Techsystem
can not ping 8.8.8.8 from my MT router
Tue Sep 20, 2022 5:22 pm
Hello my friends ..! so i just realied that i can't ping 8.8.8.8 from my mikrotik and when i traceroute the ping i get this
the 10.10.0.200 is not my public ip.
but when i ping 1.1.1.1 i get response and my public ip as the first ip in the list.
so anyone have any idea on what may be cause this..?
anav
Re: can not ping 8.8.8.8 from my MT router
Tue Sep 20, 2022 5:32 pm
Your internet provider is ahead of its time and banning anything touched by google???
Let me get out my tarot cards, crystal ball, crystal meth, snake oil, divining rod, harry potters wand, and an ouiji board....
OR
/export full config (hide serial number and any public WAN IP info)
Znevna
Tue Sep 20, 2022 5:33 pm
Yes.
Either something in your config or your ISP is doing something fishy.
Techsystem
Tue Sep 20, 2022 7:25 pm
OR
Lol...so here is my router config
Techsystem
Tue Sep 20, 2022 7:26 pm
Yes.
but in same area from other router i can ping 8.8.8.8. and they are from the same provider.
rextended
Tue Sep 20, 2022 7:52 pm
Probably 8.8.8.8 is used as test for failover somewhere, and on that moment the line is unavailable....
Ca6ko
Long time Member
Long time Member
Tue Sep 20, 2022 8:02 pm
So try 8.8.4.4
Techsystem
Tue Sep 20, 2022 9:27 pm
So try 8.8.4.4
it works ..and that's my DNS server.
rextended
Tue Sep 20, 2022 10:26 pm
:roll:
Lokamaya
Wed Sep 21, 2022 8:00 am
192.168.2.1 is your modem, I guess. And 10.10.0.200 maybe a port forward or something in your modem...
sebus46
Sat Aug 10, 2024 2:30 pm
Experienced the exact same today.
From client can ping 8.8.8.8, but NOT from Mikrotik itself
[admin@MikroTik] > ping 8.8.8.8
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 8.8.8.8                                                      timeout
    1 8.8.8.8                                                      timeout
    2 8.8.8.8                                                      timeout
    3 8.8.8.8                                                      timeout
    sent=4 received=0 packet-loss=100%
Cludflare works
[admin@MikroTik] > ping 1.1.1.1
    0 1.1.1.1                                    56  60 7ms336us
    1 1.1.1.1                                    56  60 7ms328us
    2 1.1.1.1                                    56  60 7ms150us
    3 1.1.1.1                                    56  60 7ms431us
    sent=4 received=4 packet-loss=0% min-rtt=7ms150us avg-rtt=7ms311us max-rtt=7ms431us
Ca6ko
Long time Member
Long time Member
Fri Aug 30, 2024 7:57 pm
When you encounter such a problem do traceroute 8.8.8.8.8 and you will find out on which device the problem occurs
