noob05
WAN Access Problem
Fri Sep 23, 2022 11:07 pm
I've been messing with this for a while. Went through the forums- changed MAC to reflect old router, looked at firewall and NAT, established default gateway/route, checked on DHCP client....and I still CANNOT secure an IP address from my ISP. I talk with the ISP and everything looks good from their side...they see the Mikrotik MAC, and the link looks healthy....what am I doing wrong? Appreciate any help- I was relatively new to RouterOS...though I've spent a lot of time with it lately.... after a few restarts and resets- most of the settings are 'defconf'- I have to establish an internet connection before properly segmenting the network...didn't anticipate this hurdle. Old router/hardware still works well, and an IP address is dynamically assigned to my router by the ISP. Again- thanks in advance for thoughts or guidance!
[admin@Home_Route] > export compact hide-sensitive
# sep/23/2022 09:01:01 by RouterOS 6.47.10
# software id = ETJH-7EPS
# model = RB760iGS
add admin-mac=xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=ether1
/system clock
set time-zone-name=US/Central
/system identity
set name=Home_Route
/tool mac-server
/tool mac-server mac-winbox
Sob
Re: WAN Access Problem
Sat Sep 24, 2022 2:34 am
It seems fine, only your route (/ip route add distance=1 gateway=ether1) is nonsense, default route should come from DHCP client. I'm not sure if it's the problem, in my quick test the one from DHCP overrides this manual one, but I'm not completely sure right now whether it can go other way (which would break things). Anyway, you should remove it.
If it doesn't help, check what DHCP client says (/ip dhcp-client print detail).
And of course you must plug cable from ISP in ether1 and if you're cloning old router's MAC address, it must be done on ether1 (/interface ethernet set ether1 mac-address=xx:xx:xx:xx:xx:xx).
Users browsing this forum: Bing [Bot], jb1204 and 23 guests
