Lokamaya
How can I Get/Set Variable from JSON Parse Function?
Thu Sep 22, 2022 5:33 pm
Hi all,
I have a json file with IP address and other data. I try to parse it with JParseFunctions (https://github.com/Winand/mikrotik-json-parser). The script running well on terminal, but I don't know how to make it works on /System/Scripts.
JSON code
  "ip": "108.177.16.30",
  "hostname": "30.r1.unverified-forwarding.1e100.net",
  "city": "Brussels",
  "region": "Brussels Capital",
  "country": "BE",
  "loc": "50.8505,4.3488",
  "org": "AS15169 Google LLC",
  "postal": "1000",
  "timezone": "Europe/Brussels"
My script :shock:
:global JSONLoad;
:global parsedIP "X";
:set parsedIP {
    return (:put ([$JSONLoad "ipaddress-api.json"]->"ip"))
:log warning $parsedIP;
Thanks in advance
Lokamaya
Re: How can I Get/Set Variable from JSON Parse Function?
Thu Sep 22, 2022 5:40 pm
I have run the script and make JSONLoad as global variable.
rextended
Thu Sep 22, 2022 7:57 pm
Too much frills and mess....
:global JSONLoad
:log warning ([$JSONLoad "ipaddress-api.json"]->"ip")
Lokamaya
Fri Sep 23, 2022 6:29 am
Thanks @rextended, its works.
I'll try it with more complex script to get dynamic public IP of my ISP and stored it on address list.
rextended
Re: How can I Get/Set Variable from JSON Parse Function?  [SOLVED]
Fri Sep 23, 2022 10:52 am
" get dynamic public IP of my ISP and stored it on address list"
All this for simply that? Ignoring the existence of MikroTik's Cloud DDNS:
/ip firewall address-list
remove [find where list="current-wan-ip"]
add list="current-wan-ip" address=[:resolve "myip.opendns.com" server=208.67.222.222]
Is better you expose what you want at the end, that ask for solve something inside.
If I misunderstood your description, explain yourself better, even with an example.
Lokamaya
Sat Sep 24, 2022 9:41 am
Thanks again. This is what I need.
I'am currently using ipinfo.io (json format) to get dynamic public ip.
elcapitan
Wed Dec 20, 2023 11:14 am
Public IP is also available as text by this link https://ipinfo.io/ip
Users browsing this forum: No registered users and 21 guests
