Amm0
$ROKU, the missing Roku TV remote for RouterOS
Sat Sep 17, 2022 11:36 pm
I've long used a Python-based command-line program, python-roku to control my Roku-based TV. It works pretty well, except I'd perfer "vi-style" keys to navigate the Roku TV's grid-like interface. For fun, I wrote a RouterOS script that uses the same HTTP-based Roku external control REST API, using ROS's /tool/fetch command (and /terminal/inkey). Once the script's variables are loaded, it can be run using "$ROKU <cmd>", it acts like a built-in command except prefixed with the "$" (to access the function that implements the "fake command"). Specifically "$ROKU remote" will run it as a command-line remote control for a RokuTV.
The ROKU script function works well enough for my purposes for a few months so thought I'd share. But likely not bug-free. In particular, "$ROKU remote" has a "keyboard mode" is a work-in-progress. Feel free to comment on improvements if anyone ends up using it. I have only tested it under RouterOS v7, but believe it should generally work also on V6 (but perhaps minor tweaks may be required)
Installing the script…
The script needed is at the bottom of this post. I assume some familiarity with RouterOS script – so how the ROKU function variable (and other needed associated variables) are loaded in the RouterOS "shell" is up to you, but any of the methods should work:
* Cut-and-paste the entire code block into the terminal. This allows you to test it on your particular router, but as variables are clear at power loss/reboot may not be best long term
* Copy the ROKU.rsc file below to RouterOS, then use ":import ROKU.rsc" to load it into a ROS terminal shell.
* Add the code to a /system/script via Winbox or CLI, then load the variable into the CLI by running in the terminal using /system/script/run <roku_script_name>
And, if you want to load it after reboot, you can use /system/scheduler. There are many "schools of thought" on how to load ROS scripts – I'm more sharing my ROKU remote code than how-to load a script here.
Implementation Notes
If you look at the code, the variable "ROKU" is main function. The code is structured into several global variables, either arrays or functions, but all must be loaded for the ROKU function to work.
A variable "roku-rcpmap" controls the keyboard mapping to Roku TV commands – feel free to adjust as needed (and any changed will be reflected in the "$ROKU remote" help screen).
Also, I haven't packaged this for general usage – it's more in the "fun with Mikrotik scripts" category – so you should understand some ROS scripting before using it...e.g. no warranties here ;).
Setting the Roku TV's IP address…
Roku TV OS uses DIAL/SSDP for service discovery. However, RouterOS has no native support for DIAL (or SSDP), so the ROKU script requires an IP address of the TV be specified. The IP address is available on a Roku TV under Home > Settings > Network > About. Obviously the TV's IP address needs to be reachable from the RouterOS device that's running the ROKU script.
Once the ROKU code is loaded, you can set the TV's IP address by entering like "$ROKU set ip=192.168.88.249" (replace with the actual IP address of TV). Internally, the script sets a DNS name "roku" to this IP, so alternatively you can add a static DNS record named "roku" that $ROKU will use.
$ROKU command usage…
All commands are access through a function named $ROKU that the script loads to global variable. The $ROKU functions has some "sub-modes" of operation:
* Script commands - like "$ROKU poweron" or "$ROKU input_hdmi1" that can be used in other scripts or directly at the ROS terminal
* Emulated remote control via $ROKU remote - will the function in a loop waiting for keypress in the RouterOS terminal, a help screen will the available commands but they generally follow "vi-style"(H=left, J=up, K=down, L=right) with return key same a Roku's "OK" button. In the remote control mode, a seperate "Keyboard Mode" can entered and exited via the backtick ` key (similar to switching vi/vim from command mode to input mode) –this allow typing into the various Roku screen like "Search"
* "$ROKU help" - will displace the full set of commands
* "$ROKU set ip=x.x.x.x" - will set the IP address of the Roku TV to use
"$ROKU help" will show the available commands. With "$ROKU remote" being the command to start the Roku TV remote "emulator" from the ROS terminal.
$ROKU - the missing remote for Mikrotik
   $ROKU remote  -  interactive remote using vi-like key maps
   $ROKU set ip=<roku_ip> - set Roku IP address as a static DNS name 'roku'
   $ROKU <cmd>  -  issues a single Roku remote control command, specifically:
        $ROKU back
        $ROKU backspace
        $ROKU channel_down      (requires TV with built-in Roku)
        $ROKU channel_up        (requires TV with built-in Roku)
        $ROKU down
        $ROKU enter
        $ROKU find_remote
        $ROKU forward
        $ROKU home
        $ROKU info
        $ROKU input_av1         (requires TV with built-in Roku)
        $ROKU input_hdmi1       (requires TV with built-in Roku)
        $ROKU input_hdmi2       (requires TV with built-in Roku)
        $ROKU input_hdmi3       (requires TV with built-in Roku)
        $ROKU input_hdmi4       (requires TV with built-in Roku)
        $ROKU input_tuner       (requires TV with built-in Roku)
        $ROKU left
        $ROKU literal
        $ROKU play
        $ROKU power     (requires TV with built-in Roku)
        $ROKU poweroff  (requires TV with built-in Roku)
        $ROKU poweron   (requires TV with built-in Roku)
        $ROKU replay
        $ROKU reverse
        $ROKU right
        $ROKU search
        $ROKU select
        $ROKU up
        $ROKU volume_down       (requires TV with built-in Roku)
        $ROKU volume_mute       (requires TV with built-in Roku)
        $ROKU volume_up         (requires TV with built-in Roku)
"$ROKU remote" emulator
The basic commands in "remote" mode are:
* Roku "OK" button is mapped the return key.
* Roku "Home" button is mapped to the tab key.
* Roku's * key is mapped the letter "i" (for "info").
* Either the arrow keys or "vi keys" (h,j,k,l) can be used to navigate menus.
* The "\" key will toggle the power from it's current state (either on -> off OR off -> on) while "P" means explicitly only "Power On".
* 1,2,3,4 will switch to the corresponding HDMI input
* A backtick (`) entered an under-construction "keyboard input mode" to allow sending actual letter (e.g. not commands) to a connected Roku's text edit boxes like Search
The script will loop forever waiting for keyboard input (via /terminal/inkey), a separate help screen will show the current keyboard to Roku command map like so:
           ALL                      TV ONLY
back - Back
left - Backspace                down - ChannelDown
j - Down                        up - ChannelUp
enter - Enter
F - FindRemote
f - Fwd
tab - Home
i - Info                        ! - InputAV1
                                1 - InputHDMI1
                                2 - InputHDMI2
                                3 - InputHDMI3
                                4 - InputHDMI4
h - Left                        t - InputTuner
` - Lit
space - Play                    \ - Power
                                P - PowerOff
r - InstantReplay               p - PowerOn
b - Rev
l - Right
/ - Search
enter - Select
k - Up                          - - VolumeDown
                                0 - VolumeMute
                                + - VolumeUp
Control-C will exit the remote.
ROKU script function…
Here is actual code:
# $ROKU - the missing remote for RouterOS
:global ROKU
:global debug 0
# helpers types
:global "roku-rcpmap"
:global "roku-sendkey"
# UDP port for communication with roku (set later, default is 8060)
:global "roku-active-rcpport"
# RouterOS ASCII mappings
:global "ascii-map"
:global "ascii-name"
# main command function
:set ROKU do={
    # no keyboard events, so poll for keypresses every...
    :local loopdelay 100ms
    # global used variables must be defined
    :global ROKU
    :global "ascii-map"
    # default is port 8060
    :if ([:typeof ($"roku-active-rcpport")]!="num") do={
        :set "roku-active-rcpport" 8060
    # we require some command after $ROKU, like help or remote...
    :if ([typeof $1]="str") do={
        # if it's a known command, like "$ROKU back", easy...
        :local cmd ($"roku-rcpmap"->$1->"cmd")
        :if ([:typeof $cmd]="str") do={
            :local sendkeyout [$"roku-sendkey" $1]
            :put "\$ROKU '$1' sent to $sendkeyout"
            :return $sendkeyout
        # interactive remote use "$ROKU remote"...
        :if ($1="remote") do={
            # first, output possible commands
            :put "\t   ALL  \t            TV ONLY"
            # & process $"roku-rcpmap" for output and
            # as a "pivot" rcpmap on keypress (e.g. lookup table for keypress to roku cmds)
            :local cmdkeymap [:toarray ""]
            :local lastcol -1
            :foreach k,v in=($"roku-rcpmap") do={
                :local hit ($v->"keypress")
                :local tags ($v->"tags")
                :local cmd ($v->"cmd")
                :if ($tags~"tv") do={
                    :if ($lastcol=0) do={/terminal cuu}
                    :put "\t\t\t\t$hit - $cmd"
                    :set $lastcol 1
                } else={
                    :if ($lastcol=1) do={/terminal cuu}
                    :put "$hit - $cmd"
                    :set $lastcol 0
                :set ($cmdkeymap->"$hit") $cmd
            # always map array keys
            :set ($cmdkeymap->"up") "Up"
            :set ($cmdkeymap->"down") "Down"
            :set ($cmdkeymap->"left") "Left"
            :set ($cmdkeymap->"right") "right"
            :put ""
            :local keyed 65535
            :local started 1
            :local keyboard 0
            :while ($started) do={
                :local keyname [$"ascii-name" $keyed]
                :if ($keyname="`") do={
                    :if ($keyboard=1) do={
                        :set keyboard 0
                        /terminal cuu
                    } else={
                        :set keyboard 1
                        :put "KEYBOARD MODE ACTIVE               "
                :if ($keyboard=0 && [:typeof ($cmdkeymap->"$keyname")]="str") do={
                        :local sendkeyout [$"roku-sendkey" ($cmdkeymap->"$keyname")]
                        :put "\$ROKU $sendkeyout SENT $(($cmdkeymap->"$keyname"))"
                        :set keyed 65535
                        /terminal cuu
                } else={
                    :if ($keyboard=1 && $keyname~"^([A-z0-9]|\\.|enter|space|back)\$") do={
                        :local litkey "Lit_$keyname"
                        :if ($keyname="enter") do={:set litkey "Enter"}
                        :if ($keyname="space") do={:set litkey "Lit_%20"}
                        :if ($keyname="back") do={:set litkey "Backspace"}
                        $"roku-sendkey" $litkey
                        /terminal cuu
                        :put "\t\t\t\t     sent $litkey      "
                :if ($keyboard=0 && $keyname~"q|Q|x|X") do={
                    :return "Quiting Roku Remote..."
                :set keyed [/terminal inkey timeout=$loopdelay]
            :return ""
        :if ($1="help") do={
            :put "\$ROKU - the missing remote for Mikrotik"
            :put "   \$ROKU remote  -  interactive remote using vi-like key maps"
            :put "   \$ROKU set ip=<roku_ip> - set Roku IP address as a static DNS name 'roku'"
            :put "   \$ROKU <cmd>  -  issues a single Roku remote control command, specifically:"
                :local requires ""
                :if (($v->"tags")~"tv") do={
                    :set requires "(requires TV with built-in Roku)"
                :put "\t\$ROKU $k \t$requires"
            :return ""
        :if ($1="set") do={
            :if ([:typeof [:toip $ip]]="ip") do={
                :local rokudns [/ip dns static find name="roku"]
                :if ([:len $rokudns]=1) do={
                    /ip dns static set $rokudns address=$ip
                } else={
                    /ip dns static add name=roku address=$ip type=A
            :if ([:typeof $port]="str") do={
                :set ($"roku-active-rcpport") [:tonum $port]
            :return ""
        :if ($1="print") do={
            :put "\t ip: \t $[:resolve roku]"
            :put "\t port: \t $($"roku-active-rcpport")"
            :return ""
    [$ROKU help]
:set "roku-sendkey" do={
    :global debug
    :local rokuip [:resolve roku]
    :local rokuport ($"roku-active-rcpport")
    :if ([:typeof $rokuip]!="ip") do={
        :put "Problem! \$ROKU does a DNS lookup for 'roku'. To fix, use a static DNS entry with the IP of your Roku devices"
        :error "\$ROKU 'roku' does not resolve to an IP address.  An IP address of a Roku device is required."
    :if ($1="Lit") do={:return "$rokuip:$rokuport"}
    :local rokurl "http://$rokuip:$rokuport/keypress/$1"
    :if ($debug = 1) do={
        :put "DEBUG: sending $rokurl"
    :do command={
        :local out [/tool fetch http-method=post output=none url=$rokurl as-value]
    } on-error={:put "Unsupported command."; /terminal cuu}
# KV array mapping roku commands to keyboard
# (tags= is used by help to organize the grouping)
:set "roku-rcpmap" {
    "home"={
        cmd="Home";
        keypress="tab";
        tags={""}
    "reverse"={
        cmd="Rev";
        keypress="b";
        tags={""}
    "forward"={
        cmd="Fwd";
        keypress="f";
        tags={""}
    "play"={
        cmd="Play";
        keypress="space";
        tags={""}
    "select"={
        cmd="Select";
        keypress="enter";
        tags={""}
    "left"={
        cmd="Left";
        keypress="h";
        tags={""}
    "right"={
        cmd="Right";
        keypress="l";
        tags={""}
    "down"={
        cmd="Down";
        keypress="j";
        tags={""}
    "up"={
        cmd="Up";
        keypress="k";
        tags={""}
    "back"={
        cmd="Back";
        keypress="back";
        tags={""}
    "replay"={
        cmd="InstantReplay";
        keypress="r";
        tags={""}
    "info"={
        cmd="Info";
        keypress="i";
        tags={""}
    "backspace"={
        cmd="Backspace";
        keypress="left";
        tags={""}
    "search"={
        cmd="Search";
        keypress="/";
        tags={""}
    "enter"={
        cmd="Enter";
        keypress="enter";
        tags={""}
    "literal"={
        cmd="Lit";
        keypress="`";
        tags={""}
    "find_remote"={
        cmd="FindRemote";
        keypress="F";
        tags={"find"}
    "volume_down"={
        cmd="VolumeDown";
        keypress="-";
        tags={"tv"}
    "volume_up"={
        cmd="VolumeUp";
        keypress="+";
        tags={"tv"}
    "volume_mute"={
        cmd="VolumeMute";
        keypress="0";
        tags={"tv"}
    "channel_up"={
        cmd="ChannelUp";
        keypress="up";
        tags={"tv";"channel"}
    "channel_down"={
        cmd="ChannelDown";
        keypress="down";
    "input_tuner"={
        cmd="InputTuner";
        keypress="t";
        tags={"tv";"input"}
    "input_hdmi1"={
        cmd="InputHDMI1";
        keypress="1";
        tags={"tv";"input"}
    "input_hdmi2"={
        cmd="InputHDMI2";
        keypress="2";
        tags={"tv";"input"}
    "input_hdmi3"={
        cmd="InputHDMI3";
        keypress="3";
        tags={"tv";"input"}
    "input_hdmi4"={
        cmd="InputHDMI4";
        keypress="4";
        tags={"tv";"input"}
    "input_av1"={
        cmd="InputAV1";
        keypress="!";
        tags={"tv";"input"}
    "power"={
        cmd="Power";
        keypress="\\";
        tags={"tv";"power"}
    "poweroff"={
        cmd="PowerOff";
        keypress="P";
        tags={"tv";"power"}
    "poweron"={
        cmd="PowerOn";
        keypress="p";
        tags={"tv";"power"}
# function, takes $1 a num result from [/terminal inkey]
#           and maps to name a string name like "tab" or "enter"
:set "ascii-name" do={
    :global "ascii-map"
    :local keyname ""
    :local keyed [:tonum $1]
    :if ($keyed<255) do={
        :set keyname ($"ascii-map"->$keyed)
        #:put $keyname
    } else={
        :if ($keyed=65535) do={ :set keyname "timeout" }
        :if ($keyed=60929) do={ :set keyname "left" }
        :if ($keyed=60930) do={ :set keyname "right" }
        :if ($keyed=60931) do={ :set keyname "up" }
        :if ($keyed=60932) do={ :set keyname "down" }
    :return $keyname
# array of str, with array index match the ascii code with value being the str name
:global "ascii-map"
:set "ascii-map" {"";"NUL";"SOH";"STX";"ETX";"EOT";"ENQ";"ACK";"back";"back";"tab";"VT";"FF";"enter";"return";"SI";"DLE";"DC1";"DC2";"DC3";"DC4";"NAK";"SYN";"ETB";"CAN";"EM";"SUB";"ESC";"FS";"GS";"RS";"US";"space";"!";"\"";"comment";"\$";"%";"&";"";"(";")";"*";"+";",";"-";".";"/";"0";"1";"2";"3";"4";"5";"6";"7";"8";"9";":";";";"<";"=";">";"\?";"@";"A";"B";"C";"D";"E";"F";"G";"H";"I";"J";"K";"L";"M";"N";"O";"P";"Q";"R";"S";"T";"U";"V";"W";"X";"Y";"Z";"[";"\\";"]";"^";"_";"`";"a";"b";"c";"d";"e";"f";"g";"h";"i";"j";"k";"l";"m";"n";"o";"p";"q";"r";"s";"t";"u";"v";"w";"x";"y";"z";"{";"|";"}";"~";"delete";"\80";"\81";"\82";"\83";"\84";"\85";"\86";"\87";"\88";"\89";"\8A";"\8B";"\8C";"\8D";"\8E";"\8F";"\90";"\91";"\92";"\93";"\94";"\95";"\96";"\97";"\98";"\99";"\9A";"\9B";"\9C";"\9D";"\9E";"\9F";"\A0";"\A1";"\A2";"\A3";"\A4";"\A5";"\A6";"\A7";"\A8";"\A9";"\AA";"\AB";"\AC";"\AD";"\AE";"\AF";"\B0";"\B1";"\B2";"\B3";"\B4";"\B5";"\B6";"\B7";"\B8";"\B9";"\BA";"\BB";"\BC";"\BD";"\BE";"\BF";"\C0";"\C1";"\C2";"\C3";"\C4";"\C5";"\C6";"\C7";"\C8";"\C9";"\CA";"\CB";"\CC";"\CD";"\CE";"\CF";"\D0";"\D1";"\D2";"\D3";"\D4";"\D5";"\D6";"\D7";"\D8";"\D9";"\DA";"\DB";"\DC";"\DD";"\DE";"\DF";"\E0";"\E1";"\E2";"\E3";"\E4";"\E5";"\E6";"\E7";"\E8";"\E9";"\EA";"\EB";"\EC";"\ED";"\EE";"\EF";"\F0";"\F1";"\F2";"\F3";"\F4";"\F5";"\F6";"\F7";"\F8";"\F9";"\FA";"\FB";"\FC";"\FD";"\FE";"\FF"}
anovojr
Re: $ROKU, the missing Roku TV remote for RouterOS
Thu Mar 14, 2024 10:14 pm
Thank you for the script. I will try it and and tell you my impressions.
Amm0
Fri Mar 15, 2024 4:32 am
I still use it, so it works. LMK if you run into trouble.
You need to either add static DNS for "roku" or use the following to set the Roku's IP address to control:
If you run "$ROKU remote", it uses the VI-keys to navigate menus . When in the remote, typing backtick ` puts you into "keyboard mode" to type actual keys for stuff like Search (and ` will get you out of "keyboard mode" back to command mode where the keys navigate).
I know the "help screen" could be cleaner, I kinda know what the keys do since I pick them ;)
arifworldnet2
Fri Mar 15, 2024 5:27 pm
You did a great job. I can see that you put a lot of time and effort into this. Will I be able to use my digital remote, or will it work only with the Roku TV remote? My physical TV remote control does not work correctly, so I use a digital one. I connected my TV to my phone via an app I downloaded from the App Store. Here is the link to the app if you want to understand what type of digital remote I am using: https://apps.apple.com/us/app/universal ... 6467252904.
Amm0
Fri Mar 15, 2024 5:41 pm
It works with anything that runs "Roku OS", a lot of TV have Roku built-in but the Roku sticks would also work. But it's not a universal remote ;)
Since it uses IP directly to the TV, it does not actually involve the remote control. It uses a REST API on the TV to send the commands. So on RouterOS side, it uses /tool/fetch and it's /terminal/in-key makes it "interactive" wait for keypress, with some arrays doing lookups on what to do when a keypresses. With the status line bring updated using :put then /terminal/cuu.
The underlying approach could work for potentially more useful things – like creating more "interactive" UI over VLAN bridge. Instead, I occasionally make CLI remote controls, and more recently a "piano" (which is a fun one, if you're router's :beep does something at CLI): viewtopic.php?t=204728
I have a few Roku's and used a Python script for years that did similar CLI control of the TV. But the python script didn't support "VI" like keys & writing anything in RouterOS script is kinda fun programming challenge.
Users browsing this forum: No registered users and 20 guests
