mokoko
No routing between 2 LANs connected via wireguard and a linux server
Thu Sep 22, 2022 11:43 pm
I try to connect 2 LANs that are behind firewalls/DSL lines and do not have public IPs. I have a Mikrotik on each LAN and want them to use a linux server with a public IP as a gateway using wireguard. IP-forwarding on the server is enabled.
LAN1/Mikrotik1: 10.253.108.1/24
LAN2/Mikrotik2: 10.253.109.1/24
I want the hosts in each LAN to be able to access the other LAN IP addresses. Eventually I want to add 2 more LAN segments.
The connection/routing should be done using wireguard, the server is (internal IP) 10.253.253.1, the Mikrotik routers are 10.253.253.108 and 10.253.253.109
- wireguard works perfectly
- the Mikrotiks can ping the server (10.253.253.1 and each other 10.253.253.108 and 10.253.253.109)
- from the linux server, I can ping the local LAN IPs (10.253.108.1 and the hosts on that LAN, same with 10.253.109.x)
- but I can't get one Mikrotik to reach the other one (or any hosts) on the LAN side. So I cannot ping 10.253.108.1 from Mikrotik2 and 10.253.109.1 from Mikrotik1.
I just spent 3 hours trying to figure out why, not understanding where the mistake is. Can anyone help me please?
Wireguard-Peers on the linux server:
[Peer]
PublicKey = XXXXX
AllowedIPs = 10.253.253.108/32, 10.253.108.0/24
PersistentKeepalive = 15
[Peer]
PublicKey = XXXXX
AllowedIPs = 10.253.253.109/32, 10.253.109.0/24
Mikrotik1 config (other one is exactly the same, just 108/109 changed). Some details XXXX'd:
# sep/22/2022 22:12:00 by RouterOS 7.5
# software id = QH2C-IGET
# model = RB750Gr3
# serial number =
add admin-mac=XXXXX auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=53923 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp ranges=10.253.108.100-10.253.108.199
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.253.253.1/24 endpoint-address=XXXXX endpoint-port=XXXXX interface=wireguard1 persistent-keepalive=10s public-key="XXXXX"
add address=10.253.253.108/24 interface=wireguard1 network=10.253.253.0
add address=10.253.108.1/24 interface=bridge network=10.253.108.0
/ip dhcp-client
add address=10.253.108.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=10.253.108.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add disabled=no distance=1 dst-address=10.253.109.0/24 gateway=10.253.253.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/system clock
/system identity
set name=Router_MT_108
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=no down-script=\
    ":delay 15 \r\
    \n/interface/wireguard/disable wireguard1\r\
    \n:delay 1\r\
    \n/interface/wireguard/enable wireguard1\r\
    \n:log info \"WGPeer toggled\"\r\
    \n" host=10.253.253.1 http-codes="" interval=10s start-delay=20s test-script="" timeout=5s type=simple up-script=""
own3r1138
Long time Member
Long time Member
Re: No routing between 2 LANs connected via wireguard and a linux server
Fri Sep 23, 2022 2:01 am
anav
Fri Sep 23, 2022 2:06 am
Please draw a network diagram as I cannot make heads or tails out of what you described.
Each LAN does not require a router for example, how does a linux server have a public IP but the MT routers dont, nothing makes sense.
mokoko
Fri Sep 23, 2022 11:52 am
I read through that at least twice, but now this morning when I looked at (again) and was comparing my configs (again) I realized I was missing the "allowed-adress" parts for the remote subnet in the wireguard peers section. Sometimes it takes a night of sleep to see clearly again. It all works now.
add allowed-address=10.253.253.1/24,10.253.0.0/16 endpoint-address=XXXXX endpoint-port=XXXXX interface=wireguard1 \
I was missing the 10.253.0.0/16 part above.
mokoko
Fri Sep 23, 2022 11:54 am
Here is a simple diagram.
I fixed the issue (see above), but I hope this helps others that want to create similar setups!
anav
Fri Sep 23, 2022 3:48 pm
Glad its all working for you, so basically your MT devices are acting as routers getting a private IP address from unreachable routers.
Hence they simply need to be able to get out to the internet to reach the server as you described.
Yup, pretty standard wireguard setup.
Allowed addresses, firewall rules and IP routes have to line up.
The servers allowed IPs should include the wireguard IP address of each peer (/32) , the mT devices as peers should have the subnet of the IP wireguard network /24 as the allowed IP address (this permits you as the admin to be able to access the other MT router from another MT router for example for pinging purposes.
Thats the starting point, then add subnets that ALWAYS concern the other end (either the other ends subnets you will have local users reaching OR the other ends subnets that are coming to the local router).
Users browsing this forum: stef70 and 107 guests
