jamie398
Dual Wan Marking Connections with VLAN
Fri Sep 23, 2022 10:28 pm
Hi, I'm reasonably new to Mikrotik. I have an RB2011 that will only ever have two WAN's at a time. I want to connect some unifi AP's and VLAN tag the traffic but with VLAN 20 going out of WAN2 (Starlink in bypass mode). WAN1 needs to be a DHCP client as I would not be in control of the IP's on that side. This is my attempt and it does kinda work but looking for some advice on best practices or if I have missed something or general advice. Also there device connected to ETH10 that always routes via Starlink.
# sep/23/2022 20:11:43 by RouterOS 7.4
# software id = QX7H-822A
# model = RB2011UiAS
add admin-mac=08:55:31:4F:0F:09 auto-mac=no comment=defconf name=\
    "Starlink Bridge"
add admin-mac=08:55:31:4F:0F:09 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=08:55:31:4F:0F:08 name=WAN1
set [ find default-name=ether2 ] mac-address=08:55:31:4F:0F:09 name=\
    WAN2_STARLINK
set [ find default-name=sfp1 ] disabled=yes mac-address=08:55:31:4F:0F:07 \
    name=WAN3_SFP
set [ find default-name=ether3 ] mac-address=08:55:31:4F:0F:0A
set [ find default-name=ether4 ] mac-address=08:55:31:4F:0F:0B
set [ find default-name=ether5 ] mac-address=08:55:31:4F:0F:0C
set [ find default-name=ether6 ] mac-address=08:55:31:4F:0F:0D
set [ find default-name=ether7 ] mac-address=08:55:31:4F:0F:0E
set [ find default-name=ether8 ] mac-address=08:55:31:4F:0F:0F
set [ find default-name=ether9 ] mac-address=08:55:31:4F:0F:10
set [ find default-name=ether10 ] mac-address=08:55:31:4F:0F:11 poe-out=off
/interface vlan
add interface=bridge name=vlan20 vlan-id=20
add interface=bridge name=vlan40 vlan-id=40
add interface=bridge name=vlan60 vlan-id=60
add interface=bridge name=vlan80 vlan-id=80
add interface=bridge name=vlan100 vlan-id=100
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=dhcp ranges=10.10.0.100-10.10.100.100
add name=vlan40_pool ranges=10.40.40.20-10.40.255.250
add name=vlan60_pool ranges=10.60.60.20-10.60.255.250
add name=vlan80_pool ranges=10.80.80.20-10.80.255.250
add name=vlan20_pool ranges=10.20.20.20-10.20.255.250
add address-pool=dhcp interface=bridge lease-time=1d name=defconf
add address-pool=vlan40_pool interface=vlan40 lease-time=1d name=vlan40_dhcp
add address-pool=vlan60_pool interface=vlan60 lease-time=1d name=vlan60_dhcp
add address-pool=vlan80_pool interface=vlan80 lease-time=1d name=vlan80_dhcp
add address-pool=vlan20_pool interface="Starlink Bridge" lease-time=1d name=\
    vlan20_dhcp
/port
set 0 baud-rate=115200 name=serial0
/queue simple
add max-limit=20M/20M name="VLAN 80" target=10.80.0.0/16
add max-limit=10M/10M name="VLAN 60" target=10.60.0.0/16
add max-limit=10M/10M name="VLAN40" target=10.40.0.0/16
/queue type
add kind=pcq name=vlan40-pcq pcq-classifier=dst-address \
    pcq-dst-address6-mask=64 pcq-rate=1M pcq-src-address6-mask=64
add kind=pcq name=Download pcq-classifier=dst-address pcq-dst-address6-mask=\
    64 pcq-rate=2M pcq-src-address6-mask=64
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing table
add disabled=no fib name=ToStarlink
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=*C
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge="Starlink Bridge" interface=ether10
add bridge="Starlink Bridge" interface=vlan20
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add comment=defconf interface=WAN1 list=WAN
add interface=WAN2_STARLINK list=WAN
add interface=WAN3_SFP list=WAN
/interface ovpn-server server
set auth=sha1,md5
add address=10.10.0.1/16 comment=defconf interface=bridge network=10.10.0.0
add address=10.40.0.1/16 interface=vlan40 network=10.40.0.0
add address=10.60.0.1/16 interface=vlan60 network=10.60.0.0
add address=10.80.0.1/16 interface=vlan80 network=10.80.0.0
add address=10.20.0.1/16 interface=vlan20 network=10.20.0.0
add address=100.94.216.66/10 disabled=yes interface=WAN2_STARLINK network=\
    100.64.0.0
/ip dhcp-client
add comment="WAN1_DHCP Client" interface=WAN1
add comment="WAN2_DHCP Client" default-route-distance=2 interface=\
    WAN2_STARLINK
add comment="WAN3 SFP_DHCP Client" interface=WAN3_SFP
add address=10.10.0.0/16 comment=defconf dns-server=10.10.0.1 gateway=\
    10.10.0.1 netmask=16
add address=10.20.0.0/16 comment="Google DNS" dns-server=8.8.8.8,8.8.4.4 \
    gateway=10.20.0.1
add address=10.40.0.0/16 comment="Google DNS" dns-server=8.8.8.8,8.8.4.4 \
    gateway=10.40.0.1
add address=10.60.0.0/16 comment="Google DNS" dns-server=8.8.8.8,8.8.4.4 \
    gateway=10.60.0.1
add address=10.80.0.0/16 comment="Google DNS" dns-server=8.8.8.8,8.8.4.4 \
    gateway=10.80.0.1
set allow-remote-requests=yes cache-max-ttl=30m
/ip dns static
add address=10.10.0.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    "Block UDP on port 80 for Starlink to load full web pages correctly." \
    dst-port=80 out-interface=WAN2_STARLINK protocol=udp
    dst-port=443 out-interface=WAN2_STARLINK protocol=udp
    connection-state=established,related disabled=yes hw-offload=yes
    connection-state=invalid
add action=accept chain=input dst-port=80 protocol=tcp
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=ToStarlink \
    passthrough=yes src-address=10.20.0.0/16
add check-gateway=ping comment="Static Route To Starlink" disabled=no \
    distance=1 dst-address=0.0.0.0/0 gateway=100.64.0.1 pref-src=0.0.0.0 \
    routing-table=ToStarlink suppress-hw-offload=no
/lcd interface pages
set 0 interfaces="WAN3_SFP,WAN1,WAN2_STARLINK,ether3,ether4,ether5,ether6,ethe\
    r7,ether8,ether9,ether10"
/system clock
set time-zone-name=Europe/London
/system identity
set name="MikroTik"
/system ntp client
set mode=broadcast
/tool mac-server
/tool mac-server mac-winbox
anav
Re: Dual Wan Marking Connections with VLAN
Fri Sep 23, 2022 10:36 pm
This is the basic VPN guidance. - See Para C first link: viewtopic.php?t=182373
Understand that starlink even in bypass mode doesnt give you a true public IP, its CG NAT, which should be illegal. ( so to me its about as useful as a private IP )
and that your WAN1 ISP modem gives you a public IP.
By the way, for the new way of bridge vlan filtering, its
one bridge, all subnets as vlans with interface the bridge, bridge does no heavy dhcp lifting.
vlans get ip pool, ip address, dhcp server, dhcp server network
assign /interface bridge ports and /interface bridge vlans and then apply firewall routes to mach.
gotsprings
Sun Sep 25, 2022 6:55 pm
If you want traffic to flow out a second interface...
You have the mark the packets as they come on on that interface.
You need to mark the packets you want to use that interface.
Then you need an output rule for thos packets.
Then you need a route with those marks.
This also assumes you have the basics done already.
jamie398
Sun Sep 25, 2022 10:31 pm
/ip firewall mangle
Is this not correct then?
jamie398
Sun Sep 25, 2022 10:33 pm
Thanks, I will change this.
Users browsing this forum: Bing [Bot] and 184 guests
