raminmalek
Scrpit Working On version 6 For Get backup And Transfer to remote FTP server
Sun Sep 18, 2022 8:40 am
Hi Dear Friends I need Script that shedulet every week To get backup From my router And Transfer to the Remote FTP
Please share with me
Jotne
Re: Scrpit Working On version 6 For Get backup And Transfer to remote FTP server  [SOLVED]
Sun Sep 18, 2022 8:54 am
# Backup sctip to send rsc and binary backup to FTP server
# Remember to create a folder with name as show $info_$serial
# Jotne 2022
# ver 1.2 added path
# ver 1.3 fixed missing serial
:local Server "192.168.88.5"
:local User "FTPUser"
:local Pass "FTPPassword"
/system
:local date [clock get date]
:set $date ([:pick "$date" 0 3].".".[:pick "$date" 4 6].".".[:pick "$date" 7 11])
:local time [clock get time]
:set $time ([:pick "$time" 0 2].".".[:pick "$time" 3 5])
:local info [identity get name]
:local board ([resource get board-name])
:local serial
:if ($board!="CHR") do={
	:set $serial [routerboard get serial-number]
} else={
	:set $serial "CHR"
:local Version [resource get version]
# Take readable backup
:if ($Version~"^7") do={
	[:parse "/export show-sensitive file=backup.rsc"]
} else={
	/export file="backup.rsc"
:delay 2s
# Take binary backup
/system backup save name="backup"
:delay 2s
# Send files to FTP server
/tool fetch address="$Server" src-path="backup.rsc" user="$User" mode=ftp password="$Pass" dst-path="$info_$serial/$info_$serial_$date_$time.rsc" upload=yes port=21
:delay 2s
/tool fetch address="$Server" src-path="backup.backup" user="$User" mode=ftp password="$Pass" dst-path="$info_$serial/$info_$serial_$date_$time.backup" upload=yes port=21
:delay 2s
# Remove temp files
/file remove backup.backup
/file remove backup.rsc
:log info "Backup router=$info serial=$serial ok"
raminmalek
Sun Sep 18, 2022 10:21 am
Thanks I need Standard file Name For widnows Format used Filezilla server On windows Server
Colons are not valid in filenames on Windows
STOR content_742907D17019/content_742907D17019_sep.18.2022_11.46.rsc
550 Filename invalid
Jotne
Sun Sep 18, 2022 10:44 am
As written in the script. You need to make folder that it tries to write to.
For your files, it would be: content_742907D17019
I could have put all routers in one folder, but that would be messy if you have many routers.
PS some strange Identity name of a router: content
Users browsing this forum: No registered users and 22 guests
