basyir
VPN - PPTP Cannot Connect Remotely
Thu Sep 22, 2022 12:40 pm
Hi there,
Newb here. I'm trying to setup PPTP VPN in a lab environment to enable remote access to my network.
Upon setting up, tested local connection - VPN works.
Connecting from another network seems to fail for unknown reasons.
Pardon my absolute lack of knowledge on this.
Connecting remotely via Windows 10 yields this:
Exported config:
add name=dhcp_pool1 ranges=10.0.10.50-10.0.10.254
add name=PPTP_pool ranges=192.168.2.10-192.168.2.100
add address-pool=dhcp_pool1 disabled=no interface=bridge name=dhcp1
/ppp profile
add local-address=10.0.10.1 name=PPTP remote-address=PPTP_pool
interface bridge port
add bridge=bridge comment=defconf interface=sfp1
/interface l2tp-server server
set default-profile=PPTP ipsec-secret=####### use-ipsec=yes
add interface=unifi list=WAN
/interface pptp-server server
set enabled=yes
add address=10.0.10.1/24 comment=defconf interface=bridge network=10.0.10.0
/ppp secret
add name=username password=####### profile=PPTP service=pptp
Appreciate any kind assistance. Regards,
Basyir
own3r1138
Long time Member
Long time Member
Re: VPN - PPTP Cannot Connect Remotely
Thu Sep 22, 2022 1:34 pm
Enable the LOG on your server and also check if the firewall helper service is on. some of your configs look wrong to me I changed them to what I have done.
However, You should consider changing the protocol to something else, the PPTP protocol was discontinued.
system logging
add disabled=no topics=pptp,!packet
ip firewall service-port set pptp disabled=no
ip pool add name=PPTP_pool ranges=192.168.2.10-192.168.2.100
ppp profile add local-address=192.168.2.1 name=PPTP remote-address=PPTP_pool dns=192.168.2.1
interface pptp-server server set enabled=yes
ip address add address=192.168.2.0/24 interface=bridge network=192.168.2.0
Users browsing this forum: litogorospe, pmcsill, unhuzpt and 94 guests
