eldoncito2019
Why the file is not created
Sun Sep 18, 2022 10:13 pm
I am using these scripts made by REXTENDED, I have copied and pasted the same as the original scripts and I cannot find why the file is not created
:global addLogToFile do={
    :local filename "$1"
    :local fileext  ".txt"
    :local maxlen 4095
    /file
    :if ([:len [find where name="flash" and type="disk"]] = 1) do={:set filename "flash/$filename"}
    :local wkfilename "$filename$fileext"
    :if ([:len [find where name=$wkfilename]] = 0) do={print file="$wkfilename"; :delay 5s; set $wkfilename contents=""}
    :local filecon [get $wkfilename contents]
    :local filelen [:len $filecon]
    :local addthis "$2\r\n"
    :local addlen  [:len $addthis]
    :if (($filelen + $addlen) > $maxlen) do={
        :set filecon ""
        :set filelen 0
        :delay 1s
    :set filecon  "$filecon$addthis"
    set $wkfilename contents=$filecon
    :delay 1s
/system
:local date [clock get date]
:set $date ([:pick "$date" 4 7]."".[:pick "$date" 0 4]."".[:pick "$date" 7 11])
:local time [clock get time]
:set $time ([:pick "$time" 0 2]."".[:pick "$time" 2 8])
/file
:local filename "TESTING"
:local filecontent [get $filename contents]
:local newfilecontent  "*********************************************\r\nTIME:  $time          DATE:   $date\r\n$filecontent"
[$addLogToFile $filename $newfilecontent]
set $filename contents=$newfilecontent
taking advantage of the help, how would I send the file by mail before it is deleted?
Thanks for the help.
EL DONCITO.
rextended
Re: Why the file is not created
Mon Sep 19, 2022 10:56 am
You altered my function.
If there were things written inside it was not by random.
eldoncito2019
Mon Sep 19, 2022 4:02 pm
I can't find where I'm wrong REX, help me please,
EL DONCITO.
rextended
Re: Why the file is not created  [SOLVED]
Mon Sep 19, 2022 4:49 pm
Try to stop to copy & paste random script here and there.
    :local fileext  ".txt" ; # can be only .txt !!!
    :local maxlen 4095
    /file
    :if ([:len [find where name=$wkfilename]] = 0) do={print file="$wkfilename"; :delay 2s; set $wkfilename contents=""; :delay 1s}
        :set filecon ""
        :set filelen 0
        :delay 2s
    :delay 1s
/system clock
:local date [get date]
:local time [get time]
:set $date "$[:pick $date 4 7]$[:pick $date 0 4]$[:pick $date 7 11]"
:local filename "TESTING" ; # do not put any extension, only the filename
:local logthis  "*********************************************\r\nTIME:  $time          DATE:   $date"
[$addLogToFile $filename $logthis]
eldoncito2019
Mon Sep 19, 2022 5:13 pm
Thanks REX, in the file write like this.
But I would like you to write like this, of course if you can.
EL DONCITO.
rextended
Mon Sep 19, 2022 5:25 pm
What is? The game "Find the differences between two images"?
How many are they?
Maybe a description...
simplye change
with
:set filecon  "$addthis$filecon"
eldoncito2019
Mon Sep 19, 2022 5:48 pm
Excuse me friend REX, I did it as you recommended and it's still the same.
EL DONCITO.
rextended
Mon Sep 19, 2022 5:50 pm
Is not possible, you done it wrong.
eldoncito2019
Mon Sep 19, 2022 5:53 pm
    :local maxlen 4095
    /file
        :set filecon ""
        :set filelen 0
        :delay 2s
    :delay 1s
/system clock
rextended
Mon Sep 19, 2022 5:59 pm
Check yourself what you done wrong,
for me work:
TESTING code
TIME:  01:00:10          DATE:   02/jan/1970
TIME:  00:59:57          DATE:   02/jan/1970
TIME:  00:59:44          DATE:   02/jan/1970
eldoncito2019
Mon Sep 19, 2022 10:07 pm
The script is working very well friend Rex, how can I send the file before it reaches 4095 bits by mail
EL DONCITO.
rextended
Mon Sep 19, 2022 10:44 pm
I'm not going to edit the script one bit at a time again,
because every time you add a subsequent request instead of clearly explaining what you need.
Check how long it takes to fill up, and have it sent out on a regular basis before it fills up.
Users browsing this forum: No registered users and 26 guests
