MiiD0205
ProtonVPN - Ping/route subnet
Sat Sep 17, 2022 10:55 pm
First post here, I hope that everything will be written logical, network beginner here. :)
So I successfully configured ProtonVPN-IPsec with Mikrotik. Router doesn’t have anything else special configured because it is my secondary router. Only DHCP, route to main router and IPsec. Diagram is attached.
Main router: 192.168.10.0/24
Secondary/ProtonVPN router: 192.168.100.0/24
As you see, Mikrotik is connected to main router in diffrent subnet. If I disconnect IPsec, routing between them and devices(PC1 in PC2) works normally, ping from 192.168.100.x to 19.168.10.x and the other way around. With IPsec enabled, it doesn’t go through. This is probably because all the traffic goes through tunnel to WAN.
Question: How to set up firewall (maybe some other solution?) to make LAN traffic to main subnet work when I enable IPsec/ProtonVPN?
Thanks,
Configuration:
add name=WAN
add name=LAN
/ip ipsec mode-config
add name=ProtonVPN responder=no src-address-list=local
/ip ipsec policy group
add name=ProtonVPN
/ip ipsec profile
add dpd-interval=disable-dpd enc-algorithm=aes-256 hash-algorithm=sha256 \
    name=ProtonVPN
/ip ipsec peer
add address=node-us-67.protonvpn.net exchange-mode=ike2 name=ProtonVPN \
    profile=ProtonVPN send-initial-contact=no
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=ProtonVPN \
    pfs-group=modp2048
add name=dhcp ranges=192.168.100.10-192.168.100.150
add address-pool=dhcp disabled=no interface=bridgeLocal name=dhcp1
add bridge=bridgeLocal comment=defconf disabled=yes interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
add interface=ether1 list=WAN
add interface=bridgeLocal list=LAN
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal interfaces=\
    wlan1,wlan2
add address=192.168.100.1/24 interface=ether2 network=192.168.100.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.100.0/24 dns-server=8.8.8.8 gateway=192.168.100.1 \
    netmask=24
/ip firewall address-list
add address=192.168.100.0/24 list=local
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=\
    port-strict mode-config=ProtonVPN password=\
    ******* peer=ProtonVPN policy-template-group=\
    ProtonVPN username=*******
/ip ipsec policy
add dst-address=0.0.0.0/0 group=ProtonVPN proposal=ProtonVPN src-address=\
    0.0.0.0/0 template=yes
Users browsing this forum: Bing [Bot], dioeyandika, skodalex, Velos and 56 guests
