel local-address=192.168.100.1 name=profile-sstp \
    remote-address=vpn_pool
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=CAPs
add bridge=bridge-datel comment=defconf interface=ether2
add bridge=bridge-datel comment=defconf interface=ether3
add bridge=bridge-datel comment=defconf interface=ether4
add bridge=bridge-datel comment=defconf interface=ether5
add bridge=bridge-home comment=defconf interface=ether6
add bridge=bridge-home comment=defconf interface=ether7
add bridge=bridge-home comment=defconf interface=ether8
add bridge=bridge-home comment=defconf interface=ether9
add bridge=bridge-home comment=defconf interface=ether10
add bridge=bridge-home comment=defconf interface=sfp1
add comment=defconf interface=bridge-datel list=LAN
/interface sstp-server server
set authentication=mschap2 certificate=Server enabled=yes force-aes=yes pfs=yes
add address=192.168.100.1/24 comment=defconf interface=bridge-datel network=\
    192.168.100.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.100.1 comment=defconf name=router.lan
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=Bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A" list=Bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=Bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=Bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B" list=Bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=Bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=Bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=Bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=Bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=Bogons
add address=224.0.0.0/4 comment="MC, Class D, IANA" list=Bogons
add action=drop chain=forward comment="Disable Internet Remote Desktop" \
    dst-port=3389 in-interface=ether1 protocol=tcp
add action=accept chain=input dst-port=443 protocol=tcp
add action=accept chain=forward comment="Allow Always On VPN Connections" \
    dst-port=500,4500 protocol=udp
    established,related,untracked
    invalid
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
    Bogons
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/ip service
set telnet disabled=yes port=2301
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.100.0/24 port=2201
set api disabled=yes
set winbox address=192.168.100.0/24
set api-ssl disabled=yes
/lcd
set backlight-timeout=never default-screen=stats read-only-mode=yes
/system clock
set time-zone-name=Europe/Prague
/system identity
set name=DatelRouterBoard
/tool mac-server
/tool mac-server mac-winbox
Thanks a lot.
Tomas
thomassocz
Wed Sep 21, 2022 11:00 am
Hi again,
after some further googling, I think that I may need to add an IP route for this? But I'm not sure which one.
Further testing shows that I can only ping the router, not the server or anything else in the network.
This is my detailed configuration:
  • I have several bridges on the router (bridge-datel, bridge-guest)
  • Mikrotik acts as DHCP server for bridge-guest - basically a guest wi-fi
  • Windows Server acts as DHCP server for bridge-datel (range 192.168.100.100-192.168.100.149)
Please see a screenshot here:
Basically I need the VPN connections to be able to access everything in bridge-datel
Thanks in advance for any tips.
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Wed Sep 21, 2022 1:20 pm
They way your config is at the moment, i.e. vpn and LAN on same subnet, you will need proxy arp, which I do not suggest.
Rather give your vpn a separate subnet to the LAN, and then route / firewall between these
thomassocz
Wed Sep 21, 2022 1:54 pm
Ok, let's say that my LAN subnet is 192.168.100.0/24 and my VPN subnet will be 192.168.101.0/24.
Can you please advise how I would set the routing and firewall for this?
Also, what role will my Windows DHCP Server play in this scenario? Currently it assigns 192.168.100.100-192.168.100.149 to everything connected to bridge-datel.
Thanks a lot :)
Tomas
thomassocz
Wed Sep 21, 2022 4:04 pm
I tried something quite "random":
Unfortunately it doesn't work... :(
CZFan
Wed Sep 21, 2022 11:30 pm
Post full configuration export, screen shots shows only part of config
But there 2 things you really need to look at after separating the subnets.
One being that the vpn subnet is allowed in relevant chains in firewall on mikrotik, and second is you will need to add the vpn subnet on the windows firewall as by default, the windows firewall will block all traffic initiated outside its local ip range
thomassocz
Thu Sep 22, 2022 9:45 am
Hi, here it is.
I tried turning the Windows Firewall off and it didn't help, so that's not the issue.
Thanks a lot. Tomas
# sep/22/2022 08:44:09 by RouterOS 6.49.6
add name=bridge-guest
/caps-man datapath
add bridge=bridge-datel name=datapath-datel
add bridge=bridge-guest name=datapath-guest
/caps-man security
    name=security-datel
    name=security-guest
add country="czech republic" datapath=datapath-guest installation=indoor mode=ap \
    name=cfg-guest security=security-guest ssid=datel-guest
add country="czech republic" datapath=datapath-datel installation=indoor mode=ap \
    name=cfg-datel security=security-datel ssid=datel-office
add name=vpn-pool ranges=192.168.100.150-192.168.100.199
add name=guest-pool ranges=192.168.175.2-192.168.175.254
add address-pool=guest-pool disabled=no interface=bridge-guest name=dhcp-guest
/ppp profile
    remote-address=vpn-pool
/caps-man manager
set enabled=yes
add action=create-dynamic-enabled master-configuration=cfg-datel \
    slave-configurations=cfg-guest
add bridge=bridge-datel comment=defconf interface=ether6
add bridge=bridge-datel comment=defconf interface=ether7
add bridge=bridge-datel comment=defconf interface=ether8
add bridge=bridge-datel comment=defconf interface=sfp1
set authentication=mschap2 certificate=Server default-profile=profile-sstp \
    192.168.100.0
add address=192.168.175.1/24 interface=bridge-guest network=192.168.175.0
/ip dhcp-client
add address=192.168.175.0/24 gateway=192.168.175.1
/ip dns static
add action=drop chain=forward comment="Prohibit WAN Remote Desktop" dst-port=\
add action=accept chain=input comment="Allow SSTP VPN Tunnel" dst-port=443 \
    protocol=tcp
add action=accept chain=forward dst-address=192.168.100.0/24 src-address=\
    192.168.101.0/24
    invalid
    Bogons
    invalid
    out,none out-interface=ether1
add distance=1 dst-address=192.168.101.0/24 gateway=bridge-datel
/ip service
/lcd
/ppp secret
add name=tomas.pokorny profile=profile-sstp service=sstp
/system clock
/system identity
/tool mac-server
thomassocz
Thu Sep 22, 2022 5:42 pm
Update:
After adding this rule to Windows Server Firewall:
I can now ping the Server from remote connection, but still can't access its resources.
Tomas
Sob
Thu Sep 22, 2022 10:25 pm
Do something similar for other services, e.g. if you want to access shared files, find "File and Printer Sharing (SMB-In)", open its properties and look at "Remote IP address" on "Scope" tab. By default there's only "Local subnet". Add 192.168.101.0/24 and it should work.
thomassocz
Mon Sep 26, 2022 3:34 pm
Hi, thanks, I added the VPN subnet to all firewall rules that were "Local subnet" only, but this didn't fix the issue.
Would you have any other ideas?
Thanks,
Tomas
Users browsing this forum: intania, voytecky and 93 guests
