klausf
How to control NIC's on pc with ROS 7.5
Sat Sep 24, 2022 4:27 pm
I have installed 7.5 on a PC without any problems.
My problem lies in managing the NIC's. There is 1 onboard NIC and a intel 4 PRO 1000/PT 4 port nic.
The onboard NIC becomes ether5, and the intel ether1-4. Somewhat annoying.
I have tried to tweak the PCI addresses, but the MOBO do not support that. (asrock j4105B-itx)
As I see it, I have 3 solutions:
1: Live with it - A possibility, but not an option for me.
2: Find a way in ROS to tweak
3: Reprogram the intel pro 100 pt
Anyone got an idea ?
Sob
Re: How to control NIC's on pc with ROS 7.5
Sun Sep 25, 2022 12:20 am
And what exactly is the problem? If you don't like default names, then rename them and live happily every after.
set [ find default-name=ether5 ] name=onboard
klausf
Sun Sep 25, 2022 7:18 am
That is another solution, and it is a good one.
Users browsing this forum: McSee and 74 guests
