Cibersuite
"RouterOS V7.x BUG" (another user that do not read changelogs)
Tue Sep 20, 2022 6:06 pm
when we update the mikrotik the winbox options are bugged and it does not allow access even through ssh
Anyone else have happened ?
we attach captures
It has happened to us in CCR-1009 and other models
rextended
Re: "RouterOS V7.x BUG" (another user that do not read changelogs)
Tue Sep 20, 2022 6:36 pm
Another user that the first thing he does writes "RouterOS v7.x BUG",
instead you'd better read all the changelogs between the v6 you had before and the v7 you put.
If you create a "default" skin where you removed various options on WebFig, on v7 you remove that options also for WinBox...
Znevna
Tue Sep 20, 2022 6:42 pm
The last part doesn't make sense though, "even through ssh", probably not skin related?
rextended
Tue Sep 20, 2022 6:44 pm
I think if is because do not appear "New Terminal" option on webfig and winbox.
if you read the post is misspelled, probably some automatic translator
Users browsing this forum: askarot, Google [Bot], marsando, rspott and 219 guests
