john231
wlan port flapping - normal?
Tue Sep 20, 2022 10:01 am
Hello, i have a hap ac3 that has a uptime of 104 days with a lot of wlan link downs registered.
wlan1
wlan2
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=estonia disabled=no distance=indoors frequency=2417 installation=indoor mode=ap-bridge ssid=Oru \
    wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=estonia disabled=no distance=indoors frequency=5200 installation=\
    indoor keepalive-frames=disabled mode=ap-bridge multicast-helper=disabled ssid=Oru wireless-protocol=802.11 wps-mode=disabled
Is this normal? I have another hap ac with uptime over 30 days and with 0 link downs.
Ca6ko
Long time Member
Long time Member
Re: wlan port flapping - normal?
Tue Sep 20, 2022 11:02 am
This number shows how many times no device has been connected to the interface.
mkx
Tue Sep 20, 2022 6:08 pm
Adding to reply by @Ca6ko: check meaning of property disable-running-check
in wireless manual. You may want to toggle its setting, benefit goes beyond the annoying statistics.
Users browsing this forum: No registered users and 15 guests
