tuxxy
RB750Gr3 not getting gigabit speed
Fri Sep 23, 2022 10:43 pm
I recently upgraded to a gigabit subscription and got a new modem sent by my ISP. My modem is operating in bridge mode. When I plugin a device in the bridge port I can see that I'm getting gigabit speed internet connection.
My Mikrotik RB750Gr3 is not getting anywhere near gigabit speed. Whenever I run a speedtest on my wired devices I get downloads speeds fluctuating between max 600 Mbps, 400 and even 100 Mbps.It constantly changes and I can not tell what is causing this. I never had these problems with my previous subscription (different modem) and always had the 600Mbps download speeds.
Today I did a reset and started from default configuration without any success. I made sure fast track is enabled and is the 1st rule on the firewall list.
What might be the cause and how to solve this?
My config:
 # sep/23/2022 21:14:14 by RouterOS 7.5
# software id = QMGA-7TGX
# model = RB750Gr3
# serial number =
add admin-mac=48:8F:5A:16:52:65 auto-mac=no comment=defconf name=local
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=listBridge
/ip hotspot profile
add name=dhcp ranges=192.168.200.100-192.168.200.200
add address-pool=dhcp interface=local name=defconf
/port
set 0 name=serial0
add bridge=local comment=defconf interface=ether3
add comment=defconf interface=local list=LAN
add interface=local list=listBridge
add address=192.168.255.254/16 comment=defconf interface=local network=192.168.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.2.248 client-id=ff:e4:82:d0:7e:0:2:0:0:ab:11:e0:8f:2c:c4:fb:92:17:38 mac-address=\
    42:5F:F7:4B:E6:7F server=defconf
add address=192.168.0.0/16 comment=defconf dns-server=1.1.1.1 gateway=192.168.255.254 netmask=16
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.255.254 comment=defconf name=router.lan
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
    src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Amsterdam
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
anav
Re: RB750Gr3 not getting gigabit speed
Fri Sep 23, 2022 11:46 pm
(1) I see no purpose for the interface listBridge ???
(2) Your IP pool does not jive.
Try to stick to normal sized networks for testing like /24, why the heck did you pick 16 with only a pool size of 100. Where is the logic??
(3) How does this happen when your pool is from .100 to .200
Other than that looks normal.
By the way according to the router specs you should expect somewhere in the 700 range for speeds.
If you want 1 gig, look at hapac2, hapac3 or RB4011.
rextended
Sat Sep 24, 2022 12:04 am
(1) yes, is useless, already exist LAN, but listBridge is used here:
/tool mac-server
rextended
Sat Sep 24, 2022 12:11 am
/ip dhcp-client
Not, your modem is on NAT mode and you double NAT your network....
And probably your modem DHCP give address on 192.168.1.x/24 range and go on conflict with all used 192.168.0.0/16 range, as already @anav noted...
If I do not remember bad, missing ,untracked after established,related on both lines???
Users browsing this forum: UniCloud and 67 guests
