luca773
Performance issue and QoS question
Sun Sep 18, 2022 10:32 pm
I have a quite simple setup on a RB750GL: PPPoE internet on eth1, LAN subnet on eth4, LAN2 on eth5 and VoIP phones on eth2.
I would like to implement some sort of QoS to give VoIP phones on eth2 highest routing priority. So I started by marking Voip packets and then added a global queue.
Is that a correct approach?
Also by disabling fastrack-connection to take advantage of firewall mangle feature I had a massive drop in performance (throughput on SMB share falls from ~90MB/s to 20MB/s with 100% RB750GL cpu usage). Is that normal or am I missing something?
thanks
# sep/18/2022 21:13:11 by RouterOS 6.49.6
add action=fasttrack-connection chain=input connection-state=established,related disabled=yes
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=fasttrack-connection chain=forward connection-state=established,related disabled=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/ip firewall mangle
add action=mark-connection chain=forward comment="VOIP Packets" \
    in-interface="eth2 - VoIP 86.0" new-connection-mark=VoIP_connection passthrough=yes
add action=mark-packet chain=forward connection-mark=VoIP_connection new-packet-mark=VOIP_Packet passthrough=\
    yes
add action=change-dscp chain=postrouting comment="DSCP Priority" disabled=yes new-dscp=46 packet-mark=\
    VOIP_Packet passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=\
    Eolo-pppoe
/queue
add name=Queue1 parent=global queue=default
add name=Priority1-VoIP packet-mark=VOIP_Packet parent=Queue1 priority=1 queue=default
add name=Priority7-Other packet-mark=no-mark parent=Queue1 priority=7
seriquiti
Re: Performance issue and QoS question
Mon Sep 19, 2022 11:02 am
Disabling Fasttrack will stop traffic from being handled in HW and thus will be processed by CPU. The RB750GL only has a single core 400mhz CPU so it can't do much.
Instead of disabling fasttrack globally you can add a firewall rule to bypass fasttrack only for traffic going to the internet. In regards to QOS, with that CPU you probably won't see more than 40mb's reliably over a queue.
If you need more speed you will have to replace that router with something a bit more powerfull.
luca773
Mon Sep 19, 2022 10:31 pm
Good suggestion, didn't think about.
BTW just ordered a RB750gr3 since my internet connection will be upgraded to 200Mbit soon. It's an entry level device but I hope will be enough.
thanks
Users browsing this forum: philipwillemse, plastilin, vagrik and 230 guests
